Question about Toshiba Satellite A45-S151 Notebook
Boot to password
I cant seem to do anything, boots to password, I press f2 to enter bios and it doesnt work, what do I do? I hold down tab and the fan comes on and it beeps at me.
  • 23 Answers
Clear the CMOS to remove the password -
Here's the procedure (citing the relevant pages of the Toshiba maintenance manual):
1. Remove the main battery pack (p. 4-8).
2. Remove the hard drive (p. 4-13). The covers is secured with both screws and plastic "snaps," so you'll need to use something with a thin blade to gently (!) pry it loose with after you remove the screws; I used one of the flathead screwdrivers from my precision screwdriver set.
3. Remove the heat sink and CPU covers (p. 4-16)-just the covers, not the heat sink or CPU themselves. These covers are also secured with both screws and plastic "snaps."
Note: While you're here, this would be a good time to take some compressed air and blow the dust out of the heat sink fins and CPU fan (remember to not overspeed the fan).
4. Remove the optical drive (p. 4-20). I'm not sure that this step is really necessary, as I can't see how the optical drive would affect the shell disassembly, but it's easy to do-if nothing else it removes a lot of weight, and will make the laptop easier to handle later. Since the case holes have no threads, I just threaded these screws into the holes in the optical drive itself in order to keep track of them.
Note: Before reassembly, I gave the full system a thorough blow-out with compressed air; a lot of dust came out through the open optical drive bay, so that may be reason enough to remove it now.
5. Remove the keyboard (p. 4-23). Do also remove the "keyboard hold plate" and "keyboard support plate" and set them aside; note how they are oriented, so that you can put them back in place correctly later. Be gentle when pulling out the keyboard cable from the mainboard connector-I used a side-to-side shimmy motion to ease it out.
6. Remove the wireless LANboot to password - icon1.png board cover and carefully disconnect the wireless LAN antenna leads (p. 4-28). I used the needle-nose pliers to disconnect the antenna leads from their mounting posts on the wireless LAN board-just pull straight up (gently!). Note that the black antenna lead connects to the post nearest the screen hinge, while the white lead connects to the post nearest the wrist rest. You do not need to remove the wireless LAN board itself, so just skip those steps.
7. Remove the CD/DVD (audio) play button circuit board (p. 4-33). Disconnecting the thin ribbon cable connector looks scary, but it slips right out with a gentle tug.
8. Remove the display assembly (p. 4-34). This is where you'll go bugnuts keeping track of the screws if you're not using my Scotch tape method! Note that by "display assembly," we're talking about the LCD screen assembly and the upper half of the laptop shell.
Note 1: In addition to the two screws show in figure 4-20 on p. 4-35, there are two other screws that need to be removed that I can't find mentioned anywhere in the manual. These screws are located next to the memory module bay (one "above" and one in the "top right" corner; "up" means toward the screen hinge); both have "B4" marked in plastic next to their holes.
Note 2: Disconnecting all the (tiny!) cable connectors in step #7 goes easiest with the small needle-nose pliers, grasping the plastic head of each connector and pulling straight back (I suspect that standard size needle-nose pliers will prove to have tips too thick for this delicate work). Whatever you do, resist the temptation to just tug on the wires to disconnect the cables!
Note 3: The display assembly has plastic "snaps" in addition to screws, so you may need to do a little gentle levering to remove it.
9. Remove and replace the RTC battery (p. 4-43). You'll need to be careful to maneuver the "insulator" tab around the ribbon cable for the LED board, but it's manageable without removing the LED board.
10. Reassemble the laptop in the reverse order of disassembly (hope you know where all the screws are!).
Note on reversing step #7 (CD/DVD play button circuit board): The connector socket for the ribbon cable is on the bottom of the board, inset from the edge. Consequently, I found that it was easier to reinsert the ribbon cable into the connector socket before putting the circuit board back into place. Also, because this ribbon cable doesn't have a hard plastic plug on the end, I had to gently (!) grip the ribbon cable with needle-nose pliers in order to reinsert it into the connector socket (which is just a thin slot, and somewhat hard to see while positioning the circuit board). Be careful to not put too much pressure on the ribbon cable--it's relatively fragile due to its thinness.
Note on reversing step #6 (wireless LAN antenna): The antenna leads are on the small side; while easy to position over their sockets on the LAN board, pushing them onto the sockets would be difficult to do with a finger tip. My solutionicon1.png was to take my needle-nose pliers, close them, then use the closed tip of the pliers to apply moderate pressure to the cable connectors until I felt them snap into place. Note that I did not grip the cable connectors with the pliers--I only used the closed tip of the pliers to apply the necessary pressure.
You should now be able to boot up the laptop (after setting the clock, of course)-unless, like the one I'm working on, there are other problems to fix...
Posted on Apr 18, 2014
  • 1003 Answers
SOURCE: toshiba satellite with windows xp will only show black sreen and wont let windows xp repair
AvioriX is right your operating system is gone.
if u dont have restore disk get a windows xp program disk from walmart or target or office supply store and load operating system from it.(this will only load windows xp.) but will bring computer back up
Posted on Jan 15, 2008
josh1856
  • 105 Answers
SOURCE: BIOS password.
BIOS password article regarding Toshiba Satellite A135-S4427
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1816197xml&sliceId=&dialogID=32999663&stateId=0%200%2032997592
you actually should be able to "FLASH" your bios through windows.
Direct download page for BIOS
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1731516xml&sliceId=&dialogID=32999663&stateId=0%200%2032997592
Be sure to take your time to read the instructions and follow them dont have any programs open.
hope that helps!
Posted on Jan 29, 2008
SOURCE: Cmos / Bios password
IF IT COMES TO A SCREEN THAT SAYS "TOSHIBA" AND AT THR BOTOM LEFT SAYS ''F2-UTIITY , F12- BOOT MENU'' CLICK F2 IMIDITLY AND USING THE RIGHT CONTROL BUTTON SCROLL TO ''SECURTY'' AND CHANCE THE PASS WORS
Posted on Apr 05, 2009
SOURCE: cannot enter bios boot order
just when turn on notebook press esc then appear option f1 and thats all
Posted on Jul 07, 2009
  • 1481 Answers
SOURCE: Bios stuck on my toshiba L305D-S5934 it not doing
u can re-set the BIOS by removing the BIOS battery, the BIOS battery(wrist watch cell) is the size of a Dime inside the laptop, so you need to open the laptop, i suggets you visit a technician to do this.
Try doing the following also.
remove the power adaptor and remove the battery from the notebook, keep pressing the power button for 3 - 4 mins. Refit the battery / power and re-start.
Posted on Dec 07, 2009
Bios password
deepak,
You can create an administrator password by creating an administrator account in Windows. You can also add a BIOS password by entering the bios. (press F2 to enter the bios while booting up the system). Once in the bios tab down to the security screen to add password.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Sep 16, 2013 | Dell Inspiron 630M Notebook
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
WHAT WOULD BE THE PASSWORD FOR ENTERING THE BIOS TOSHIBA 1115 F103 THE LAPTOP JUST GO A NEW HARD DRIVE AND I CANT GET INTO THE BIOS tHANKS
Hold f2 on start up until it boots in to bios failing that do the same but this time hold f8 but hold down this key just touching it wont work.
Feb 16, 2011 | Toshiba Computers & Internet
My ASUS Eee PC 1005HA turned off by itself then when I turn it on again, a screen come up and said "press F2 or tab" but when i press each of them, nothing's happened. How can I fix that?
Hi I have almost the same problem as ame_91_ok with my Asus Eee Pc 1005Ha. It suddenly shut down a few days ago and ever since that time it boots the bios screen where you have to press F1 to enter setup or F2 to load with the default settings. If I press F1 I enter the bios setup and if I press F2 it's boots fine after that and it seems to work normally. Still I'd like to know what the problem is and if I can fix it before it might get worse. I don't know anything about bios settings or anything like that so I could really use some expert advise. Already tried updating my bios, I have the latest bios version now but that didn't fix the booting problem.
Greetz 08Ray
Dec 31, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I forgot the bios password also i want to update the bios in the laptop my currient version is f 39
when you boot up to the log in screen type in administrator to log in if you cant log in
During the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
or
control panel user accounts
on the users tab,click the name of the computer administrator you can change the password there
hope this helps
Dec 04, 2010 | HP Computers & Internet
After boot, appears ENTER PRIMARY MASTER HDD USER Password i need the password @ solution to boot up my lappy... thanks
How Do I Change the Primary Master HDD User Password?
Prior to loading an operating system, your computer will first execute the BIOS program. The BIOS has an extra password feature, called the hard disk drive (HDD) user password, that can't be bypassed and provides a layer of defense to keep your data secure. To change an existing HDD user password you will have to load the BIOS menu, which is only accessible during the computer's operating system reboot procedure.
Instructions
1. Close any windows that are currently open on your computer. Eject any discs inserted into the optical drive and disconnect any peripheral USB devices.
2. Open the "Start" menu and select "Shut Down." Turn on your computer once the operating system finishes shutting down.
3. Press the key your computer uses to load the BIOS menu. For example, with Dell computers tap "F2" when the "Press F2 for Setup" option appears. Press the "Access IBM" key on IBM laptops or "F10" on HP desktops.
4. Navigate to the BIOS tab that contains the HDD password option, which will usually be the "Security" tab. Some computer manufactures instead include the password option in the "Advanced" tab.
5. Scroll down to the option labeled either "User Password" or "BIOS lock" and hit "Enter." Type the current master HDD user password when the prompt appears and press "Enter."
6. Input a new HDD user password and hit "Enter" again. Navigate to the BIOS tab labeled "Exit" or something similar.
7. Move over to the "Save and Exit" entry and press "Enter." Select "Yes" and tap "Enter."
Nov 15, 2010 | Acer Aspire 5610 Notebook
I have an Acer Aspire One notebook. I cant seem to start it. I turn it on and this displays : Check cable connection..! PXE-E63 : Error while initializing the NIC PXE-M0F : Exiting Intel PXE ROM. No...
It happens when no boot device is selected, the default is network boot first, you must select CDROM/DVDROM or HD as your first startup device. boot up machine and enter bios setup think its F2 key to enter bios generally it del or f1 or f2 it may say onscreen at start if f2 doesnt work
in the bios set boot order to HD as firstboot option then save and exit
hope this helps
dont know if all acers do this but also if you press f12 on boot up it gives you current boot options select HD that way is current boot and would have to be done everytime
Nov 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire 5315 doesnt boot blank screen
When you power up the laptop press F1 or F2 or "del" key to enter in bios setup.
Then check your harddisk is detect or not?
Then also make sure SATA option is disabled in bios.
Then go to boot option and set first boot device as your harddrive.Then save settings and exit.
But if you even not able to enter in bios then you have reset bios settings and Refix RAM memory .
For that open back cover fo laptop and find cmos cell on motherbord pull it for 10 minutes so all settings of bios goes to factory defaults.
Let me know if you need more assistanse.
Thanks.
Sep 25, 2009 | Acer Aspire 5315 Notebook
Toshiba Satellite A45-S151 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
