Question about Sony Handycam HDR-PJ10 Camcorder
Lcd doesnt turn on, and lens stuck open
I just got my camcorder out for the first time in years, and the LCD will not turn on and the lens cover is stuck open. When I flip open the LCD, the lens makes some clicks until the camera automatically shuts off. i have charged the camera for about 10 minutes, so I know it has enough charge to open.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 103 Answers
did you took off the battery during the time you didn't use the cam, or was it mounted on it ?
if it was mounted on it, it is most certainly dammaged and doesn't keep enought charge. did you try with the charging cable plugged?
Posted on May 18, 2014
SOURCE: sony handycam lcd sez 'cover not open'
Had same issue. Appeared to solve it by turning off USB Streaming when not connected to pc.
Posted on Aug 18, 2007
SOURCE: Records audio but no video
What is the ccd base assumbly?
Posted on Jan 01, 2008
ctf1800
  • 4402 Answers
SOURCE: DCR-HC96 Automatic Lens Cover won't open
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Feb 22, 2008
welcomejee
  • 10594 Answers
SOURCE: DCR-HC19E Camcorder LCD Screen not Working
DCR-HC19E has cracked/ broken flexible cable, connecting LCD and main camera board.
Posted on Jul 25, 2008
  • 21 Answers
SOURCE: I have a Sony Handycam DCR-HC42.
ccd doesnt good
Posted on Sep 22, 2009
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
May 25, 2010 | Sony HDR-XR200V High Definition AVCHD...
When recording, no picture thru viewfinder or lcd panel. Records sound. Was working fine, just started this, and the lens cap is off. Any assistance greatly appreciated.
It could be either aperture is stuck or ccd imager chip is defective in your camcorder that will be replaced.
In bright light, look into camera lens, turn ON in camera mode and observe does aperture open like an eye?
If you notice some thing opens right in center of camcorder lens then aperture is working and ccd imager chip is bad that will be replaced.
Let me know model number of your Sony camcorder to provide you ccd imager part number info.
Thanks.
Dec 09, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
E6100 flashing on lcd screen
The E61 is an internal error code shown when the motor is not moving. I will look up the specific details when I get to the shop and update this with the required fix.
Dan
Oct 15, 2009 | Sony DCR-HC18E Mini DV Digital Camcorder
Hi I have DRC-SR200 camcoder, bought one year ago. Issue is lens cover is not opening. On the LCD display there is a message "lens cover not fully open. Turn off and on". I tried that but no use. Went...
Hi, perform the following steps to get this issue resolvbed... 1. Check whether the lens cover is opened 2. check whether the battery is fully charged. If the battery is not fullly charged, connect the Camcorder to the wall outlet using the sipplied AC adaptor. 3. Then, try resetting the Camcorder by pressing the RESET button using a sharp-pointed object while the Camcorder is turned ON. 4. If the issue still persists, turn OFF the Camcorder; then remove the battery pack and discinnect the Ac adaptor from the Camcorder; slide the POWER switch to the ON position for 1 minute. Then, connect the AC Adaptor tro the wall outlet and cjeck whether it helps.
If the issue still persists, service of the unit may require. contact the manufacturer of the Camcorder to get ut serviced.
Jul 10, 2009 | Sony Handycam HDR-HC1E HDV Digital...
Panasonic SD H80 Lens cover
Make sure gas valve is turned on. Make sure spark plug is not soaked. If has has a primer, only prime it about 3 times. No more than 5
Jul 03, 2009 | Panasonic SDR-H40 HDD Camcorder
I have a 3 year old Sony DCR-DVD202E Camcorder which has worked perfectly up until yesterday, when the lens cover refused to open. Other thsn this the camera powers up normally and the LCD screen shows a...
Sounds like the gears are stuck, the motor is bad or that the potmeter is bad. The only way to fix this is that the camera has to be opened. If you are sending it to repair make sure that it is not to costly to fix. Most times spending a hundred extra dollars would buy you a new camera then repairing the old one.
Jun 09, 2008 | Cameras
Replace the ccd base assumbly and check.
Jan 01, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony handycam lcd sez 'cover not open'
maybe you have the wrong type of tape or check and change all of the settings to normal
Jul 01, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony Handycam HDR-PJ10 Camcorder Logo
61 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
