Question about Philips CDR796 2-Disc CD Recorder
The tray keeps opening & will not close
And the recording tray opens slow
3 Suggested Answers
  • 567 Answers
SOURCE: Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Posted on May 07, 2010
  • 3 Answers
SOURCE: I have a CDX-602 CD Player. I was on a gig the
The gears have probably come out of sync, meaning the tray is riding on the limit switch. You need to remove the deck, dismantle and re-sync the drawer mech. Check the limit switch isnt bent, it's quite flimsy
Posted on Aug 22, 2010
Magnavox ZC320MW8 door stays open
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
God bless you
Sep 27, 2012 | Magnavox ZC320MW8 DVD Recorder Refurbished
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
CD Player Tray keeps opening and closing by it self
This is either caused by the drive belt slipping, the closed sensor being faulty or an obstruction to the tray.
Basically the tray isn't makeing it to or registering as being in the fully closed position.
May 02, 2011 | Tascam CC-222mkIII CD Player / Recorder
I have an RC100H that keeps opening the DVD/CD tray as if it does not read the disc. Even if I have no disc in it the tray opns and stops. The only way to keep the DVD Tray closed it to hit the close...
eject belt propably worn out, does not close lid proper - so ejects back. change of belt solves problem.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 21, 2011 | LG RC199H DVD Recorder/VCR
LG RH1757 (80 GB) DVD Recorder / HDD Recorder Drawer keeps opening Drawer keeps opening and closing and won't read discs! Rassie from Cape Town South Africa
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Mar 16, 2010 | LG RH177 DVD Recorder/HDD Recorder
How do I select the recording speed "SP" mode on my Panasonic DMR-E55 DVD recorder
1 Press [< OPEN/CLOSE] on the main
unit to open the tray and insert a disc.
≥Press the button again to close the tray.
2 Press [W X CH] to select the channel.
To select with the numbered buttons:
3 Press [REC MODE] to select the
recording mode (XP, SP, LP or EP).
4 Press [¥ REC] to start recording.
Recording will take place on open space on disc. Data will not
be overwritten.
≥You cannot change the channel or recording mode during
recording.
≥[RAM] You can change the audio being received by pressing
[AUDIO] during recording. (Does not affect the recording of
audio.)
Feb 02, 2010 | Panasonic DMR-E55 DVD Recorder
DVD TRAY KEEPS ON OPENING AND CLOSING CONTINOUSLY
Hi, I have exactly the same thing. Happened before but went away when I got bored trying to fix it. This time I phoned LG support and they said take it back to Comet (they have bought out their servicing). End of conversation. Polite but firm.
Appalling support via their websites, appalling products. Never again.
Oct 05, 2009 | LG DR787T DVD Recorder
Disc tray keeps opening/closing on DVD recorder
my dvd player sony cinema entertainment system dav-dz111 the tray is opening again after closing
Sep 22, 2009 | Televison & Video
DR6000 display "open"
you may need to replace the whole mechanism as i've had quite a few philips and marantz cd recorders with the same mechanism with exactly the same problem. when you press open/close it will display open or close with no sign of life from the player. this turned out to be a faulty laser unit and the PCB which is underneath the mechanism seems to go the same way which i found out later when i replaced the laser unit. the recorder worked for around 5 minutes then the laser started moving erratically but then would work again for 5 minutes after switching it off & on again. i cured the fault by replacing the PCB aswell. hope this helps?
Aug 24, 2009 | Marantz DR-6000 CD Player
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
Philips CDR796 2-Disc CD Recorder Logo
71 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
