Question about Saeco Royal Professional Espresso Machine
Saeco royal,coffee dispens.blocked - Saeco Royal Professional Espresso Machine
JohnnyBeans
  • 223 Answers
SOURCE: royal coffee bar
You have the go into the menu and change the setting on the "direct water supply" option to off. Your machine comes from the factory set to use direct water feed. This option tells the machine water supply to use.
Saeco Parts and Cleaning supplies
www.cerinicoffee.com
Posted on Dec 19, 2007
  • 1089 Answers
SOURCE: SAECO Royal Professional no water comes out?
Hi
What is the lever for despensing grounds on the top of the side door reading. If its all the way to the back it probably too far. Pull it back one click and try it. The other thing you should try if its not the grounds it to push the button you want to use and hold it in until the liquid coffee want is reached, then release the button. This is called programing and you can do it to each button for you desired amount.
Posted on May 21, 2009
  • 1089 Answers
SOURCE: how to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Posted on Jun 14, 2010
  • 1089 Answers
SOURCE: How to decalcify a Saeco Royal coffee bar?
To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to "direct water connection" and push the enter. Chose "off" and push enter. Push "escape". Use the arrows on the left to scroll down until you come to "Descale". Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again
Posted on Sep 09, 2010
  • 1089 Answers
SOURCE: how to decalcify coffee machine
Hi
Your showing a different machine than a Royal and that one is different, but if yours is a Royal, this is how.
Auto descale: To automatically descale your machine, press the scoop or menu button and hold it down until you enter the menu. Use the arrow buttons to scroll up until you come to Descale. Press enter button and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Manual descale: To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Place the tank back on the machine, then turn the machine on.
  1. If you have a non-rapid steam machine, just open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
  2. If you have a rapid steam machine, turn on the machine and then push the hot water button. This turns off the rapid steam and allows you to run hot water/solution through the steam wand. Just open the steam valve and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes.
  3. Repeat step #2 for your type of machine. Do this until you have used the entire water tank of solution (approximately four to five cycles). Remove the water tank and rinse it with fresh water.
  4. Refill the water tank with fresh water and place it back on the machine.
  5. Repeat step #2 to rinse the machine, only this time use the entire water tank at one time, and there is not need to let it set.
  6. Your machine has been decalcified. You may still have scale in your boiler, but not as much as you had before. To reset your descale light, hold down on the steam button for at least five seconds. You are ready to brew, once your boiler has heated up.
Posted on Nov 12, 2010
Why wont the steamer work
hi,
he pump presses hot water through the grind not steam.
if the coffee is hot and hot water is dispensed, your line are clocked.
descale the machine as directed.
if coffee is cold the heat element is toasted. very unlikely though, since the machine will not dispens coffee, pump running if correct temperature is not reached.
good luck
Aug 08, 2014 | Saeco Royal Professional Espresso Machine
Saeco royal coffee bar steamer doesnt work
Hi there
Have you looked into the steamer to see if the things function there?
I suspect that there is something not working. What does the troublshooting say? Look there ;
http://www.generalmanual.com/Kitchen-Appliances/Saeco-Royal-Coffee-Bar.htm
Good luck
Kolbrun
Mar 05, 2012 | Saeco Royal Coffee Bar Coffee Maker,...
I need an owners manual for the Saeco Royal Cappuccino machine? SUP016R manufactured in 6/2006
Scroll down this page:
http://www.saeco-usa.com/en/products/household-automatic-machines/1/automatic/0/royal-coffee-bar/17/royal-coffee-bar.html
You can download the manual for your Saeco Royal in a PDF format.
Hope that helped! Thanks for using FixYa.
Jun 10, 2010 | Saeco Royal Cappuccino Espresso Machine
Cleaning of saeco royal cappucino machine
The user manual shows you how to clean your machine. If you don't have it you can download it from the Saeco site:
Apr 09, 2010 | Saeco Royal Cappuccino Espresso Machine
No water coming from Saeco Royal Professional Coffee Machine
Check the end of the steam spout using a paperclip make sure it is not blocked.
Oct 06, 2009 | Coffee Makers & Espresso Machines
Keeps saying "Coffee Beans Empty" - Saeco Royal Digital Plus
Either the coffee chute from the grinder is blocked, or the grind is too fine. Remove brew unit and check grinder chute.
Sep 28, 2009 | Saeco Royal Digital Plus Coffee...
Can you buy a repair manuel for a saeco royal
www.manualnguide.com/.../manual.../saeco-royal-professional-instruction-manual.html -try tis link
Jul 23, 2009 | Saeco Royal Coffee Bar Coffee Maker,...
Blocked coffee despencer
I think you have to go to a Saeco service center to fix this, it can be the electric board.
Jun 25, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
