Question about Vehicle Parts & Accessories
Dodge neon water boiling in the engine - Vehicle Parts & Accessories
  • Jesse Gerardo
    Jesse Gerardo Apr 18, 2014
    bad head gasket...exhaust gasses entering engine and causing presuure into cooling system
    New Friend:
  • 22 Answers
Replace head gasket.
Posted on Apr 18, 2014
Gurgling when engine is turned off
2005 Grand Caravan 2 Problems may be connected - DodgeForum.com
dodgeforum.com/.../dodge-caravan/328382-2005-grand-caravan-2-prob...
Jun 12, 2012 - Vehicle: 2005 Dodge Grand Caravan ... I noticed last week that when Ishut off the engine I could hear water bubbling on my side of the van. coolant vanishing and gurgling
Jul 20, 2013
coolant leaking into heater core?
May 13, 2009
More results from dodgeforum.com
chrysler - Bubbling sound from the cooliant area when I turn ...
mechanics.stackexchange.com/.../bubbling-sound-from-the-cooliant-area...
Aug 13, 2014 - I hear this bubbling sound when I turn the engine off. It occasionally ... When the engine is hot and the coolant is boiling, open your hood and have a look around. DO NOT try ... 2005 chrysler neon clunking noise from front end.Missing: dodge
Mystery of the Gurgling Heater Core - YouTube
? 7:04
https://www.youtube.com/watch?v=db2nR0EMOIs
Dec 28, 2015 | 2005 Dodge Grand Caravan
95 neon overheating. I can see coolant reservior is boiling and smoking. 3 months ago replaced water pump and thermostat. Whats wrong?
did you flush the system before replacing pump and thermostat? Check also the temp sending unit
Feb 19, 2014 | 1995 Dodge Neon
My 2004 dodge neon is over heating, i replaced the radiator and the thermostat. It is still overheating, can you help me figure out the problem?
i had this same problem with a 2004 dodge stratus. turned out to be mixed coolants. check to make sure that the thermostat is opening and closing properly. you can do this by dropping the thermostat into boiling water. if it opens its not that. could also be the water pump, to check this look for a slow drip of coolant coming from the water pump. water pump has what is called a weep hole and when it goes bad coolant will drip from the weep hole.
Oct 27, 2013 | 2000 Plymouth Neon
I have a chrysler neon 2l 2001 model and I can hear the water in the water tank boiling yet the temp gauge shows temp is normal.
What you are hearing may be normal.
There may be air pockets in the cooling system and you are hearing the coolant moving around in the system. Kind of like a coffee pot.
As the thermostat opens at 195 degrees the coolant expands and contracts.
Make sure the system is full of coolant.
Feb 14, 2013 | 2000 Dodge Neon
I have 1996 dodge neon. temp gauge needle goes to hot. i have replaced the radiator cap, thermostate,fan relay switch,drained and refilled coolant, and a oil change, and temperture sensor. when i turn on...
Have you checked out the water pump? Most of the time, you can feel movement in the /head shaft area before it fails. Water pumps usually go slowly, pumping less and less water (making the engine run hotter). The also get noisy when they start to fail.
Jul 01, 2011 | Dodge Neon Cars & Trucks
Need to access 96' Dodge neon water pump to replace it. Need to see engine diagram where water pump is located
the water pump is behind the plastic covers on the right side of engine requires removing the timing belt to replace water pump
Jul 16, 2010 | 1996 Dodge Neon
Boiling overfill, however temperature gauge not over heating no water in oil. temperature gauge starts at cool then climbs to middle but does not continue to rise however when turning car off you can here...
you need to check your upper and lower rad hoses also your thermostat if in doubt take to a reputable Rad shop and have them look at it threy are usually very good with most rad and overheating problems
Dec 25, 2009 | 1995 Dodge Neon
My 2000 neon is overheating. has 60 thousand on motor. new water pump flushed radiator new thermostat. runs perfect. till about twenty miles or so down the road then overheats and boils.. cracked head?
It maybe a cracked head or head gasket or cracked block. Ask your friends for help (those with mechanical abilities) or take it to a shop. Make sure you don;t get water/ antifreeze in the oil or your whole engine will be toast.
Pull the spark plugs. the one with the cleaner/ whiter insulator is probably the bad cylinder.
Hope this helps.
Aug 09, 2009 | 2000 Dodge Neon
2001 dodge neon dohc engine 2.0 radiater cracked inside a/t oil passage and mixed a/t oil and coolant . after replacing radiater I could not bleeding air.because before thermostat opining,coolant is...
Ok well there are two issues here the boiling and the potential for the transmission to be harmed by the contamination of the tranny fluid by antifreeze. First A/T fluid is not going to harm the coolant system in the least, however antifreeze in the trans. fluid will harm the automatic transmission get the tranny flushed as soon as possible , Change out the thermostat then refill radiator using 50% water 50 % antifreeze ( premixed in container) fill radiator then run the car without radiator cap add coolant as needed, put you radiator cap on and wait 5 - 10 minutes until car comes up to operatimg temp. you must observe the engine to make sure the electric radiator fan comes on after the car runs for at least ten minutes if it does not the problem is the usually the radiator fan relay or the fan coolant temperature sensor last in rare cases the fan itself. As for the air bleed usually letting the car run with the radiator cap off for ten to fifteen minutes will do it just make sure you don't remove the radiator cap when the car is hot 2nd degree burns usually hurt.
Jul 14, 2009 | 2001 Dodge Neon
Car is still overheating after new thermostat, new housing.....
bleed air out cooling system. put half antifreeze and half water .if you got too much water .it willl cause engine to over heat. antifreeze raise boiling point .220 degrees it wont boil away . water will evaporate 212 degrees.it will boil away .causing low coolant problems and over heating.
May 01, 2009 | 1997 Dodge Neon
Vehicle Parts & Accessories Logo
14 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
