Question about Craftsman Tools & Hardware - Others
Take apart 172.26770
Broke reciprocating rod
The saw quit working. I took it apart & it needed new bearings. I ordered parts & installed.
Need to know model & type # - DeWalt used several different reciprocating mechanisms.
Mar 01, 2015 | Dewalt Saws
How do I take apart a Ridgid R3030 reciprocating saw
scroll down to the bottom of the page on the link, it gives you some dismantling instructions.
Ridgid R3030 One Handed Fuego Reciprocating Saw Parts
you may be able to order your parts here.
RIDGID R3030 Reciprocating Saw Parts
Jan 31, 2015 | Ridgid R3030 Contractor Tool Bag
Blade clamp
i purchased a clarke reciprocating saw, and the first time i tightened the blade it broke, where can i get the parts to fix it
Mar 09, 2014 | Clarke Power Products Electronic...
Sawzall broke in half tearing wires out
Go to www.2helpu.com and you will find a drawing for it. easy to refit.
Dec 25, 2012 | Dewalt DC385B 18v. Cordless Bare...
Broken reciprocating saw blade stuck in saw
Hello, I found a very quick and easy solution to this. Pulling the blade release and shaking, and taking the saw apart, did not work. What worked instead was to simply turn the saw on while pulling the blade release at the same time - when I did that, the piece of stuck saw blade came shooting out. Please be VERY CAREFUL while doing this, making sure you are wearing eye protection and pointing the saw away from others, so that no one gets hurt by the ejecting blade piece. I would also suggest knocking and shaking the saw while holding the blade release before you try this, as another poster suggested, because if the blade piece is big enough it might come out this way, or at least it may help loosen it so that it will easily eject outward when you turn the saw on. Good luck!
Jun 26, 2012 | Ryobi P510 18V Cordless One Variable Speed...
Sawzall runs but wont reciprocate
Seems like the wheel and gear are not hooked up, reopen it and check the reciprocating arm connection is where i would start
Apr 05, 2012 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
Shaft or rod seems to be broken
The gears are stripped internally in the saw...it will need to be repaired..usually there are regional service centers for repair...look for the one closest to you...
heatman101
Jul 26, 2010 | Craftsman 85 reciprocating saw 926770
Tools & Hardware - Others Logo
Top Craftsman Tools & Hardware - Others Experts
Mike
John Trevino
Jay Finke
Jay Finke
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
