Question about Canon PC-890 Black and White Copier
Canon CP890 ADF
The ADF unit will not feed orignals as it states orignal in unit and this is not the case
SOURCE: Canon D780 Adf Feed Rollers
http://www.precisionroller.com/ht/index.htm
Posted on Jan 14, 2008
SOURCE: Canon PC980 ADF PROBLEM
not really familiar with this model, however, you should be able to open the cover (slightly) where the paper feeds in and you will see some rubber rollers (likely top and bottom), try cleaning these with a rag dampened with some alcohol (preferably), or water, and turning gently (do not force). If you use water, dry them afterward
Posted on Feb 13, 2009
  • 12 Answers
SOURCE: Canon D780 ADF will not feed properly.
replace the feed tire assy
Posted on Jul 10, 2009
  • 3 Answers
SOURCE: It senses paper loaded into the ADF but doesn't feed
There should be a button with settings on it.....ie: 2 sided, collate, etc. There should be an option to change paper settings.......or just clear the whole menu, and go to default to reset the rollers.
Posted on Oct 20, 2009
  • 73 Answers
SOURCE: Paper jams when using the ADF. Canon IC D780
When using ADF
Note:
* Set a document on the Platen Glass if you want to scan it at optimum quality,
* The area (range) within 0.08"/2mm from the top edge if document cannot be printed since the machine cannot scan it.
*Do not load the following types of documents in the ADF. They will jam.
-Wrinkled or creased paper
- Curled paper
- Torn paper
- Paper with holes
- Carbon paper or carbon-backed paper
- Surface treated paper
- Onion skin or thin paper
- Photogragh or thick paper.
1) Remove any documents from the PLaten Glass.
2) Open the Document Tray.
3) Load the document in the ADF.
Load the document with the side you want to copy, or scan face up in the ADF.
4) Adjust the Doument Guides to match the document width.
Note :
Ensure that the edge of the document stack is in line with the Paper Size Mark imprinted on the Document Tray.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Posted on Nov 30, 2009
After i change a used transfer unit into the c900, why is it still stated need to change transfer unit?
Is this a remanufatured part?
Epson's printers have microchipsets that indicate when a unit is blown. Some remanufatured parts may still have defective chipsets that prevent printers from using these parts. Try buying an orignal part or another comaptable but new part to see if this works.
Let me know how it goes :)
Mar 06, 2010 | Epson AcuLaser C900 Printer
Changing lights in my truck
Before you buy them check with your local laws.Most states have outlawed the xenon,our state only allows them if they're factory orignal.
Nov 12, 2009 | 1988 Chevrolet K1500
I have a problem with my MP830 it is not scanning.
- Confirm the connection
- between the ADF motor and the ADF PWB, and
- between the ADF PWB and the logic board.
- Replace the
- document feed unit, or
- logic board.
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Documents will not feed from the ADF
Is there a more permanent fix in the meantime? I'm just tired of fiddling each time that I use the ADF
Jul 03, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Motherbord problem
i have problem with my mother board as my orignal processr was intel 933 mhz i have changed the processor with intel 366 mhz and after that i re instlled my orignal processor 933 mhz but system does not boot on my orignal processr
Jan 25, 2009 | Computers & Internet
CANON 4050 XEROX MACHINE
my xerox machine canon 4050 shown an eroor(E020)...we cant able to take copier
Oct 16, 2008 | Canon NP 6050 Copier
Bobbin tangles on Brother xr 65
This was happening to me too, I reversed the bobbin feeds and it has not tangled since then. I was orignally feeding the bobbin from the left side and now i feed the thread from the right. It works great this way.
May 19, 2008 | Brother XR-65t Mechanical Sewing Machine
CHECK ORIGNAL
you have the problem with your adf on machine try to see where is sensor jammed or broken
Feb 28, 2008 | Brother MFC-8840D All-In-One Laser Printer
Canon PC-890 Black and White Copier Logo
23 people viewed this question
old marine
old marine
