Question about Vehicle Parts & Accessories
40 amp fuses continue tripping in a 1996 Chrysler Concorde
I have two different 40 amp fuses that continue tripping.How do I trace out these circuits to see if I need to replace the wire harness(es)?
  • 128 Answers
The owner's manual should delineate which circuits each fuse pertains to. Are they fuses that are blowing or circuit breakers that trip and can be reset?
Posted on Apr 18, 2014
1995 chyrsler concorde trips 40amp fuses
In place of a fuse connect a bulb... bulb should burn. trace wire with a compass or a magnetic field app on smart phone till you found the problem, way easier than a new wiring harness as well as cheaper... :-)
Apr 18, 2014 | Vehicle Parts & Accessories
1995 Mercury Grand Marquis blowing 40 amp fuse as soon as I turn on ignition
It will help if you can identify the 40 Amp fuse that is being toasted when the key is turned.
I looked briefly at a fusebox diagram and found 3 circuits protected by a 40 Amp fuse. The Lamp circuit protects several circuits which have smaller rated fuses on each separate wire. The 40 Amp protection seems to be a safeguard if all the smaller circuits are active in total. Turning off the automatic headlights, should reduce power drain.
The next circuit is the Rear window defroster. Can easily pull 40 Amps, but once the 40 Amp fuse breaks, it should have no effect on the engine.
The last circuit, on the cars with Trailer Tow or Police package has a
40 Amp fuse on the Battery charge Relay. This is a remote possibility. But the engine should be able to run without an Alternator for several minutes using Battery power.
Have them check the fuel pressure. The Inertia switch could have tripped while the car was being repaired. It does not explain the wiring short, but can explain the no start condition.
Again, if the same 40 Amp circuit is overloading, identify the circuit with the fuse box diagram.
Feb 18, 2014 | 1995 Mercury Grand Marquis
All systems seem to work ok but battery(brand new) won't hold charge
There is one circuit or more still active when the car is at rest. Connect a tester light between battery`s (-)terminal and ground cable. If there is an active circuit the light will be on. Unplug fuses one by one leaving them outside. When the light turns off note the number of the circuit/fuse and trace the problem. If several curcuits are active, this procedure shoulde reated. Usually simple things like the glove box light switch, or the luggagecompartment light switch cause this type of problems.
Nov 10, 2013 | 2002 Chrysler Concorde
Location of fusebox on 1996 chrysler concorde
sunroof is optional for this car I have it So the fuse for this isn't listed in the manual? any idea which fuse controls it & the A/C op
Apr 28, 2013 | Cars & Trucks
On a 1996 chrysler concorde I was told to disconnect a bad catlitic? converter to get around high prices for a young lady I am trying to help with no cash.after replaceing it with strait pipe the car idle...
By connecting the O2 sensor wires together you have created a short to ground in the O2 heater circuit blowing the related fuse that is usually on the ASD circuit. Without a converter the check engine light will come on since the O2 sensors are no longer doing their job. If she doesn't mind the light being on, disconnect the sensors leaving all the wires an open circuit and replace the affected fuse. You can't trick the computer since it looks for a ramp voltage and compares the upstream to downstream O2 sensors to determine the proper air fuel ratio for any given driving condition. I hope this helps.
Oct 19, 2009 | 1996 Chrysler Concorde
I have a 2001 chrysler concorde. the trouble codes
I RECOMMEND REPLACING THE OUTPUT SPEED SENSOR..ABOUT 40 BUCKS..WILL CAUSE THESE OTHER FAULT CODES AS WELL
Aug 30, 2009 | 2001 Chrysler Concorde
I have a 99 chrysler concorde and the radio will not come on,
turn ur key to on and pull 10 amp fuses out and find a blowin one put a new 10 amp in
Apr 11, 2009 | 1999 Chrysler Concorde
I need to find my fuel line in my 1996 chrysler concorde lx
START WITH F FILTER, LOC. START AT TANK, TRACE LINES TO FRAME FORWARD
Oct 07, 2008 | 1996 Chrysler Concorde
Vehicle Parts & Accessories Logo
44 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
