Question about Whirlpool Duet GHW9150P Front Load Washer
Drum has dropped about an inch
I"ve had a Duet for about 3 yrs. The drum drops and the washer stops. I can pull it back up into place and it will work for a few more loads and then the same thing happens. It has a new boot.
  • curtandrache Jun 19, 2009
    How do I get into the machine and wahere do I look for the part?
  • 490 Answers
Sounds like the stabilizer arms that suspend the drum are broken or have come off you should be able to fix it yourself if you can figure out how to get into the machine i think you go from the bottom or there will be a panel to unbolt on the back
Posted on Jun 19, 2009
  • marley mcelhinney Jun 22, 2009
    you will either have to lye the machine on its side to get underneath it or remove the panel on the back if you dont know much bout washers i would take it to be repaired it shouldnt be much
Whirlpool duet washer is putting holes in clothes. The gap between the stainless drum and rubber bellows is about 1/2 inch. Do I need to replace the bellows or the drum?
Tearing or holes if tearing pull the bellow forward and inspect the lip of the front tub for rough spots place your hand in the basket and see if you can push upward looking for play should not have any if so tub bearing worn of holes take a flashlight and inspect the SS basket looking for raised dimples.
Sep 04, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front lading washer, GHW9150PW4
Could be drum bearings gone Quite a big job hence costly with around 3 hours labour plus parts, some models need half drum as the bearings are loaded in here,leak could be door boot seal at 7 yrs old not sure if worthwhile as its about the end of its working life.Good luck
Apr 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Drum suspension failure
The suspension spring of the drum has come off and this means that the drum is hanging off the center.
The drum is hung with spring and shock absorbers and if one side has come off it will be off balanced. The springs are hung from the corners of the BODY FRAME. Check this out, replace spring if the end had broken or also you can use a good plier to extend the spring head to be clipped.( if broken)
Dec 30, 2012 | Asko WL6532XXL Washer
Drum has dropped
the reear bearing housing is worn due to a seized bearing.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do you clean out the baffles filled with lint in the Whirlpool Duet dryer?
To remove the dryer drum baffles on a Whirlpool Duet, follow these steps:
1. UNPLUG the dryer.
2. Remove the top panel of the appliance by removing the screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off.
3. Locate the bolts that hold the baffles in place on the outside perimeter of the drum. There should be 2 for each one.
4. Remove the screws for the baffle and it will come off.
HELPFUL HINTS:
1. Remove ONE baffle at a time so you can use the remaining baffles to turn the drum manually.
2. Drum rotates in a clockwise direction.
3. When removing or reinstalling each baffle, duct taping it place will keep it from flipping around when you get to the last bolt holding it in place. It will also keep it from dropping in the drum when removing, and help you hold it in place to reinstalling.
If you have any questions, please let me know. I hope this helps you.
Feb 07, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My Whirlpool Duet Sport Front-Loading washer stopped working. This morning it gave an F-25 error. We've unplugged it, plugged it back in, and I tried draining it but the drum seems like it's caught on...
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.htm
These are the fault codes for whirpool. The noise problem is what is bothering me.You can pull the bottom front panel, three screws and see if you have a problem with the wiring harness to the motor, also remove the clean out filter on the water pump and clean that out,(large 3 to 4inch diameter white plastic screw almost dead center and to the left of the pump motor). I would also pull remove the backing plate and check where the drum pulley attaches to the shaft, see if it is broken or makes noise as you turn it. You may see water or brown streaks coming from the bottom of the main bearing shaft assembly, This is a major repair. l would recommend you have a technician check this out, you may have a bad main bearing assembly, bad motor, or bad pump (unlikely) but you need a technician for most of these. I have also seen a sock between the inner and outer drum, causing the drum not to spin up to speed. Good Luck, Appliance Specialists
Dec 14, 2009 | Refrigerators
How to replace the belt on a whirlpool duet washer
To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and remove the rear panel.
2. Place the drive belt on the drive motor pulley with the ribbed side on the drive motor pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet Sport Washer Banging During Spin Cycle
If the the drum feels loose in any way, there are three possible reasons:
1. The pulley nut has come loose. (easily repairable from the rear)
2. The bearing is bad (part of the rear tub).
3. The spinner has come loose from the basket (what you describe)
In cases 2 and 3, the entire drum/tub assembly will have to be removed, disassembled and repaired/replaced.
Check your owners manual for possible limited warranty. Contact Whirlpool for potential warranty repair concessions for case 3 if not covered under limited warranty.
Regards
reg501..The FixYa Team
Jun 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Drum dropped
Are you able to lift the inner drum back into position ? If so then the culprit is most likely within the trunnion or spin bearing assemblies. Dis-assembly can be tricky but it is possible to do this yourself.
Jan 01, 2008 | Frigidaire FWS1339A Top Load Washer
Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Sep 12, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
219 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
