Question about Maytag Dishwashers
DOOR NOT CLOSING CORRECTLY AND LEAKING ON LEFT SIDE
MODEL # MDB4100AWB LEFT DOOR NOT CLOSING CORRECTLY AND IS LEAKING
  • LaDonna Griffis-Griego
    LaDonna Griffis-Griego Apr 18, 2014
    DOOR MAKES A POPPING SOUND WHEN I CLOSE IT
  • 23 Answers
Is it level? Could have been damaged during shipping if its new. If its not new it could be a worn out door seal.
Posted on Apr 18, 2014
4 Suggested Answers
SOURCE: Kenmore 665-15962 Elite 8 yrs old
Won't start nor drain. what could the problem be? please help.
Posted on Oct 16, 2010
prawinmv22
  • 106 Answers
SOURCE: DISHWASHER LEAKS AROUND DOOR LEFT SIDE MODEL HDA900
This is a faulty water valve assembly. replace asap if possible. the embedded water pressure sensor is damaged
Posted on Jun 10, 2009
futureloginn
  • 734 Answers
SOURCE: leaking problem from the door
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Posted on Dec 12, 2008
How to adjust left french door to correct clouser problem. It is making a sharp noise
Each model is different and giving us a model# greatly improves the advice we give you!
There are two ways to typically adjust the doors..
-Firstly is there is sometimes an adjustment nut at the bottom of the door that will raise and lower the height.
-Second is to adjust the feet in the front of the cabinet to shift from one side ( This raises or lowers adjacent side)
-Sharp noises are typical of LG's on the left door (models with ice and water in the door) and that noise comes from a spring loaded closer going bad.. Soon it will not close correctly and you will find it open often.
Please give us more information if further assistance is needed.
Feb 10, 2018 | Sharp Refrigerators
Jenn-Air side by side refrigerator, Model JRSD2490. Not staying cold enough
Larger=colder. Make sure that 1) your magnetic strip around the fridge door is sealing well. Even a small leaking area could make it difficult to keep cold, especially in warmer areas. Also, make sure there is nothing obstructing the door from closing completely and sealing properly. I had this same issue where one of the door shelves was unlatched a little and the door would close but not seal. Beyond that could be motor or more likely compressor or coolant leak. Good luck.
Jun 20, 2014 | Jenn-Air JCD2389G Side by Side...
Model # FDB1100RHB2 Dishwasher The dishwasher, since the installation just one month ago, has leaked continually (requiring a drip pan be placed beneath the door) from the lower left hand corner of the...
The door bottom is actually NOT sealed. Look into the levelness of the unit, and that you are using the correct soap. Both can cause water to leak by the door.
Look closely at the door alignment and make sure is did not get damaged along the way..
Nov 08, 2010 | Frigidaire Dishwashers
Our Hotpoint Aquarius Dishwasher BF11, built into the kitchen units is leaking steam from the door ( and starting to cause the wooden floor to bend ). Can I get a door seal for this model ? It's probably...
you gotta send the full model number,open the door and look at the very front of dw where the door closes into the machine,usually the tag is on the left side at 9 oclock,first are you positive that's where it's leaking remove the bottom kick panel and see if the motor or anything isn't leaking there too.if it is the door gasket it's an easy fix
Oct 07, 2017 | Hotpoint Dishwashers
Left door pops open when right door is closed Also
its a very airtight unit so sometimes the doors popping open when another is closed sort of briskly is normal, or the door has gotten tweaked/bent so its magnetic gasket is not making really good, firm contact with the frame to hold it shut..
the water dripping is (if memory serves me correct) the condensate drain for the unit was prone to sometimes getting clogged, or the pan leaking. you may be able to get a ladder and climb up to the cooling box and see where the water is leaking from and remedy fairly easily.
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | True TM-52 Commercial Refrigerator
Ice buildup around freezer door seal.
Hi, Check and see if the gasket is leaking any where. Also check and see if the door to you ice dispenser is closing. Ice/frost only builds up around the door hen there is an air leak.
I hope this helps you. Please let me know if I can assist you further,
Thanks
Vic
May 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
MAYTAG MDBO880AWB LEAKS FROM LEFT SIDE DOOR ONLY SOMETIMES AND
If the door is sprung in a manner that one side is flush and not other then most likely the hinge has been bent outward by the weight placed on it.the best solution would be to replace hinge,the spring only adjusts the tension for door closing. There is a slight possibility that either the frame or the door has bent in this manner so before buying hinge check frame and door for damage,after doing repair would suggest adjusting front legs of unit to raise front up a bit to ensure leaking wont continue
Apr 21, 2009 | Dishwashers
GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Jan 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
Kenmore Microwave door adjustment
Depends on the door. It likely can be adjusted they have 2 screws on the door bracket you may have to remove the cover to see them. But it also needs to be checked with a leakage meter to make sure its not leaking.
RadioShack used to make a low cost meter not certified or anything but a good way to see if its leaking.
Jan 08, 2009 | Kenmore 62622 Microwave Oven
Right side french door does not stay closed
I had the same problem - had my local appliance repair shop come by - simple releveling of the unit such that it is tilted slightly back re-establishes things so that the doors will cloe and pull themselves closed. The gaskets are actually magnetized. If the leveling is correct - even upon closing the left door - forcing enough pressure to push open slightly the right side - it will draw itself back in.
Nov 21, 2008 | Jenn-Air JFC2089HE French Door...
Dishwashers Logo
35 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
