Question about Kitchen Appliances - Others
Broken blade locking screw for a FS-150PR - Kitchen Appliances - Others
Why can't the screw be tightened?
First of all, the blade has to be seated correctly on the spindle and the screw hand tightened to hold it in place. Next, a locking device such as a screwdriver has to be inserted crosswise between two teeth to prevent the blade from rotating. With the blade locked, the screw can be tightened. Finally, be sure to remove the locking device before operating the saw.
Oct 05, 2015 | Saws
How to unlock hood from outside cable is broken
go up from underneath with a long blades screw driver and trip the hood lock.
Cable broken in drivers compartment? if enough cable grab it with vise grips.
Jul 14, 2014 | Chevrolet Silverado 1500 Cars & Trucks
How to replace the upper cutter on the baby lock? which screws to release the old blade?
I also have a babylock eclipse BLE1DX serger & here's how my book says to do it
to replace the upper cutting blade
1.open the front panel
2.remove the screw holding the upper blade
remove the upper blade
3.position the new blade in the blade slot, replace the screw.as you tighten the screw, hold the blade up in it's highest position
4.close blade cover. close front cover
hope this helps you
good luck
Sep 12, 2011 | Baby Lock Eclipse Serger
Inserting the blade on the Proxxon DS/230E I can't get the top of the blade to tighten no matter what I do. I have bent or broken six blades (so far). I can get the blade in the base, tighten the screw,...
If you haven't watched this video, you may want to check it out, just to make sure that you are following the procedure. From what you have said, you are doing it correctly, but perhaps by watching it, you may catch something that we are missing.
http://www.proxxon.com/eng/html/27088.html
Is it possible that the 3 position head is in the wrong position? I am sorry, but I have never used this peticular scroll saw. Please let me know if you still have a problem with it.
Nov 22, 2010 | Saws
Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
Mar 25, 2010 | Garden
The blade lock is not locking . When you put pressure on the blades they pop off
Most makes of clipper including Oster, Andis, Wahl have a latch which is depressed to release the blades. The latch is commonly situated under the hinge assembly and holds the blade with a simple hook at the tip which catches on the blades.
If the blades will pull off without depressing the latch, chances are the tip has broken off and will require replacement.
Undo the two screws securing the hinge into place and remove both parts, when fitting the new latch make sure the spring ends of the hinge locate through the holes on either side of the latch.
Dec 16, 2009 | Andis Health & Beauty
Reciprocating saw-snapped blade-cannot be removed
What I would try is to spray some WD40 on the pin first and then see if you can find a small screwdriver or punch and try pushing the pin in further to release the broken blade. It doesn't sound as though it is anything major, maybe a burr on the side of the pin or possibly rust or debris. DON"T hit the pin because you might damage it or push it in and never get it back out. Looked at a diagram and it appears that they used roll pins to hold the clamp in place so it might be that one is cracked or mushroomed and you might have to drive them out. I suggest that you go to Searspartsdirect.com and type in your model number to look at the same diagram.
May 26, 2009 | Craftsman 8.0 amp Reciprocating Saw
Blade wont stay in Bosch 1882VS jig saw
ARE YOU USING BOSCH BLADES IF NOT GET SOME THEY ARE MADE A LITTLE DIFFERENT THAN SOME OF THE OTHER BRANDS AND FIT A LITTLE BETTER , IF YOU ARE THEN DO NOT KNOW
Feb 22, 2009 | Bosch 1587AVSK 5.0 - AMP Top Handle Jig...
My printer prints dust particles with the print ducument
Before your printer prints a page a small blade runs across the toner drum to clean it before the next page is printed. If the blade is broken or not functioning then you will get some toner particles on your paper. So you need to get it repaired at the local computer and repair shop. Remember it's just the blade so if they try and add some other stuff tell them no, just fix the blade...Good Luck and let me know if you have any questions. Don't forget to vote this solution with 4 stars before you log out.
Feb 10, 2009 | Kyocera FS-1030D Laser Printer
Kitchen Appliances - Others Logo
370 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
