Question about Canon PC-890 Black and White Copier
Canon PC890 ADF will not work
ADF unit will not pick up orignals as it seems to not switch on
2 Suggested Answers
hamzaskilltd
  • 316 Answers
SOURCE: CANON PC890 EO
fixing overheating
Posted on Jun 06, 2010
E-000711-0001 in canon ir 3300 xerox
The connector has poor connection. The ADF controller PCB is faulty. The finisher controller PCB is faulty. The DA unit PCB is faulty. The card reader PCB is faulty.
Connector, ADF controller PCB Is the interface cable between the ADF controller PCB an the reader controller PCB normal? NO: Correct the cable. YES: Replace the ADF controller PCB.
Dec 31, 2017 | Canon Office Equipment & Supplies
Doc feeder jam error on HP laserjet M1522nf continuesly also due to that i am unable to scan and also its showing that "Device is busy try again later"
Open adf cover, remove adf pick up unit, two sensor located in it 1. paper leading edge sensor, located upper portion of the unit.2. paper out sensor located back side of the adf pick up unit. Carefully open this unit your will easily find out the sensor location..
Sep 13, 2011 | HP LaserJet M1522nf Multifunction Printer...
HP Officejet Pro LP 7880 feeder does not work, how to fix it?
Step one: Check the paper in the ADF The condition of the paper or the amount of paper loaded in the ADF might prevent the ADF from picking it up and feeding it through the product.
  1. Make sure that no more than 50 sheets of paper are in the ADF input tray.
  2. Make sure the original is not photo paper or carbon paper. These types of originals must be loaded on the scanner glass.
  3. Make sure the original document that is loaded in the ADF meets the following criteria:
    • Free from curls, folds, creases, and tears
    • Does not have staples or clips attached
Step two: Make sure the ADF pick assembly is in good working condition
  1. Remove the document feeder and open the ADF cover.
  2. While lifting the blue-green lever, carefully rotate the pick assembly toward the open ADF cover until it stops.
  3. Examine the pick assembly.
    • Make sure the bottom roller is held firmly in place by the two-catch, which is located to the left and the right of the roller.
    • Make sure the stack stopper, which is located between the top and bottom rollers, fits within the double slots just above the bottom roller. The stack stopper should move freely within the double slots to flow up and down when the whole pick assembly is lifted and lowered into position.
  4. Return the pick assembly to its original position.
  5. When the product is turned on, the top roller will reset to its original position above the separator pad. There will be a gap between the separator pad and the top roller.
  6. If there is no gap between the ADF top roller and the separator pad, press the Power button to turn off the product.
  7. Wait three to five seconds and then press the Power button to turn the product on. The ADF rollers should reset to the correct positions.
  8. Close the ADF cover and replace the document feeder.
Step three: Clean the rollers and separator pad
  3. Lightly dampen a clean, lint-free cloth with distilled water, and then squeeze any excess liquid from it.
  4. Use the damp cloth to wipe any residue off the rollers and the separator pad. If the residue does not come off using distilled water, use isopropyl (rubbing) alcohol on the cloth instead.
  5. Return the pick assembly to its original position.
  6. Close the ADF cover and replace the document feeder.
Step four: Detaching and re-attaching the ADF pick roller assembly If the ADF pick assembly is detached or not connected properly, follow the steps below to resolve the issue. If the ADF pick assembly works well, do not perform these steps.
  1. Press the Power button to turn off the All-in-One.
  2. Remove the document feeder and open the ADF cover.
  3. Press the blue-green ADF-release button to release the ADF rollers from the pick assembly as shown in the figure below (the red arrow is pointing to the ADF release button).
  4. Re-attach the ADF pick rollers by placing the rollers into the roller slot of the ADF pick assembly as shown in the figure below. The red arrows show the gears on the ADF pick assembly aligned on one side. The yellow arrows point to the two-catch notch.
  5. Once the rollers are placed on the two-catch notch, push them in, so that the two-catch clicks into place. The photo below shows a correctly installed ADF pick assembly.
  6. Close the ADF assembly and cover.
  7. Turn the product on and make a copy with the ADF to check that the pick assembly works.
Jul 16, 2010 | HP Officejet Pro L7680 All-In-One Printer
Canon Imageclass D880 automatic document feeder problems
Clean the ADF rollers and pad with alcohol.
Check to see if your ADF has done over 90 000 copies and if it has, change the ADF pick up assembly only.
Good Luck
Oct 19, 2009 | Canon imageCLASS D880 All-In-One Laser...
I need parts exploded view for adf or just part numbers for all rollers in adf
FM2 - 0015 - 000 - SEPARATION ROLLER UNIT
FC5 - 0009 - 000 - ROLLER, PICK-UP
These next three part go together:
FL2 - 0006 - 000 1 PAD MOUNT UNIT
FC5 - 0042 - 000 1 PAD, RUBBER
FC5 - 0044 - 000 1 PAD, SPONGE
Aug 04, 2009 | Canon imageCLASS D880 All-In-One Laser...
CANON 4050 XEROX MACHINE
my xerox machine canon 4050 shown an eroor(E020)...we cant able to take copier
Oct 16, 2008 | Canon NP 6050 Copier
Canon PC 1061 ADF Error
Hello, you should open the ADF and try cleaning pick-up rollers + separation pad with alcohol ( some chemicals products works best but i can t remmember what kind of product it is ).
Regards, Mug
Oct 06, 2008 | Canon PC1061 Copier
Canon Pixma MP780 Fax Problem (horizontal line)
Solution is here: http://www.fixya.com/support/t136826-printer_problem
Mar 05, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PC-890 Black and White Copier Logo
21 people viewed this question
old marine
old marine
