No power cut off got no power changed fuse in power lead still not coming on
  • 23 Answers
Get a new power supply / cord. If the light on the TV doesnt even turn orange then its the power supply for sure.
Posted on Apr 18, 2014
Engine cut of when engin get worm in ford falcon 2000
HAVE YOU CHECKED AT ALL WHETHER IS THE FUEL PUMP ITSELF,OR FUEL PRESSURE DROPPED,OR ANY FUEL FILTER
BLOGGED? GOOD LUCK.
Nov 06, 2013 | Cars & Trucks
2002 FORD WINDSTAR SPORT CUT OFF NO SPARK
Remove distributor cup mark position of the distributor rotor start for a second and see if the rotor change position if is not is your timing belt is broken ,if change position check high tension lead from the coil ,rotor,and high tension leads ,coil positive lead and negative. check fuse .
Sep 20, 2012 | 2000 Hyundai Sonata
98 grand cherokee asd relay blowing fuse
The fuse it doing it's job, you have a short ( Wire that is connected to a ground, that draws too much power )
If you have an electrical schematic ( Repair manual ) find out which wires are connected to that fuse and check them for any chaffing, cuts, unnesassary twists, or corrosion.
If you have a ohm-meter, isolate the system ( by disconnecting the fuse, and other connections. Then check for any resistance on wires that should not be connected ( because you disconnected them ) by having one Lead on the wire's connector and the other meter-lead on your car's frame. A good wire will not have continuity if it is isolated.
Apr 10, 2010 | 1998 Jeep Grand Cherokee
CANT SEEM TO SAVE MY RADIO STATIONS EVRY TIME I TURN OFF MY CAR THE STATIONS ERASE.
there is a memory power lead (usually yellow) that must be hooked up to constant power. find a circuit in the car that doesn't cut off with the switch and hook the memory power lead to that. if the memory lead is properly attached, and has power even with the switch off, then the problem is internal to the radio and will have to be repaired. be aware, there is usually a fuse in the power lead to the memory, check the fuse also.
Aug 20, 2009 | Alpine CDA-9833 CD Player
The hot feed wire for fuel tank where does it come from and how many volts should it read
1995 chevy 1500 pickup. no power to fuel pump. possible wires got cut.need fuel pump wire diag to trace.thank you.
May 10, 2009 | Chevrolet C1500 Cars & Trucks
Nilfisk c120 vacuum - no power
The fuse is part of the motor so is not something that can be changed. Make sure that there isn't a break in your power lead at the plug.
Mar 15, 2009 | Vacuums
The Oven won't heat up
the thermal cut off located on the back of the oven has probably tripped,common problem. replace thermal cut off.
Dec 19, 2008 | Whirlpool RBS245PDS Electric Single Oven
Televison & Video Logo
Top Televison & Video Experts
