Turntables This turntable have a very odd connection that needs a specific 11 pin plug. I have never seen anything like this. I have a wiring diagram but I am not the man to get it working using that. I need this cable to get it to work and no one seems to know anything about tis product,
  • Bjorn Nystrom
    Bjorn Nystrom Apr 18, 2014
    The turntable is ITT Tricon HiFi 7010 tangential
  • 141 Answers
I think your SOL dude as those types went out a long time ago and were proprietary.
Posted on May 08, 2014
Noggin
  • 944 Answers
SOURCE: International Power
You have probably permanently damaged your turntable. The voltage supply in Germany is 220V AC, whereas in the US it is 110 V AC. It is just possible that all you have done is to blow a fuse in the unit, if no external fuse holders are visible then try opening up the case and looking for one near where the power cable enters the unit. If you have no luck with that then the transformer is almost certainly burnt out - this could be replaced but it is unlikely to be something you can do yourself. Please don't plug anything else that is designed for 110V into a European socket, regardless of being able to get an adaptor that will fit the socket - the voltage is different. It will almost certainly die as well and the possible risks of electric shock, fire etc. are quite significant. Hope this helps, if you want to try and get the unit repaired in Germany please ask again with details of your location and I will try and find you a reputable repair facility. If in doubt about which of your items can be plugged in in Europe then please ask as some can be switched to deal with the higher voltage, although not all. :)
Posted on Jun 25, 2007
djproaudio
  • 515 Answers
SOURCE: Connect turntables(technics SL1210MK5) to a mixer?
None. The cables are already attached to the turntable. They are hard wired to the unit. The red & White cable. Just connect to the PHONO INPUT on your DJ MIXER, and connect the thin ground wire to the GROUND terminal on the mixer. That's it your ready to go.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Posted on Dec 18, 2008
  • 104 Answers
SOURCE: Need free owner's manual for a Detrola record player Model KM837
unable to follow what is wrong.
are you talking about the tonearm or a lever at the power switch?
Posted on Feb 11, 2009
dunnbiker
  • 8546 Answers
SOURCE: SONY PS LX300H turntable works only one channel at a time
This sounds suspiciously like the wiring of the cartridge is wrong or something is shorted together. The cause should be visible.
Taking special care to NOT touch the stylus itself in this operation:
Turn the locking collar and remove the cartridge assembly in its shell from the tonearm.
Flip the assembly over and examine the four wires under a magnifying glass for disconnections, kinks, crimps, or metal-to-metal contact between any of them. They should each attach to a pin exiting straight out from the cartridge.
The wires are also color coded as are the terminals. If they're wrong you could have various sonic malfunctions.
Correcting miswires is delicate and I would recommend taking the turntable and stylus to a pro for that part.
Posted on Apr 06, 2009
SOURCE: 1210 mk5g tone arm pin stuck
Hey raz, i've just taken apart and put back together my turn table trying to cure the same problem. I DIDN'T NEED TO!!!!
number 1) i think the tone arm is a sealed unit so far as i can gather so if the spring is broken you need a new tone arm. however. Get a cotton swab, soak in malt vinegar and use this to gently push the faulty contact in. The idea behind this is to get vinegar around the contact shaft. This should dislodge the dirt and release the contact.
Posted on Apr 18, 2009
Power supply Sony PS-LX10
Connect the RCA phono plug wires usually red and white wires with plugs to a receiver or amplifier in the back of it to phono in. New receivers will not work unless you have a phono preamp. Best to buy a vintage stereo receiver or amplifier with the correct connections. Make sure you connect the ground wire which is usually a small black wire coming from the turntable to an receiver or amplifier. Turn the stereo receiver on phono. Connect it to any screw attached to metal on back or look for a ground screw. If you do not attach it it will hum.
http://www.hardwaresecrets.com/imageview.php?image=357
Apr 18, 2014 | Audio Players & Recorders
I have an Aiwa PX-E77U turntable I'm connecting to a Pioneer VSX-454 receiver. The turntable has no ground wire. It plays okay at low levels, but as soon as I bump up the volume a little, I'm getting a...
It could be a bad connection of the earth pins to the cartridge. One turntable I had hummed even with an earth connection. I found out that the cause was the connection of the earth wire in a 3 pin plug.
Aug 31, 2013 | Aiwa Audio Players & Recorders
I have a Technics turntable Model: SL-BD22-KM, Ser.#: GF3Fc73813. The RCA and ground connection panel on the turntable has been jurked-out tearing the wires apart. I need to know which wires are soldered...
hi,
Here is the wiring of the turntable RCA plug ( RCA wire will have 4 connections like red and its outer wire then White and its outer wire.). connect these as follows.
For right channel
Red wire from the turntable to the red center wire of the RCA plug
Green wire from the turntable to the outer wire with red wire of the RCA plug
For left channel
White wire from the turntable to the white center wire of the RCA plug
Blue wire from the turntable to the outer wire with White wire of the RCA plug
OK
Oct 10, 2011 | Technics SL-BD22 Turntable
How do i hook a numark tt 1625 turntable to a regular home stereo amplifier...does the ground need to go into anything specific?
Turntables require a special input in the amp (usually marked PHONO) because they require high gain and different equalization - and yes, that ground wire has to go to ground unless you want to get a super annoying 60Hz hum from it!
If your amp doesn't have a phono input, you're going to have to go out and get a phono pre-amp and connect it between the turntable and the amp.
Best of luck!
Feb 26, 2011 | Numark TT1650 Turntable
I have a JVC AL E31BK turntable that I want to connect up to my system. I need a power adaptor for it. It says it requires 11-13volts but I don't know the amperage required. I don't want to use the wrong...
Normally these low power turntables connect to a unit audio system that supplies them with power. If you find out that you should be able to track down the specifications of it.
Jan 08, 2011 | Audio Players & Recorders
Hi i bought my technics 1210mk5's in america and when i gor back to ireland i had them converted to 220v as this particular model is not dual voltage. The 1210's worked fine then when i used a plug pin...
i had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do technics turntable servicing
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
Jul 10, 2009 | Technics SL-1210MK5 Turntable
Dec 17, 2008 | Sony PS-LX250H Turntable
I am trying to hook together a computer and a turntable(Turntable has its own pre-amp) & I need a diagram on what wire gos where?
OK. Since there is a pre-amp, all you need to do is to connect pre-amp output to Line-in input on the PC. This may be a bit of challenge as the connector on the pre-amp and computer are of different types. Usually, you need a cable with RCA connectors on one end and 3.5mm stereo pin (same pin as you have for stereo headphones) on the other.
Aug 17, 2008 | Sony PS-LX250 Turntable
No sound from turntable bought for our hi fi system
Most if not all turntables would need to be connected to a PHONO INput which is high impedance with a high gain pre-amplifier stage. It will not work when connected to an AUX, CD or any line level inputs. Alternately, if your amp does not have any Phono Inputs, you can feed the turntable output to a preamp which can then be connected to any any line level inputs. An example may be found here or here. Additionally, there are some turntables with a built-in preamp.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 16, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
