Question about Sony Televison & Video
Tray wont open though evereything else works just fine
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Look for a little pin hole, put in needle and tray should open, this is an emergency way to release tray.
Posted on Apr 19, 2014
HAVE A SONY DAV-HDX265 DISC TARY WONT OPEN AND DISPLAY READS (c 31 00)
Hi. If you are able to open, do so and check if you find a black rubber band that could have fallen off the tray. If you do just buy and replace. The band is is driven by some gears and helps open the tray and if it ages it gets damaged and cuts off. If the band is still intact, then see if the elasticity is still there and replace if there is no elasticity. If the band seems fine, then look at the gear near the end of the tray and try to open the tray manually.If you open the tray manually try see if there are broken or damaged gears. If non power the system and see if the tray closes. If it does then press the open button to see if it opens. If it does not, change the black rubber band that should work.
Aug 30, 2016 | Sony Audio Players & Recorders
JVC DR-MV80B display says hello then shuts itself off.
On electric board you need to change the STR,and work fine.....
Sep 09, 2012 | JVC DR-MV80B DVD Recorder / VCR Combo
My xbox 360 disc tray wont open how do i fix that problem
Slap the top of the the box as you press eject. that will get it open.
then wipe a little rubbing alcohol on the black belt
just under the tray . And a little petroleum jell in the
tracks under the tray . Then open and close the tray to
work it in.
Rob
Sep 19, 2009 | Microsoft Xbox 360 Console
MY GAMES WONT LOAD
you need to unplug ever cable you have and every accessory you have. Unplug adapters memory units hd inter coolers every thing. let it sit for 10-15 minutes. Plug everything back in then press the button to open the tray to turn it on then put in a different game keep it open . Then when the menu comes go into a program so you can't see play game or close tray. Then when you are in the right place close the tray and it should load. This worked for me 2 times.
Jun 23, 2009 | Microsoft Xbox 360 Console
E1 (rear) error. DVD tray will not open.
there might be a possibility that as soon as the tray closed the dvd shifted inside the machine. the dvd is stuck yes which means that the tray wont open because the dvd is blocking the gear turning. if so you are going to have to take it to your Dealership to open up the player and remove the disk. you can try it yourself but it's not recommended. tray gears will have to be tested to see if the tray will open once the disk is out though
Mar 29, 2009 | Philips Magnavox DVD/VCR Dual Player
My Samsung BD-P1400 is frozen on "load" and disc tray won't open
My player worked fine couple of days ago, then last night when powered up, message was "load" and it stayed like this forever, and tray open would not work. Tried everything, nothing worked. Left unplugged from power for 24 hrs and bingo everything worked as should. I suspect that the unit is still trying to load info from last disc which I stopped in the middle of some bonus material, even though the disc was no longer in the tray.
Dec 26, 2008 | Samsung BD-P1400 Blu-Ray Player
Canon i865 6x4 photo tray - knob wont turn to engage paper seems jammed. Thanks
Embarrisingly simple fix. The printer was pushed up close to our wall thus not allowing to the paper feeder sit back normally. Therefore the photo tray was not sitting correcly. Once placed in the proper position, it all worked fine.
Thanks for the response though.
Kind Regards.
Jul 10, 2008 | Canon Office Equipment & Supplies
I had the same problem. I opened up the unit and gently released the tray from inside. It has been working fine since - except for the problem I just posted i.e. the remote does not work.
Nov 17, 2007 | Memorex MVD2027 DVD Player
My xbox wont stay shut
push it in until it closes .i know it sounds crazy but it worked for my ps2. i dont know about xbox though.
Nov 13, 2007 | Microsoft Xbox 360 Console
Televison & Video Logo
51 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
