Question about Hoover SteamVac F7411-900 Upright Vacuum
Machine dosen't spray solution all the time.
When I press the tigger for solution to come out doesn't always work.
  • 85 Answers
Do you hear the switch click every time? If not, change the switch.
Posted on Apr 21, 2014
Rug shampoo machine keeps blowing breakers now will not power on
It sounds like you have a dead short. Check the wire, it quite often will break at the point that it comes out of the machine. The power is going straight back to the panel before it gets to the motor and that flips the breaker. It probably needs the whole wire replaced. If you can take it apart, check with an ohm meter to see which wire it broken. Do not have it plugged in while doing this.
May 10, 2015 | Vacuums
The cord will not rewind
These get stuck all the time...I own 2 of these , and I have done this many times...Get a can of WD40 or some type of spray lubricant with the little straw in the nozzle. Try pulling and pushing the cord back inside(don't pull it too hard) while you are spraying the lubricant directly inside where the cord comes out. push the cord back in as if you were going to force all of it back inside the cord winder. You may even have to bump the back of the machine where the cord winder is located. But it will wind back up.If you are worried about getting the lubricant on something that it doesn't need to be on , then take the Vac apart and spray it directly on the the coils of the cord winder..A lot of times, that's all they do in the repair shop when they tell you they replaced the cord winder....
Jun 15, 2011 | Electrolux Epic 6500 Vacuum
Does not spray cleaner
It helps to always run hot water in the soap holding tank after you have cleaned the carpet to make sure the soap does not dry inside and clog. Make sure that the dirty tank water filter is clear of debris, I have noticed that if it is clogged it won't spray out solution. Another thing to try is, it usually will always spray out of handheld cleaning attatchment. steve
Jun 06, 2010 | Bissell 1699 ProHeat Clear View Upright...
No water sprays when I press lever on handle
proheat 9300
assuming the water works for the tools
Remove the water tank. You will see 2 red tabbed plastic spray tubes.(where the spray comes out if not clogged) Pinch the clips to remove from the machine. Then you will need to pinch the hose clips to remove the red tabs from the hose. Clean out those red spray nozzles. Next step: have a towel ready and fill the solution tank with water. Put the solution (not water) tank on to where the water tank would go. Place the machine selection knob to rinse/wet only. Now with towel under the hoses that you removed the red tabs. Turn on the machine and pull the trigger to activate the water. You should see water flow out of the hoses that had the red tabs on them. If not, release and pull again the trigger several times. If only 1 hose has water coming out of it then block the one that works and try the process above again to de clog the one that isn't working. Good luck.
Apr 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Wont spray soap
Please look at my other posts for this solution
Aug 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Little Green won't spray the solution. The suction seems to be working fine and the lines are all connected as they should be. What's up and how can I fix it?
I also had the same problem as you.
Try suctioning up a full tank of hot tap water into the collection tank to soften/release a possible kink in the tubing inside of the vacuum hose that carries solution out to the spray tip.
I did this a couple of times and it worked. This info I found on the Bissell website.
Good Luck!
Aug 15, 2008 | Bissell 1425 Little Green ProHeat Handheld...
Bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Nov 06, 2007 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell ProHeat Carpet Steam Cleaner stopped spraying.
The problem was a clogged heating unit which is located in the lower handle. There are two clear hoses going up the inside of the left leg of the lower handle that go to the heater and to the in-line water switch all within the lower handle. I unplugged the metal heating unit water lines and electrical connections (label the connections as you take them apart if you have a hard time remembering things...there were seven connection in all be it water and/or electrical). Removed the heat unit out and then removed the 6 screws holding the heater cover. Inside was a white powdery pasty debris (lime deposit ?) and the water path was clearly blocked in four different places. I cleansed the water trough with a little water and soft toothbrush and several toothpicks then reassembled. If you need new washers go to Orchard or ACE hardware. Take the old rubber washers(they are red) with you for comparison. I didn't need new washers...I just gently cleansed them. I immediately ran clear water through the machine and actually cleaned the carpet with a water rinse only. Will go back and finish the carpet the right way tomorrow. I had only used my machine three times before this happend over a three year period. A friend told me to always rinse it two maybe three times with clear water after using it and before storage. This took me exactly 42 minutes to disassembly and reassemble. Cost savings is several hundred dollars since I have a 5 bdrm house and would need a professional cleaner to do the small dirty traffic lanes all around the house.
Sep 29, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Hoover SteamVac F7411-900 Upright Vacuum Logo
23 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
