Question about Frigidaire FFBD2406NB Built-In Dishwasher FFBD2406NB
Every now and then it leaks
It leaks only on occaision. This last time a lot. The time before I wasn't sure and was electricuted while cleaning it up. Is it clogging? I made sure the disposal was cleaned out before running. I was also doing laundry so could both be draining water at same time be toomuch and make it leak or not drain. I don't know if leaking only in front or underneath. They also don't include instructions on how to clean the filter.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Look at the bottom inside, there is a drain which can collect too much dirt and then stops up.
Posted on Apr 19, 2014
  • 159 Answers
SOURCE: Garbage Disposal backing up in dishwasher
Most dishwasher have a check valve at the pump to prevent water from backing into the dishwasher. If the pump is electric there is a rubber flat that may be gone or not working properly. If that is the case you need to replace the pump. If the pump is part of the motor assembly then the pump and motor will need to be replaced. One other thing to make sure of is that you have the drain hose looped to the top od the dishwasher and then to the disposal conection. Its called a drain loop and all dishwashers should have it. Good Luck
Posted on Jul 12, 2007
SOURCE: Frigidaire PLD2855RCO Leaking
The gasket at the bottom of the door where air vents in to allow for "drying" gets water splash that differs depending upon what is loaded in front of it. For instance, my dishwasher (Frigidaire PLD2855RFC1) leaks only when a certain spoon or something is loaded in a certain position or a pan is creating too much basksplash. That sort of dynamic simply excapes the repair types in a lot of cases. And the problem leak does not occur when the technicial tests it when the machine is empty.
You need to call your local repair folks and tell them to get on their "support service website" (that only they can get on) and look up Electrolux bulletin DW 071 which speaks to this issue. The offending and poorly designed "gasket" has quietly been redesigned and supposedly fixes this problem. Too bad they don't tell us about it. My serial number fell right in the middle of the units produced with this bad design. I will never again buy a Frigidaire of any type - ever. Nor will I deal with Coos Bay Area Appliance Store again. They all spoon fed me all kinds of accusations that it was installed wrong, unlevel, whatever. None solved my problem. THEY WILL SUFFER REVENUE LOSSES because of this. Good luck to you.
Posted on Dec 20, 2007
NJFIRESTORM
  • 84 Answers
SOURCE: Frigidaire Dishwasher
A common problem with dishwashers is the non-draining machine. If you are having trouble, check to see if the drainpipe and sink trap are clogged. If you still have drainage problems after doing this, check your drain hose to make sure there are no kinks or bends. if the hose looks worn out you can replace the hose pretty inexpensivley. if your have thoughly checked from dishwasher to trap under the sink where your dishwasher should drain to and it seems clear you may have to call in the repair man.
Posted on Jun 20, 2008
SOURCE: dishwasher not draining
I had water at the bottom of my 4 year old plus dishwasher and of course I thought the worst. Did the pump go out, bad impeller, or what else could it be! I started with the easy stuff first and disconnected the drain lines. The drain line runs from the dishwasher to an air gap mounted to my sink, which keeps the drain line from getting an airlock. From the air gap device another larger line runs to the garbage disposal. I used an 8MM wrench to loosen the clamps enough to pull the drain lines off and drained them into a bucket. There really wasn't any resistance to water flow and no real chunks, I was disappointed.
I then took the actual air gap out of the sink by removing a large plastic nut and pulling the devise out from underneath the sink. When I inspected the air gap I saw a wad of hairy, feathery plastic stuff blocking the flow of water. I took the chunk out, reassembled everything and it works like new again.
It is a very easy fix and now even the area under the sink is clean to boot.
Jerry
Posted on Oct 18, 2008
  • 574 Answers
SOURCE: Frigidaire Dishwasher FDB2810LDC1 not draining
Sure its redeemable if you have the time and money. If I understand you correctly when you move the lowewr spray arm the water drains out? If this is the case then more than likely its a pump motor or solenoid. Reason I say this is on the bottom of the spray arm is a impeller and under that is filter and then pump impeller that drains the water. If its not draining but will by hand then its your pump motor or solenoid. When you start the washer then press cancel/drain do you hear anything? Maybe a humming sound. One more thing could be a thermal fuse for the motor. These are usually not resetable its a one time fuse if it blows you have o buy another one.Hope this helps
Posted on Jan 25, 2010
Dishwasher leaking
If its leaking from the front its the seal. Its probably dried out and got a crack in it. You could try to repair it with superglue or something but would be best to get a new one (seal or dishwasher you pick)
Apr 18, 2014 | Frigidaire FFBD2406NB 24" Built-In...
'service engine soon' light
I think that is scan tool only but most mechanics have the scanners these days so it will be a lot cheaper to go to your local mechanic instead of the dealer. It prob wasn't reset last service if the light wasn't on at time of service.
Jul 15, 2012 | 2006 BMW 330i
So my father bought me a new msi A6200 msi notebook. Everything was working fine. So yesterday i set a password on my account. Today i turned on my laptop and my account wasn't on there. Some user...
Hi ebonybesh...
You will need to start your computer in the "Safe Mode", you do this by tapping F8 while the computer is starting up.
Once the computer has started, select "Safe Mode"
Once you are in the safe mode, then you will double left click on "Start">Control Panel>User Accounts>Change an Account.
Now you can change your password,delete the account,etc.
Please take time to rate me
Aug 19, 2011 | Computers & Internet
I've had my grill for a few years and when i turned it on last night, i could barely see the flames and i had both burners on hi. I cleaned (took a wire brush) to where the flames get out and still...
You may have to recheck the tank for full. If you forgot to turn off the tank after the last time you used the grill, the tank could have leaked down. I always keep a spare full tank for just those types of problems. If the tank is full, then the regulator may have a problem. That grill should be able to get over 300 degrees.
Jul 07, 2011 | Weber Genesis Silver A Grill
Hello, I have the stainless steel bottom freezer refrigerator model GFSS6KIXASS. I purchased it 3yrs ago. This morning I noticed that the freezer wasn't working properly. Everything in there was frozen...
A.C.; Can you tell if the fan is operating? If not that could cause the problem, but it is most likely in the defrost system: this might help you troubleshoot which component is bad:
The defrost heater is easy to check with a ohm meter. http://www.acmehowto.com/howto/appliance/freezer/check/defrostheater.php If you have continuity, then it is good.
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html is instructions on how to test the timer.
http://www.acmehowto.com/howto/appliance/refrigerator/check/defrosthermo.php is instruction on how to test the defrost thermostat.
You should also check to make sure the the condenser coils are clean and that air flow is good over it. I.E. the fan is operating, and not a lot of debrie on or around the condenser coils.
Hope this helps.
Jun 16, 2011 | GE Refrigerators
Hi, the Hoover f5915-900 that we have is leaking the clean solution when we are using the attachment. but the leakage seems to be coming from the bottom of machine
With this style of machine there are hoses, or connections to transfer the cleaning solution. these can fail after some time. Stop using the machine, leaking fluid onto the internal parts can become a electricution/fire hazard. take the unit to a service center for repair.
Jan 01, 2010 | Hoover F5906-900 Upright Steam Vacuum
It leaks from under the front door, escpecially when it gets to the rinse cycle. LG LDS5811WW
The Vent Kit behind the lower door panel, upper left corner has a rubber, solonoid stopper. Pressure from the spray arms overcome the rubber as the stopper hardens over time, allowing water to enter into the vent blower assembly. I found my replacement on Sears-Parts for $40 w/ shipping and just ordered it today. Be sure to turn off the breaker to the washer before removing the lower front door panel - 120vac in there, don't want no electricutions.
Oct 16, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Oil light flickers...
replace the oil pressure sending unit
Apr 20, 2009 | 2002 Mitsubishi Galant
Electricution sound w/ clicking noises and no picture
I am having the same exact issues wih the same TV and mine is only 2 years and 6 months old. Please let us know what is going on. Thank you.
Mar 07, 2007 | Zenith R40W46 40" Rear Projection...
Frigidaire FFBD2406NB Built-In Dishwasher FFBD2406NB Logo
75 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
