Question about Element ELC-HS321 32 in. LCD TV
Element tv wont turn on red light is on but wont power up
Red light is on and a power up sound accrues when plugging it in but wont turn on
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
I had the same problem. The power supply board is bad and this is very common with this TV. I ordered a new power board from shopjimmy.com. The cost is $51.00 with shipping. Just open the back of the tv and you'll see the part number on the circuit board. It's easier to replace the whole board. You can also go on UTube and see a video on replacing the board. Very easy to do yourself. My tv hasn't had a problem since I replaced this board.
Posted on Apr 21, 2014
    Top Expert:
  • Element Master
  • 74,383 Answers
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Posted on Apr 19, 2014
3 Suggested Answers
  • 608 Answers
SOURCE: element elchs321----tv cuts off on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors. That crackling sound is the capacitors burning out.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
SD Tech
  • 14553 Answers
SOURCE: my element tv has red light on push power it clicks wont power on have keep plugging and unplugging till it double clicks then i can power it up
This sounds like a very common issue.
If set is hard to turn on (takes several tries)but will eventually turn on hereis what my guess would be.
Every set has a standby power supplythat is running 7/24 if the set is plugged in and it supplies voltage to theremote circuit that turn on the main power supply for the tv and hence turn theset on.
This is an area where companies cut corners by using lower rated voltage caps.By this I mean Standby usually provides under 10 volts to trigger the seton----what they do is use filter caps rated at say 10 volts max in a circuitwith 9 volts (example)=with the standby on all the time the filter caps(electrolytic caps) dry out and fail.
The problem usually begins where you have to turn set on or or two times andgradually gets worse--takes longer and more tries to get it to come up.
Once on it will stay on until turned off for a period of time.
The caps will begin to work better (regain some of thecapacitance) as they get hot--hence one it is on it will seem ok.
The beauty of this problem is most of themhappen when set is a year or two old (no warranty) and all you have to do islook at the top to locate bad ones.
They are generally black or blue and round and vary in --they have twoconnections each--a + for positive and a - for negative--not unlike a batterywhich in a way they are. The + and - are marked on top and bottom of most boards.
They are easy to replace and not expensive parts.
The tops are silverand metal looking with creases on top and if bad they will be puffed up ontop---tops must be perfectly flat with no brown material leaking top or bottom.
If this is your problem once you id them (make a drawing) you can begin.
Here is the critical part---on each cap is also marked the value like 220uf 10vdc---220 micro farad at 10 volts maximum.
If you find for example 6 puffed up and all are 10 vdc replace them with thesame value capacitance (like the 220 uf) but go up to at least in this case(from 10 volts) to a 16 or higher rated voltage cap.
The only issue is when you go up in voltage rated value the cap is larger sosometimes there is an issue of physical space for the replacement on the boardto fit them in.
The reason they cheapen these sets in this way is if 10 caps and you make25,000 sets there is a considerable savings in parts cost.
They do not care as long as it lasts past the usual one year parts warranty.
I have taken the time to be long winded because this really sounds like it maybe the problem you have.
See attached photo of a typical cap and if you have questions or need advicelet me know.5_23_2012_12_30_11_pm.jpg5_23_2012_12_30_36_pm.jpg
Posted on May 23, 2012
ELEMENT LED TV will not turn on
You have to check the power supply of the tv. Try to replace it then only you will be able to identify the fault. Is it the power supply or the motherboard
If you wish to get some more details about television repair then check the following link
http://electro-medical.blogspot.com/
Aug 16, 2016 | Element Televison & Video
Element flat screen tv screen appears off when power is on
At this stage, try replacing ps Caps. Old elements had cap problems in ps area.
Feb 11, 2014 | Element Electronics Televison & Video
Tv wont turn on the red light is on but will not turn on by power button on tv or remote
my tv has the same problem. I found if you unplug the TV for a couple of days, then plug it back in, it should work. The tv will also do this whenever there is a power failure or if you unplug the tv to use the outlet for another device.
Sep 26, 2013 | Element ELC-HS321 32 in. LCD TV
FLX3211b when plugged in the red power light comes. Then when the TV is turned the red light turns blue and stays on. The Element logo appears for a couple seconds then the screen goes black. There is a...
the transformer for the backlight is usually what fails on the elements especially if the logo comes up briefly then the screen goes out. I would check the transformers.
Apr 04, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Element (FLX-3210) I lost sound when I unpluged my pc plug from my laptop to the TV. Then I went to the tv output which had picture on the screen but no sound. Once the power was turned off the tv it...
The tv turn on now have power and LED power light indicator is on and solid green?Yes,than it is the main Tuner signal board had a short some where and it is the problems and the causes.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Nov 29, 2010 | Element Electronics FLX3210 32 in. LCD TV
Element stuck in standby and wont turn back on.
you can unplug the power cord and drench the power and after go ahead and plug in back the TV and try to start it
Jul 30, 2010 | Element Electronics FLX-1910 19 in. LCD...
Element tv.. model # ELCHS261 stopped working
My Element ELCHS261 will not turn on at all. The only thing it does is the red light will turn to blue but no sound and no picture. My troubleshooting items have been changed the batteries in the remote then I unpluged the power for for 30 minutes and still nothing.
Jul 10, 2009 | Element Electronics FLX2211B 22 in. LCD TV
HOOKED ELEMENTS FLX3210 TO LAPTOP TV DIED ONLY RED LIGHT WILL COME ON
Sounds like you need a new main board the light in the front comes on when you push the power button right?
Oct 07, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Element ELC-HS321 32 in. LCD TV Logo
433 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
