Question about Water Heaters
Halstead 102 combi boiler dhw/ch run for 1second then goes off
    Scholar:
  • 150 Answers
You might try cleaning the flame detector. It sits in the combustion chamber and looks like a small bent nail fixed to the burmer [usually at the rear]. Use a medium emery cloth and make sure that the gas holes around it are clean and clear of debris
Posted on Apr 19, 2014
3 Suggested Answers
  • 30 Answers
SOURCE: combi boiler no DHW
if the boiler fires when the tap is opened then the diverter valve is working ok it must be a blocked plate heat exchanger which is the stainless steel rectangular block inside the boiler connected to the pump and the mains cold water.
it will be blocked on the central heating part probably with black scale. it is possible to clean out but sometimes it is better to just change the plate. but remember to flush the system as well or the same thing will happen.
Posted on Mar 30, 2009
  • 659 Answers
SOURCE: Halstead Finest Gold Combi Boiler water input temp
I know of no limitations on the temperature of the inlet water for any boiler. The warmer the water, the less energy it will take to heat it to desired temp and the colder the water, the more energy it will take. Extreme temps over an extended amout of time in either direction can stress a unit and could possibly, only possibly reduce service time.
Posted on Mar 31, 2009
Hi my baxi 105he dhw has stopped heating the water flow rate is ok,when i try ch the temp led,s rapidly rise up to 80 degrees then the boiler shuts down
Indicates low water flow. possibly bad electrical connection to flow detector in dhw pipe or seized dector in pipe or blocked up heat exchanger. certainly a blockage somewhere in the pipes
Oct 11, 2017 | Water Water Heaters
Combi Boiler gives CH but not HW
Combi boilers have many moving parts compared to conventional models so must be serviced annually to prevent breakdowns.
Your boiler most likely has one of four problems:-
1. When the receiver for the wireless thermostat was fitted, other wiring was loosened and has come adrift. It's a possibility, but in my experience unlikely as the wiring involved isn't anything to do with HW supply..
2. During receiver fitting the pcb suffered a static electricity surge. Possible, but unlikely as this sort of damage is usually immediately evident. However, boiler pcb's are notorious for sudden failures anyway and can happen anytime. Combi pcb's are more prone to fail as they usually have up to four solenoids fitted and these do eventually fail due to mechanical wear.
3. When you your combi is in CH mode it heats the primary water circuit and directs the flow through the CH heat exchanger. When you open a hot tap (US=faucet) you're opening a supply of cold water initially as there is no stored hot water like in a conventional system. As the water starts to flow through the combi's diverter valve there's a pressure drop which activates a rubber diaphragm with mechanical connections to other parts. The diaphragm is one part which is routinely replaced annually as it will eventually fatigue and fail with the symptoms which you describe. In addition, the mechanical parts connected to the diaphragm pass through various seals in order to activate at least one micro switch. If the seals fail then the moving parts eventually corrode and seize up. Regular servicing prevents this. Combi seizures are a very common complaint in hard water areas.
4. One of the micro switches activated by the diverter valve has failed. Possible, but not likely. The purpose of the switches is usually to fire up the boiler to provide HW when the CH is not currently running, but as you haven't said which Vaillant you have I can't be definitive on this.
One major problem with combi boilers is that multiple failures can and certainly do occur almost at once. Unmaintained units may appear to be correctly functioning but in reality a number of worn parts can be close to failing. When one part fails, the others can't cope with the stress and fail as well.
In most civilised countries including the UK it's a criminal offence to attempt most repairs yourself unless you're qualified to work on gas appliances, so you need to find a decent heating engineer to service your boiler (ask your new neighbours). In the UK you can expect to pay around £120-£150 annually for a routine boiler service. If the circuit board has failed then it can easily add over £100. If parts inside the diverter valve/manifold have seized then you can be looking at an additional £80-£150. Note that diaphragm failures on their own do not merit diverter/manifold replacement and that if you have a new diverter fitted then a new diaphragm will already be present inside.
Dishonest heating engineers always diagnose a failed pcb as they know that you have no way of knowing whether it's true. If you can live with the problem for a few days then failed pcb's are usually a straightforward repair and there are plenty of companies who will send you a guaranteed exchange unit for much less than the cost of a new one. As long as you are not opening the main boiler casing which houses the combustion chamber and gas valve assemblies then some territories allow non gas qualified replacement, but others insist that the work is done by a qualified electrician: this is not the case in the UK as long as the pcb is not connected directly to mains electricity (no modern domestic ones are).
Oct 13, 2009 | Water Heaters
Heating circuit getting hot when hot water is running
Check to see if diverter valve is in domestic mode or heating mode.
Jul 04, 2009 | Water Heaters
Mar 31, 2009 | Water Heaters
Combi boiler no DHW
Dec 14, 2008 | Water Heaters
Water Heaters Logo
85 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
