Question about Gigabyte GA-K8VM800M Motherboard
I want to know that , for BIOS updates in GA-K8VM800M motherboard, whether it is necessary to alter the jumper settings or not. If not, then please tell me about a Gigabyte model in which it is necessary.
    Novelist:
    Champion:
  • 256 Answers
I don't know how old is your Gigabyte Board, but the motherboard is not an invention that was exclusively for computers. The motherboard idea was generated for the defense electronic industry. Now what they had in mind with the jumpers, is not clear to me. I know for instance that the jumpers were calibrated to change the chip voltage 0.1V per step, but probably you are right. For a given frequency and speed that a computer is designed for, there is one setting of the jumpers. Now, if somebody wanted to change the frequency up or down then it would be necessary to change the settings of the jumpers. Thank you for your consideration and choice of our service. My name is Cosntantin (arzconst is my internal nickname for Fixya.com).
Posted on Jun 19, 2009
GA-K8VM800M MOTHERBOARD The problem with the board is that, initially it got the message that disk boot failure, after checking bios settings, still it got same message. I have changed the IDE cables...
Try making your hard drive as the first boot in the bios and just connect your hard drive only on the motherboard ( remove cd/dvd drive, etc..). Make sure your hard drive is detected in the bios. Then restart your computer again.
Oct 11, 2010 | Gigabyte GA-K8VM800M Motherboard
Can't enter window
check you cables from drives to mother board make sure they are all pushed in tight
and check the jumpers are set properly on all your drives then retry if it deosn't work you might need new motherboard or one o your cd or hard drives is faulty
Jul 09, 2010 | Gigabyte GA-K8VM800M Motherboard
Hello, I have a Gigabyte k8vm800m mobo. I get a steady amber light when I turn on my computer, but no POST and no beep.
i got the exact same problem then checked all the connections and the few jumpers i had,replaced battery, tried to get video , no onboard video, put in video card, got video once, still no beeps, retried to set up hd and install windows...then everything went at once, no beeps...never again...this was installed in a net pc with 1.5 gb memmory, board, no beeps, tried reinstalling chip and fan, power supply, checked all jumpers and wiring,,,all i can do i s replace motherboard i guess, must have shorted somewhere or kilt bios / cmos...
Jun 10, 2010 | Gigabyte GA-K8VM800M Motherboard
GA-K8VM800M - No Display
hi it could be your on board gpu these are not changeable, you could also check in the bios weather the first graphics display is the on board one and not an external one, the only way you can do this and also check to see if it is your on board gup is put in an external graphics card if this works then it is possible that your gpu is u/s, but check in bios first it might be just the setting that needs changing....hope this helps
Feb 22, 2010 | Gigabyte GA-K8VM800M Motherboard
PCI Video wont work with Gigabyte GA-K8VM800M motherboard
hey try the removing cards.....
window 7 may took up it best when no such changes are around..
! Gb or 2 RAm is enough to get run your Win 7
and sound card is noot required untill you have 4 or more speakers
Feb 12, 2010 | Gigabyte GA-K8VM800M Motherboard
Gigabyte K8vm800M Motherboard Does Not Recognise Seagate SATA HDD
I HAVE THE SAME PROBLEM IN THE PAST. I REPLACE THE IDE HDD WITH SATA AND AFTER I BOOT IT SAYS NO HARDDISK. IT IS BECAUSE WINDOWS XP HAS NO BUILT IN SATA DRIVER.
WHAT YOU SHOULD DO IS CHANGE YOUR HARDDISK TO IDE OR INTEGRATE A SATA DRIVER INTO YOUR XP (USE NLITE) OR USE THE FLOPPY DRIVE TO RUN SATA DRIVER ITS INCLUDED IN THE MOBO WHEN BUYING.
Mar 16, 2009 | Gigabyte GA-K8VM800M Motherboard
Needs video drivers for GA-k8vm800m
http://www.driverstock.com/download-GigaByte-GA-K8VM800M-driver/30-9-8096/index.html
Feb 26, 2009 | Gigabyte GA-K8VM800M Motherboard
My motherboard can;t detect my harddisk.....
Hi modjoguy, the bios must see your SATA hard disk before windows can see your SATA hard disk drive. To check this please press the delete key every two seconds as soon as you power on the system. (Note 1: Some motherboards that do not show the SATA II drive while in the bios may need its jumper set to SATA I in order for the bios to see the SATA drive). (See the drives large white sticker on the hard disk drive for SATA I location of jumper).
(Note 2: Gigabyte GA-K8VM800M rev 2.x & Gigabyte GA-K8VM800M-RH motherboards use the same manual). The Gigabyte GA-K8VM800M rev 1.x manual is slightly different, thus page numbers differ from the other two above.
Here is the link for all three: http://www.giga-byte.com/Search/Search_List.aspx?Keyword=K8VM800M&SearchType=Spec
The bios main menu will open. Open your manual (rev2.0 & RH) to page 38 & read under the listing, "IDE Channel 2/3 Master". The idea is your SATA drives should be listed at 2/3.
Once they are seen you need to open Advanced BIOS Features page 40. You can load the advanced bios features by pressing "Ctrl+F1" keys. You must list the SATA drive you want as the primary hard disk drive (Usually its the model number of the drive), that will have windows installed on it.
Good luck modjoguy!
Run into a snag just post it here.
Mike
Sep 01, 2008 | Gigabyte Computers & Internet
SHARED VIDEO MEMORY
go to this site http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ProductID=1810 and download the manual, it should show you how to change the onboard video settings
good luck
Terry
Mar 05, 2008 | Gigabyte GA-K8VM800M Motherboard
Gigabyte GA-K8VM800M Motherboard Logo
176 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
