Question about Compaq Presario 5000 PC Desktop
Monitor did not responding
When I switched on the CPU there is a beeping sound and monitor also did not responding.
If beep sound repeating continously then you check the ram if it continue replace it .and one more reason if it is in case if it is beep at first and stops then it is due to display problem so check the display cable
Posted on Nov 02, 2007
  • 134 Answers
When you first power on a computer it checks itself out for proper operation even before you see anything on the screen. This process is called Power On Self Test, as no video is yet displayed and moreover there may even be a video problem the computer sends out beeps over its internal speaker to indicate its status. Usually you will just hear one beep then the computer will "come to life", if however there are any problems you hear a series of beeps. For a description of these beeps and what they mean please click here. Hope this helps !!
The cpu is running,the motherboard is with green light inside,but the monitor blanck
what king of monitor you have., crt or LCD, does the monitor led indicator has a green light, is there any beep when starting the cpu? how many beeps you have heard when the cpu was starting?.
if there is no led indicator light in you monitor the posibilities of that is the monitor was the problem.
solution: try to check your plug in monitor if it is properly inserted in the power plug or in the vga plug correctly.
if when you power the cpu and your monitor led indicator, turn green and back in the standby mode. listen to the beep sound of cpu if theres any.
solution: try eject the mem card. in the slot and clean the contact with the eraser. and put it back into the slot again after you clean it.
Mar 28, 2011 | Computers & Internet
When i start the computer the monitor doesnt go and the red light indicating an error apears. what that can be please?
Dear User,
Please refix the is display cable properly and check if the issues resolves.
Kindly check if any beep sound comes. To check is the system board is fine. Please press the Num Lock for 2-3 times and check if it responds(Led On/Off)
To check the monitor status, please remove the display cable which is coming from monitor and connected with System(Cpu), if it displays the message on screen then it passes the monitor test and indicates that Monitor is fine.
Please share the result.
Feb 22, 2011 | Computers & Internet
Desktop screen is blank even when the cpu and monitor indicator a
It looks like issue with either mother board or processor.
open the box and remove all memey and power it on. if it makes a beep sound, there is no issue with processor, else we suscpect processor. If it make beep sound, it might be mother board issue. And for checking monitor working condition, remove monitor data cable and see no cable connected messages comes in monitor or not
Oct 13, 2009 | Dell Computers & Internet
My monitor is not responding to anything. what can i do aside from rebooting?
do you see the light blinking in the monitor? I mean the POWER led light up? If so, then the monitor is ok and is working good. It is your CPU which has a problem and not sending digital signal for the monitor to display.
Try to turn off your computer. After 3 minutes turn it back on. then notice if you will hear a short beep from the CPU. That signals a successful video initialization. If you went through that process, then your computer will get back to life.
However, if you dont hear a short beep from the CPU, then definitely your CPU is frozen therefore there is nothing to display to the monitor.
You need to open the CPU case, pull out memory modules then plug them back in. Then try booting.
If not successful, try to open case and pull out the processor. Put it back in after 30 seconds. Try booting again.
Do ALL THESE while your PC is UNPLUGGED.
Good luck.
Oct 09, 2009 | Computers & Internet
When I boot my PC up I get a blank screen and a message saying no signal then the screen goes into standby mode
OK, it's gonna be one of these 3 things :
1. The cable linking your CPU to your monitor might not be properly plugged or has been damaged. You should hence ensure that the connection between the two devices has been properly done and that the cable’s state is fine.
2. You might be facing a problem with your monitor if the CPU makes a single beep error sound when you switch on the system. You can check whether the problem comes from your monitor by testing it on another CPU. If you still have “No Signal” error displayed including the error beep, I would strongly suggest you to try to get your monitor fixed by a competent technician or to get a new monitor.
3. If you receive several error beeps when starting the computer, this might be linked to a graphic card dysfunction. You can refer to the motherboard notice or check that the connection has been properly set
Dec 12, 2008 | Computers & Internet
Acer AM5641 Desk-top PC
when u power up the computer u heared any beep check then num lock if u abkle to num lock on and off your cpu is ok.then tv to cpu connection we have to check.
also press F8 key when u power the cpu then go to enable vga mode.
then change resolution to 800*600 or 1024 *768
Nov 24, 2008 | Acer AM5641-B5560A Desktop PC & Monitor...
Pc is not booting and no display in monitor
First, try resetting the CMOS. If it is not working, replace the RAM. Could be a damaged RAM
Sep 11, 2008 | ASUS (P4BGV-MX) Motherboard
Continuous Beeping, new PC
Continues short beeps... means a short OR no power OR loose card OR system board.
Test it without the keyboard and mouse too. Just the Processor with heatsink, motherboard, memory and Video card.
Now add the keyboard, no mouse yet.
Check also the voltage of the CMOS Battery it should be 3V.
keep me posted for the result... count also the beeps.
Feb 09, 2008 | Intel Motherboard
No any display in the monitor, no beep of the RAM while CPU fan is running
Check your power supply. It sounds like you have a bad power supply. Even though the computer powers up, it does not mean that it's good. I have had this problem before, and almost 9 out of 10 times the power supply had gone bad. Just try a different one and see. hope this helps you.
Oct 01, 2007 | ASUS P5S800-VM Motherboard
Compaq Presario 5000 PC Desktop Logo
93 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
