Question about Craftsman Tools & Hardware - Others
Take apart reciprocating saw 172.26770 - Craftsman Tools & Hardware - Others
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: lubrication and maintenance reciprocal saw DeWalt
Before you attempt any of this I would recommend going to Dewaltservicenet.com and see what the inside of this tool looks like. It appears that you need to remove part of the front gearcase to get into the lube. The back e.g. brushes is not that big of a deal. If there is a Service Center near you they have a Max repair rate that they will fix anything on this saw at a preset firm price and if it is less that is what they would charge.
Posted on May 18, 2009
radar001
  • 1051 Answers
SOURCE: locking screw for blade on reciprocating saw
Virtually every manufacturer has a different size thread for the locking (set) screw on their saw. Your best bet is to contact the manufacturer for a replacement.
Posted on Feb 11, 2010
  • 6 Answers
SOURCE: need a switch module for dewalt dw306 reciprocating saw
I had a similar problem with a switch on a Craftmans wire welder that they said was no longer available. I looked at the switch and there was a manufacture number and logo of the manufacturer. I called the manufacturer to see if they still made the switch and the manufacturer sent me a sample of my switch at no cost. Check to see if there is a manufacter name or logo you can look up on the internet and contact them directly and sometimes they will help you out as Sears was no help to me.
Posted on May 04, 2010
  • 204 Answers
SOURCE: how do I take apart a Ridgid R3030 reciprocating saw
scroll down to the bottom of the page on the link, it gives you some dismantling instructions.
Ridgid R3030 One Handed Fuego Reciprocating Saw Parts
you may be able to order your parts here.
RIDGID R3030 Reciprocating Saw Parts
Posted on Jan 31, 2015
Testimonial: "Thanks that did help now I just have to figure out how to unsnap the front housing"
The saw quit working. I took it apart & it needed new bearings. I ordered parts & installed.
Need to know model & type # - DeWalt used several different reciprocating mechanisms.
Mar 01, 2015 | Dewalt Saws
How do I take apart a Ridgid R3030 reciprocating saw
Jan 31, 2015 | Ridgid R3030 Contractor Tool Bag
I have a dw307 reciprocating saw that runs for 10 seconds and stops. Any ideas?
Check the set of tangs that the battery contacts. That is actually the bottom of the switch. The tangs can become spread apart or can also overheat and break off causing you to not get full battery contact. Common problem on these tools.
Jul 15, 2012 | Dewalt DW307 Reciprocating Saw
Sawzall runs but wont reciprocate
Seems like the wheel and gear are not hooked up, reopen it and check the reciprocating arm connection is where i would start
Apr 05, 2012 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
I have Dewalt DW309k .was working fine all of a sudden in the middle of the job it just stoped working.nothing is binding or jammed .I though it was the electricity breaker however all the other tools...
It could be a bad on off switch. You have to take it apart and check the switch whith a ome meter. Also check the power cord where it goes in the saw for voltage. While it is apart make sure you can spin the motor by hand. Also check the brushes on the motor they should be under screw caps.
Mar 11, 2011 | Dewalt DW309K Factory Reconditioned...
Need replacement seal gasket for sears reciprocating saw 172.2677
Check for Sears parts online or see if Black & Decker has a similar part.
May 19, 2009 | Craftsman 8.0 amp Reciprocating Saw
Reciprocating saw stops reciprocating
your missing a tooth on a large round gear in the gearbox.
when the gear on the engine rotates into the position where the little engine gear spins because there is no tooth to come into contact with the engine runs but the gearbox doesnt spin, hence no reciprocation, but engine runs.
if you bump the blade it will start going again, but when you cut it will stop offasionally in mid cut. you can repair this but stop using it the engine gear will be destroyed otherwise
I have a dewalt dw303 that you can use for parts, I need a new trigger or something the motor is dead and I found a new saw. go to craigslist.org, rochester ny tools section and look for dewalt dw303 that is my listing. for ten bucks ill sell you all the gears you need. i think it is close to the same model, i am sure it is the same gearbox.
try opening your gearbox, im positive that is what is wrong.
Mar 18, 2009 | Dewalt Heavy Duty Reciprocating Saw Kit
Tools & Hardware - Others Logo
24 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
