Question about Maytag Admiral LER3330AAW / LER3330AAZ / LER3330AAB Electric Kitchen Range
I have a admiral stove older model it has self cleaning but when i go to use the oven it either does not work or it goes straight to self cleaing the elements work just fine there is a clock a timer a
It is a small apt sized stove white with black electric
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
It appears the oven control switch/ self cleaning mode switch are at fault need to be replaced.
Posted on May 08, 2014
josh1856
  • 105 Answers
SOURCE: Admiral electric range with self cleaning oven
There is an automatic lock feature on this unit that after 1 hour will unlock itself.
hope that helps!
Posted on Jan 30, 2008
aborcass
  • 2651 Answers
SOURCE: F9-4 when cleaning upper oven
its related to the self clean ltach motr, if you pull hte unit out and drop teh rear panel, approx halh way down on theright side( when behind unit) thers asmall lock mechinisn mavbe 1.5 round, with a connecting rod 2 wires and a witch, well that motor sometimes as it heats looses connection with the switch. the switch is monitoring door positoin so if it loses contact it thinks the door is open and will trigger a code. the entire latch is replacabel (FRont to back comesa sone assy latch motor swittch and rod. 2 wires connect it and 2 screws(by front latch secure it. if youtry to replaceit your self i giveyou the heads up to lie a yard stick on top of latch before removing old latch (thos will keep the insulation in place) andthen when installe ing new latch also use hte ayrd stick ontop to keep insulation inplace!!!!!
Posted on Mar 10, 2008
SOURCE: Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Posted on Sep 18, 2008
RepairClinic
  • 32 Answers
SOURCE: I have admiral Stove top burner is workni but oven is not working
This may be due to a bad main clock/electronic control but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Admiral Stove Parts: http://www.repairclinic.com/Admiral-Range-Stove-Oven-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
  • 42 Answers
SOURCE: Gas stove works, but oven does not
A gas oven will have some built in safety devices. Assuming that you have an electric pilot light sparking device, anything in the pilot light circuit could cause your problem
The oven does not "want" to turn the gas on unless there is an operating pilot system.
Since you never smell gas, but gas is available, then something in the pilot light circuit sounds like the culprit.
It could be as simple as carbon build up on the igniter or an internal fusing mechanism.
If you can get into the oven to the igniter, you could try cleaning the unit with a plastic scrunge.
I'm going to guess that this is not going to respond well to 'home grown' measures and that it will require replacement of parts.
Perhaps it is time to bite the bullet and call in repair......
good luck
Posted on May 20, 2009
How do you clean 1993 thermador double ovens
you can't get parts for this stove anymore so i wouldn't use the self clean on it,use soft scrub to clean it it says not to use easy off on a brand new oven but at this point i don't think it would matter on a 20 to 30 year old oven,when you put a stove into self clean it gets up to 1000 degrees,the wire casings on older stoves break down as it is but with all that heat you can do some damage to the stove,even if you just bought a brand new stove using the self clean can damage the electronics in it,usually it will take out the computer board or clock assy. same thing,your clock is most likely broken on that anyway or something else could be wrong with it and most likely you won't get it to self clean but if you want to use it or try to get it into self clean go here and read from page 32 to 36 hope this helps you out but i would not put it into self clean
http://www.servicetechhelp.com/public/user-manual/14-30-789A.pdf
if this doesn't look like your oven get the model number and google it on how to self clean
Jan 20, 2018 | Thermador Ovens
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
I have an older model amana electric stove; I cannot get the self-cleaning feature to work and I don't have a manual. Can you give me the steps?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 20, 2011 | Amana AER5515QA Electric Kitchen Range
When I set the self-clean cycle, all seems to be working - the light goes on, door locks, but no heat. Fuses appear to be okay.
heatman101
Sep 26, 2010 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Want to clean my oven self clea ning but i press the clean bottom and startthe door look 'unlook and show e1 f5
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
May 13, 2010 | Kitchen Ranges
How to clean Maytag self cleaing oven that needs some extra cleaning
heatman101
May 11, 2010 | Maytag Gemini 30" Self-Cleaning...
Kenmore oven door will not unlock, it is an older model and i have lost the manual. i tried to activate the self clean but i couldn't remember how all that ended up happening is that the door has locked...
Look around the console area for a button that says push to unlock. If it is there push the button in while unlocking the door. Some models may require that you also place the stove into self clean then canceling it out thus enabling you to unlock the door. Without a model number off stove tho it is all just guess worjk as all stoves are not the same.
Feb 28, 2010 | Kenmore Ovens
How do I get self clean to work on older fridgidare stove
Move the safety lock/lever at the top of the oven door to the right and press the self clean button on the oven control panel, it is an automatic cycle so it will lock the door from opening and then will proceed with the auto clean cycle. Good luck !
Jan 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
May 22, 2008 | Ovens
Maytag Admiral LER3330AAW / LER3330AAZ / LER3330AAB Electric Kitchen Range Logo
167 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
