Question about Intel 865G Motherboard
No display problem for intel D865GSA board
At the time of formatting display gone and ram changed but no display on screen. If ram is removed from slot 3 beep sounds are hearing. When power on the pc after 3-5 sec no display is showing on monitor. Reply plz.... Thanks alot.
    Master:
  • Intel Master
  • 752 Answers
What are you formatting ? Have you changed the RAM. Does tour system work in its original configuration ? You do not say what the pattern of the beeps is. Before the display disappears, is there a message sent to the screen ?
From the manual
http://download.intel.com/support/motherboards/desktop/d865gsa/sb/d5600601us.pdf
Whenever a recoverable error occurs during POST, the BIOS displays an error message
describing the problem (see Table 53). The BIOS also issues a beep code (one long
tone followed by two short tones) during POST if the video configuration fails (a faulty
video card or no card installed) or if an external ROM module does not properly
checksum to zero.
An external ROM module (for example, a video BIOS) can also issue audible errors,
usually consisting of one long tone followed by a series of short tones. For more
information on the beep codes issued, check the documentation for that external
device.
There are several POST routines that issue a POST terminal error and shut down the
system if they fail. Before shutting down the system, the terminal-error handler issues
a beep code signifying the test point error, writes the error to I/O port 80h, attempts
to initialize the video and writes the error in the upper left corner of the screen (using
both monochrome and color adapters).
If POST completes normally, the BIOS issues one short beep before passing control to
the operating system.
18.April.2014
18.April.2014
Posted on Apr 18, 2014
SOURCE: display problem in pentium mother board!
MODEL NO.--INTEL 845 GVRS. problem is --- power led is on but no display and no beep sound. SMBS, RAM ,, PROCESSER, & HD Are all ok. Pls. tell me how can i slove my problem?
Posted on Mar 01, 2008
  • 135 Answers
SOURCE: No Dispay, No Beep
Try leaving it off but with power to it (should see a small green LED on Mobo) for about 30 minutes or more.
After this time try starting it with RAM installed of course!
If this doesn't work your Motherboard is dead.
Posted on Feb 17, 2009
swufabuda
  • 219 Answers
SOURCE: D865GSA intel mother board supports DDR1 or DDR2 ram
Straight from intels web site...
Two 184-pin DDR SDRAM Dual Inline Memory Module (DIMM) sockets Support for DDR 400, DDR 333, and DDR 266 Support for up to 2GB of system memory
Posted on Mar 09, 2009
leecom72
  • 4806 Answers
SOURCE: Intel DG31PR Booting Problem.
Try resetting the bios by removing the power cord from the back of the machine and removing the battery for an hour periodically hitting the on/off button to dispel and residual power, then try again.
post back please.
Good luck and thanks for using FixYa!!
Posted on Apr 23, 2009
the_fire
  • 432 Answers
SOURCE: intel Mother Board D815 Display Problem
If this is onboard graphics then it sounds like the onboard graphics card has died or gone so best option if it has a graphics card slot ie AGP or PCI Express then to get a dedicated graphics card and that should do the trick.
If not then there is something more sinsiter that is wrong and will be easier to get a replacement motherboard ( the exact same one or one that is similiar that will support the RAM and Processor you currently have )
Posted on Apr 28, 2009
Booting issue with intel D865GSA
First remove the hard disk and see whether you have boot error if you have boot error insert the os cd in to drive and boot from the cd if it works fine you have a problem with the hard disk to clear the hard disk problem use a desktop computer and insert the hard disk as slave in the desk top and boot the desktop with the original drive then right click my computer click mange then disk management and find the laptop hard disk the delete all the part ion in the laptop disk then switch off the desk top and insert the hard disk in the laptop and reload the OS
Feb 14, 2012 | Intel D865GSA (BOXD865GSAL) Motherboard
Dell computer makes a beeping sound when turned on and screen is black
Hi daisy jean,
The beeping sounds you hear are error code beeps which are associated with problem devices installed in your computer. The most common problem component is the RAM memory which slots into the motherboard inside your computer. It is often caused by static on the RAM chips and simply removing the RAM and spraying it with an anti-static electronic aerosol spray will often solve the problem.
The second most common cause for beeps when turning on your PC is
due to a faulty display card. If your PC has an on-board display card(this is the card where you plug your screen in), you will have to buy an add-on PCI-E display card to replace the faulty on-board display card.
Let me know if you need any clarification.
Best wishes,
Graemevm
Jan 23, 2012 | Dell Computers & Internet
Every thing is working fine but no display as i changed the display & also checked the same display on another set it is working ok changed display ic but still same problem
Power off your computer and remove the smps 24 pin connector to the motherboard and short the green and black pin and see if the SMPS is working if not replace the smps.
Remove memory from the memory slot and switch on the computer if you hear beeps clean the memory or change it with new one that fixes the memory slot
If no beeps by removing the memory then remove the processor fan and clean it with soft cloth and apply thin layer of heat sink compound and switch on the computer
If you still not hear the beeps then change the processor
If still no beeps take the motherboard to a chip level Technion the secondary power supply or the clock,reset etc in the mother board has gone wrong or not producing them
Apr 01, 2011 | Computers & Internet
System has got 512 DDR 400. Can I increase the ram capacity, as the system is working very slow. Upto what capacity the ram can be increased. Ravi
Depends which version of their board you have, I will list them here so you can just check your board and reference the right one:
Intel Desktop Board D865GLC - 4GB maximum Ram
Intel Desktop Board D865GSA - 2GB maximum Ram
Intel Desktop Board D865GLCLK - 4GB maximum Ram
If you only have 512MB Ram at this point then you definately will see huge performance increases if you take it up to at least 2GB and if you can take it to 4GB (especially since these boards only have onboard video instead of graphics card)
** If you found this information helpfuil please leave feedback to help us help others **
Feb 19, 2011 | Intel 865G Motherboard
I am using intel desktop motherboard D865GSA but no display this board, i am change the ram,power suppley ,smps, processor. this problems mainboard.on the maiboard supply working only 10 sec and shut...
More than likely your on-board video card is bad, buy a PCI video card or an AGP card and replace the video board. when you boot up go into bios and disable on-board bios so the computer will detect the new video card. hope this helps.
Aug 07, 2010 | Intel 865G Motherboard
DISPLAY DRIVER PROBLEM
redownload and install the latest intel graphic driver or display driver from intel support website by selecting your operating system.
the url is:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+865+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D865GSA
May 10, 2010 | Intel D865GSA (BOXD865GSAL) Motherboard
On power up it beeps 3 to 4 times and won't boot up
If there is no display coming on your screen check your computer RAM here is the beep codes for your dell computer i hope this will work for you
Regards
manish
Mar 24, 2010 | Dell Inspiron 530 Desktop Computer...
Pc boots but no display. tried a new video card, still wont work. ram or motherboard?
Hi.
To start the troubleshooting,
Do one thing.
Clear the cmos.
To clear the cmos, remove the battery and the cmos jumper. You will see JCC on the mb and it is attached to pin 1&2
You can Short it to pin 2&3 or remove it completely.
Don't forget to remove the power-cord from the power supply while clearing the cmos. together with the cmos bat & jumper.
After that try a different ram and a different vga card.
At times dust get accumulated in the slot that prevent firm contact with the vga slot or the memory bank.
Use a clean paint-brush and blow away the dust on the card, the mem and also the slot in the mb.
Fix it firmly.
try this
If you need further assitance revert back
Good luck
Uttam
Feb 18, 2010 | Computers & Internet
Intel 865G Motherboard Logo
161 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
