Question about Boating
Air rifle I have been left with an air rifle,I don't need it so how do I go about selling it as some sites will not allow them?
Can anyone help me to identify an BSA .22 Air Rifle please?
This site would not have this type of information. Sorry.
Oct 13, 2016 | BSA Optics
I have a BSA point 22 carbine air weapon circa 1990. Could you tell me what the name of the carbine is?
Hello Jean
It is likely to be a BSA Meteor or a BSA Airsporter. I am from Birmingham UK and owned one.
Here are a number of links for you which will help identification. I will put the Google link at the very bottom of the post which lists a lot more info. Write back as a COMMENT below my post if you need any further help. I am one of the air weapon experts.
  • 1990's Air Shot Corp./BSA Catalog, Vintage Gun Catalogs www.vintageguncatalogs.com/product_info.php?products_id=57 Circa 1990 Air Shot Corp./BSA Catalog,8-1/2" x 11" with 6 pages Content: ... Air Gun Catalogs. Air Arms; Beeman; Benjamin; Brno; BSA; Crosman; Daisy; Feinwerkbau ...
  • History & Ethos ' BSA Guns - BSA Air Rifles bsaguns.co.uk/about/history.aspx BSA Guns; History & Ethos; Production ... 1962 Introduction of Merlin air rifle; 1962 Introduction of Armatic .22 self ... and Airsporter Carbine air rifles; 1990 ...
  • BSA - John Knibbs International Ltd - Airgun Spares www.airgunspares.com/store/content/87/BSA Superstar .22 : 1990 - 2004: R22: R - 10 MK1 .22 : R77: R - 10 MK1 .177 : ... BSA Standard No2 Air Rifle .22: 1936 - 1939 : T: Ralock Self Loading Sporting Rifle .22 ...
  • BSA .22 Air Rifles and Pellets ' Wonderland Models https://www.wonderlandmodels.com/bb-air-guns/air-guns/rifles/bsa BSA .22 Air Rifles and Pellets. Wonderland Models are an Online Model Shop specialising in BSA .22 Air Rifles and Pellets and ... BSA Rifles Meteor Evo Air Rifle.
  • JC Militaria ' Air Weapons www.jcmilitaria.com/air_weapons.asp?Start=10 At JC Militaria we stock a number of Air Weapons. ... 22 Calibre Bolt Action Single Shot Air Rifle ... BSA launched a centenary air rifle to ...
  • BSA Air Rifle Combinations - The Airgun Centre https://www.theairguncentre.com/rifle-combinations/bsa BSA Guns are at the cutting edge of Air Rifle design and manufacturing and have a history going back over 150 years.
  • Blue Book of Airgun Values - BSA GUNS (U.K.), LTD. RIFLES ... bluebookofgunvalues.com/Airgun_Values/Airgun_Manufacturer_Models... ... LTD. RIFLES: MODIFIED REAR/UNDER LEVER COCKING airgun ... RIFLES: MODIFIED REAR/UNDER LEVER COCKING . ... faucet tap loading, Marked: "THE BSA AIR RIFLE ...
  • http://www.bing.com/search?q=BSA+22+air+rifle+circa+1990&FORM=HDRSC1
    Jul 05, 2016 | BSA Optics
    Where can i purchase the threaded part that goes into the gun and punctures the co2 this is my second request
    Direct, eBay possibly or direct from Daisy.
  • Daisy Outdoor Products - Official Site www.daisy.com CO2; Optics; Accessories; Collectibles; Info. ... Winchester Air Rifles ' Where to Buy ... © 2013 Daisy® Outdoor Products ...
  • daisy bb gun parts ' eBay www.ebay.ca > Search > daisy bb gun parts Find great deals on eBay for daisy bb gun parts and daisy ... Vintage Daisy Powerline Model 44 Co2 Innertube Nut BB Gun ... New listing DAISY AIR RIFLES AND BB GUNS ...
  • Air Gun Replacement Parts - AirGun Warehouse www.airgunwarehouseinc.com/repa.html Air Guns. Air Rifles; Air Pistols; BB Guns; ... Whether you are looking for Daisy BB gun parts or you ... we carry a wide range of air gun replacement parts that let ...
  • Apr 01, 2016 | Daisy BB Gun Pistol CO2 BB Gun Repeater...
    How to sight in crosman extreme g1 pellet rifle scope
    You would sight in an air rifle scope in the same manner as any other standard scope that you might find on a rifle:
    You want to secure the rifle as best you can with the sights pointed towards a target, which should be set at the desired distance.
    Reduce the error of your sight adjustments either by mounting the rifle in a gun mount or simply resting the stock (not the barrel!) on a solid surface such as a table.
    Make sure that the weight of the rifle is carefully supported and the **** is firmly pressed into your shoulder. Looking through the sights, aim at the very center of the target (which for your purposes can be as simple as a piece of paper with a dot drawn in the middle).
    Take time to ensure a careful shot, and be sure to avoid any shaking, utilizing the support of the mount/table (try resting the fore-grip of the stock on a roll of paper towels if you're having trouble keeping the rifle steady).
    Once you are confident with the placement of the cross-hairs over the center of the target, gently squeeze (don't pull) the trigger.
    Determine where the pellet struck the target, and adjust the scope accordingly; while every scope is a little different, the same basic principles for adjustment apply. Unscrew the caps on the top and side of the scope, and carefully read the markings on the adjustment dials.
    If the pellet struck low, twist the dial on the top of the scope 'up' (the markings should specify clockwise/counter), and if the pellet struck high, twist in the opposite direction. If the pellet struck to the left or right, follow the same procedure for the dial on the side of the scope.
    If the pellet struck low and to the side, make the vertical (up/down) adjustments first, repeat the shot, and only move on to make adjustments left/right once the pellet strikes in vertical alignment with the center of the target.
    Take your time, and adjust in increments of only 2-3 clicks to start. Repeat the procedure until the pellets are striking consistently in the center of the target (if you're having a hard time remembering which shot went where, replace the target and continue.
    Once you are satisfied with placement of your shot groupings on the targets, replace the dial covers on the scope.
    Tips and Notes:
    - In order to maintain the accuracy of your rifle, try to avoid resting the rifle on its scope and try to prevent the barrel from contact.
    - Take note of your rifle's range, and be aware that the further away you place the target, the less consistent your results will be.
    - Be realistic; don't attempt to sight in an air rifle at 50 yards. Remember that even with a rifle that has been professionally sighted, good results still come down to the accuracy of the shooter.
    -Sight in your rifle at a range where you are confident in your own abilities; start with a closer target and only move back (i.e. sight in at a greater distance) if necessary.
    Further Instruction:
    http://www.chuckhawks.com/sight-in_rifle.htm
    http://www.youtube.com/watch?v=lLirsAFpsfE
    May 05, 2011 | Sport & Outdoor - Others
    After inserting and compressing the CO2 cartridge, the CO2 leaks
    You need to check the rubber o-ring seals both in the plug and there could be another up in the gun where the cartridge end meets the inside. If you have a broken o-ring you should be able to find one that fits at your local hardware store or store that sells air rifles. Hope this helps.
    Jul 12, 2009 | Crosman Phantom .177 Caliber Break Barrel...
    Rifle sitting a long time but brand new won'thold air pressure
    hi
    contact Mac1 out of the US at mac1airgun@att.net.
    He would be of help as he modifies these things and has full parts kits available.
    or chek this link
    www.mac1airgun.com
    they sell you the o-rings or customize your gun to another level .
    or chek some useful sites
    http://www.crosman.com/airguns/service/manuals/crosman-rifles
    http://www.fotolode.com/images/Rapidfirex/crosmanpumpmaster760assembly.jpg
    hope u will b helpfull
    regards
    Jun 12, 2009 | Crosman (4032)
    Air rifle will not pump up
    The cylinder needs to be oiled. Its the same concept as a car jack.
    Go to a gun store or a Dicks/Bass Pro/Wall mart for the oil.
    Mar 31, 2009 | Dmm Benjamin Air Rifle
    Benjamin Air Rifle Model 342 not building pump pressure
    Springs tend to loose their performance after a few years is air rifles. Check also the seal/o rings on the piston rod and the blow hole. I found waxing it with Vaseline makes it last longer and seals more.
    Mar 27, 2009 | Dmm Benjamin Air Rifle
    How do u reset a rifle scope
    Hi type into Google, Zeroing a Telescopic Rifle site, Shooters have there own ways of doing it but you will find what is best for you depending on what type of rifle you will be using. If you are fitting it to a Air Rifle. You could Type in Zeroing telescopic site for Air Rifles.
    Hope this helps
    Oct 07, 2008 | Bushnell Sportsman 4x32 Riflescope (4x32...
    Scope
    Follow these steps
    1) Mount your scope.
    2) Use a bean bag or rifle mount and make sure that your rifle doesnt move much from its original position throughout this process.
    3) Aim with the scope and shoot at a large backstop which will allow you to see where your shot lands, where ever that may be, it doesnt matter at this point. Again, make sure your rifle doesnt move much when firing.
    4) With the rifle in the same position, look through the scope and adjust the crosshairs over to where your shot landed.
    5) The scope now sighted in with the rifle. Minimal adjustment may still be required but at least your well within the ball park.
    Happy Shooting
    Nov 13, 2007 | Bushnell Trophy Multi-Reticle Red Dot...
    Boating Logo
    62 people viewed this question
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
