Question about Refrigerators
My refrigerator makes beeping sound
My fridge has been making beeping sound for a while.Last night it quit working, temparature dropped. After we reset it, now it seems working OK.
  • 31 Answers
What brand and model number refrigerator is ?
Posted on Apr 18, 2014
the dr
  • 447 Answers
SOURCE: Kenmore 106.53603202 stopped cooling making a clicking sound
The compressor may not have to be changed it could be the relay that is bad, not properly starting the compressor. The relay is attached to the compressor where the wires go to it. Remove it, Shake it, If it sounds like little rocks are inside (it rattles) than it is bad. Let me know what you find
Posted on Jan 05, 2008
  • 958 Answers
SOURCE: refrigerator makes lot of noise
based from your story. the noise could be coming from the compressor as it starts. compressor usually vibrates a lot when starting. it would last from a few seconds to a few minutes then would normalize as it sucked all the evaporator pressure down to its normal readings. you can check the rubber mountings of the compressor,you may need to replace them. also check for some tubings that may be rubbing or touching as the compressor vibrates. tighten alllso those mounting bolst of the compressor. that should solve your problem. if everything is done and still the same, the noise could be coming inside the compressor which there will be no solution but to replace the compressor. the cleaning that you did helped it a little bit because the vibration decreased a little coz it was able to breathe a little.
Posted on Feb 13, 2008
  • 1073 Answers
SOURCE: Kenmore Refrigerator making loud sounds at shutdown
the compressor has a loose or broken spring inside the compressor, unfortunatly it can not be repaired without replacing the compressor, it could last many more years and it could quit as we speak.
best thing is to let the neighbor know of the problem and what is the repair that way they won't think you are ponning off the machine to them, it may outlast your new one, time will tell
Posted on Apr 15, 2008
SOURCE: Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Posted on May 02, 2009
  • 3 Answers
SOURCE: Fridge makes loud moaning sound
It is the control board. There is a recall on certain models and serial #'s that will cover the parts, but not all are covered. do a google search for hotpoint or GE howling noise. you will find out all the info you need.
Posted on Oct 17, 2009
My fridge - model RS583HDP started making a noise in the fridge section a few days ago, like the fan was working quite loudly and every time you openned the fridge section, the fan slowed right down and...
try to lubricate or replace bushing of your evaporator fan maybe it has awear in tear that fan hard to rotate this can cause a noise and poor circulation of air cause of temp. rise
Feb 13, 2011 | Samsung Refrigerators
We had to manually defrost our frigidaire elite refrigerater and now it keeps beeping. Can you tell me how to reset it so it will stop? It beeped all night last night!
Hi there.
Did you unplug it to defrost it? Try to unplug the fridge for about 10 minutes and then try again?
Most often it works. Resetting button on the fridge?
Iceman.
Nov 05, 2009 | Refrigerators
Viking freezer and fridge won't get cold enough.
I had the same problem with my side by side. Make sure the vents are not covered inside both the fridge and freezer between the bottom and top so the cold air is able to circulate between them. My freezer had ice covering the bottom vent.
May 27, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Freezer not working , clicking noise coming from fridge
Clicking was a relay. Replaced relatively inexpensive relay and now working fine.
Jan 17, 2009 | Jenn-Air JCD2389G Side by Side...
Fridge & Freezer not cooling
i think you have a bad compressor pull it out and take off the back panel and feel the compressor if it is hot and making a bad sound it might be an over load relay
Dec 11, 2008 | Frigidaire PHS67EHS Side by Side...
Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Nov 30, 2007 | Maytag MTB2156GES Top Freezer Refrigerator
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Clicking Fridge
I used to have a whirlpool fridge, they are the ones who make kenmore too. It used to make a loud thud noise. It was the compressor turning off. sometimes it was loud enough to wake me up at night. It did this for years and I never had any problems with it. when I purchased a larger fridge I sold it to a friend and its still working today. If you can tolerate the noise I wouldn't worry about it unless it starts giving you trouble.
Nov 01, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
