Question about Brother CS-8150 Computerized Sewing Machine
Not sewing I was quilting today and the machine gave an awful clunking sound. I stopped and cut the thread but couldn't find anything wrong. Tried again and the bobbin thread isn't doing anything so it's not sewing. Can you help?? The race is turning around properly but it's like the bobbin thread doesn't go where it should.
  • 42 Answers
Suggest open bobbin case to see if loose thread has jammed it.
Posted on Apr 20, 2014
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 16 Answers
SOURCE: Unable to wind bobbin on Brother Css-8150 stopped suddenly
Checking to see if in fact that the bobbin shaft is turning. Run it without any bobbin on the bobbin shaft. Make sure that it is push over in the correct position and run it. I checked on mine and it does make the whirring sound and the the shaft does spin. Also check underneath the shaft to see if there is any thread wrapped around it. ( I had problems with that in the past). I hope this helps,
Posted on Sep 27, 2008
SOURCE: Thread won't catch bobbin
I hope to God nobody else pays more for a repair than the machine is worth.
It's ridiculous to spend $300 for that repair since the machine is available almost everywhere for way under $200. You could have thrown that one in the trash and bought a new one cheaper than the repair!!
I paid $129 for mine, had the same problem with two, yes, two of them, and sent them back and was sent another which so far is working fine. There seems to be a flaw in the engineering of that machine since so many people are experiencing the same problem. The machines DO have a warranty so please, please, be careful of unscrupulous repair people. Oh, I'm sorry but I need to mention that I bought my machine from eBay and it was a refurbished machine sold by Ken Sewing and Vacumm in Muscle Shoals, Al. They stand behind their products and were very nice to deal with, they even paid for the return shipping on the two that I returned. Hope this helps y'all.
Posted on Nov 10, 2008
SOURCE: brother xr-65 bobbin problem
insert the bobbin so the thread comes out in the middle a away from you, hold the thread end push the bobbin down with with your finger, and pass the thread securely through the thread cutting groove
Posted on Dec 08, 2008
SOURCE: thread knotting around bobbin case
hello, I had the exact same problem and could not find the solution until i took my machine to my sewing sensei and i solved my tedious problem. It was actually not a tension problem at all but a threading problem. Make sure you have threaded your bobbin correctly and that when you pull on the bobbin thread that the bobbin turns the right way. (mine must spin anti clockwise to work)  Make sure that when you pull up the bobbin thread using the needle that it is not over the feed dogs connective bar but under it. A big problem when the thread gets caught around the bobbin case wheel is that the thread is looped around the feed dogs once and that causes the thread to get caught around the bobbin wheel. In conclusion, thread the bobbin correctly and read over your instruction book before spending the money to get it fixe in s shop.
Posted on Mar 31, 2009
My machine is adding loops under my stitches when I try to stitch a straight stitch, I am trying to machine stitch a quilt top!
Quilting is a bit more finicky than regular sewing. Be sure to ALWAYS RAISE the presser foot when threading the top thread. FWIW, I use a separate bobbin case for FMQ that I have tightened the tension to keep the bobbin thread from coming to the top of the sandwich, but I tend to use a finer thread for quilting so adjusting the bobbin takes care of it. In your case, however, it sounds like the top thread is staying under the fabric. I would try tightening the top tension. Also, install a brand new needle--a top stitch, embroidery, or microtex needle seem to work well for me. Test well on a sandwich made of the same fabric and batting and get it adjusted well before sewing on your quilt. Sometimes sewing speed will affect stitches under the fabric, or even on top.
5 Free Motion Quilting Problems and How to Fix Them
Correcting Sewing Machine Tension for Free Motion Quilting NQC
LOOPS Tension or Speed
https://www.generations-quilt-patterns.com/machine-quilting-thread.html
https://www.generations-quilt-patterns.com/sewing-machine-tension.html
https://www.generations-quilt-patterns.com/machine-quilting-tension-problems.html
Feb 27, 2018 | Sewing Machines
My Singer 8500Q continuously stops and shows that the top thread is broken and won't sew. It's not broken, I rethread & it happens again. I just got this machine and think I've wasted my money.
Sounds like part of the problem is the top thread is not seated completely.
Remove the top thread from the machine (NEVER pull the thread up...clip the thread next to the spool, raise the presser foot, and pull the thread down through the needle).
ALWAYS RAISE the presser foot and rethread the top thread.
Verify that the thread path is correct.
Now retest your machine and tweak the tension, if needed.
Jul 23, 2017 | Singer Sewing Machines
When quilting my quilt the bobbin thread is heavy and messy on
This should be an easy fix, something is wrong with the upper threading. Take the thread off the machine, raise the presser foot up and rethread the machine, that should take care of it.
Apr 21, 2010 | PfaFF Creative 7570
Thread bunches up on Singer HD-110
my wife's hd110 singer machine is not keeping tension. what can I do/ look at to try and help this
Jul 07, 2009 | Singer HD-110 Mechanical Sewing Machine
MegaQuilter Tension
Try at least 2 new needles first (HLX5, preferably Schmetz). If same, look for any rough edges on the needle plate and feed dog cover.
Beyond that, this does not sound like you are doing anything wrong. You should take your machine in for adjustment by an authorized technician. You should have about 1/2 to 1 full turn of the upper tension knob between too loose/ugly on back and too tight/breaking on the top.
May 10, 2009 | Husqvarna Viking 1
Thread breaking
I HAVE THE SAME PROBLEM WITH THREAD BREAKING. HAVE TRIED EVERYTHING. FINALLY I GOT SOME UPHOLSTERY THREAD AND IT SEAMS TO WORK MUCH BETTER. NOW i AM HAVING TROUBLE FINDING THE NEEDLES FOR THIS MACHINE. NOT HAPPY WITH MACHINE AT ALL
Dec 09, 2007 | Janome 1600P-DB Mechanical Sewing Machine
Quilting
Janome now has a darning foot ie it looks like an embroidery foot with a spring designed for the 1600 models. It is metal with a ring where the needle goes down through it. I removed the plastic lens inside the ring and this seems to have resolved the problem.
I usually pull my threads to the top so I can see where they are and not getting tangled underneath.
There are several good groups on Yahoo groups which offer support for starting out on quilting
Oct 03, 2007 | Janome 1600P-DB Mechanical Sewing Machine
Brother CS-8150 Computerized Sewing Machine Logo
60 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
