Question about Vehicle Parts & Accessories
What can i do when rear lights cant come on except break lights and front head lamps
When i switch on lights on the dash board only front head lamps are coming on,rear lights cant come home
  • 78 Answers
Have you checked the bulbs, fuses, and of course the switch.
Posted on Apr 25, 2014
I HAVE NO REAR LIGTHS NORE BREAK LIGTHS NORE THE DASH BOARD
First check fuses. The parking lights and dash lights come on with the light switch, but have different fuses. if you have front lights( the switch is good), but no rear, check the grounds in the rear. They are usually mounted to the frame on the drivers side rear. As for the dash they have their own grounds. Places I know are at the steering column and behind the drivers side kick panel. You could also have problems at the plugs them selves, Corrosion. If you have no parking, brake, or reverse lights, it is a ground problem.
Jun 13, 2016 | 1999 Mitsubishi Montero Sport
My car toyota voltz rear lights cant come on when u switch on except break lights.what can do?
Several possible issues: 1) you have a blown fuse; look at the tail light fuse or breaker 2) there is a break (ie.short) in the wiring. I suggest taking this issue to a automotive electric specialist.
Apr 18, 2014 | Vehicle Parts & Accessories
No tail lights
no (park -tail-running lights) is dash parking lamps glowing?
check the tail fuse yet?
94 accord
this circuit is huge, park/tail, up to 20 lamps. are all dead>?
front park, side park, tail park and dash lamps all out.
this i the red-blk feed. all comments , USA, as lighting varies by country. (laws)
license plate light dead too????????? that too is park
there is NO RELAY.
the fuse 32 feeds the HL (head light) switch and in PARK posistion
it feeds 12vdc raw power to all 38 lamps. (side corning lamps,etc)
the license plate lamp is key, there are 2 lamps.
and both probably are not out.
so if they are good lamps and both tail lamps are good and fuse
then they must glow, if one lamp shorts as 1156 or the like love to do
then it blows the fuse. as does the trailer jack (option) .
so fuse 32 park/tail blown
or HL park switch bad, if all 20 odd lamps dead. and fuse holds.
that simple, and this cars wiring is very simple and nice.
Feb 26, 2014 | 1994 Honda Accord
Drving lights (running lights - in driver side rear) are out on my GX470.. HOw do i fix them??
you mean the park lamps.
the park lamp (HL switch 1 click, is park or as some call it tail or other running. same o samo)
the park circuit is the most complex lighing inthe car.
2 front, 3 rear.
4 sides.
and 10 in dash. and console, as many as 20 in all.
so if all work but some, the lamps are out, replace them.
how , as in how to remove them. ok.
there are basically 3 ways from 1920 to now, all cars on earth.
1: take out the lenses screws and , remove bulb
2: if no screw, look behind lamp. see screws, or nuts, bingo
3: last, on some cars the lenses pry out. do this last so you dont break the lenes.
there are exceptions, on some cars ring snaps on the lens locking it. pry it off,
in most cars, open the operator guide, see index
see lighting, turn to that page see lamp change out, bingo
lost the op guide?, Google will Find them all,, no need to guess, RTM.
Oct 16, 2013 | 2004 Lexus GX 470
2001 Monte Carlo SS 3.8 v6 Rear park lights are out as well as the dash lights, brake lights work headlights work front running and park lights work, all turn signal lights work. replaced headlight switch...
Park, Tail, Marker Lamps, and License
The park, tail and marker lamps, including the license lamps, turn on when the headlamp switch is placed in either the PARK or the HEAD position, or anytime the headlamps are requested. The RT I/P #1 fuse in the RH I/P fuse block supplies battery positive voltage to both the park lamp relay switch contacts and to the park lamp relay coil circuit. The park lamp relay coil is controlled by the body control module (BCM). When the headlamp switch is placed in the PARK position, the BCM energizes the park lamp relay coil control circuit.
Current flows from the park lamp relay switch to both front and rear park lamp fuses and to their respective park/tail lamps. The front park lamps are grounded at G101. The rear park lamps are grounded at G302. The license plate lamps are a part of the rear park lamp circuit and are grounded at G302. The inadvertent power control feature prevents the park lamps from remaining on more than 10 minutes if left on. If the park lamps are turned on after the ignition switch has been turned OFF, or is in the ACCY position, they will remain on until turned off or until the battery runs dead.
Did you the REAR PARK LP fuse 15 amp in the right insturment panel fuse box.
Jul 18, 2017 | 2001 Chevrolet Monte Carlo
Gear selector cant move from park and the break lamp is on, on the dash board.
Check the brake light switch, which also serves as the "Shift Lock Release" switch.
I hope this helps...
Jul 06, 2011 | 1990 Acura Legend
Dash lights and reap lights
change fuse in fuse box for instrument panel the dash lights go out to tell you your tail lamps are not working
Jul 20, 2009 | 2001 Ford Escape
Vehicle Parts & Accessories Logo
44 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
