Question about Ovens
My DigiDoor flashes a F7 error which means "service required" The door doesn't open. How can I reset this error?
3 Suggested Answers
drstrawn
  • 48 Answers
SOURCE: range led flash code F7
Here is the error information for Fault Code F7
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
Hope this is helpful, I will also provide you a link to to a helpful site.
http://www.applianceaid.com/fault_codes.html
Posted on Mar 14, 2009
  • 254 Answers
SOURCE: what is error message F7 mean in GE Wall Oven?
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Posted on Jan 31, 2010
Oven won't heat flashes F2EO and 5D on
List below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appears, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad. Replace Keypad.
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Below applies only to the two digit display models for the brands above.
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Mar 20, 2016 | Ovens
I have a flashing code on my kenmore electric oven, model 911.47709200. the code is F7 dc, what does it mean?
Stuck Keypad. Roper ovens with 2 Digit Displays:
Oct 25, 2011 | Ovens
Control panel flashes F7
The F7 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F7 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Oct 02, 2011 | GE 30" Built-In Single Electric Wall Oven...
My stove is beeping and is flashing F7. What does this mean, it is a built in oven.
The F7 error code means that a function key on the touchpad is shorted or stuck, the F7 can be cleared by pushing the clear/off button,if the error code returns the touchpad would need to be replaced.
GENE
Sep 10, 2011 | GE Ovens
Aeg b5741-14 oven has code f5 -what does this mean?
Here is a list of oven error codes for your model Kenmore oven.
  1. F0 indicates a Stuck key pad.
  2. F1 and F7 may mean relay is turned on.
  3. F2 indicates that the oven is over temperature in one of the following modes within either cooking or cleaning mode of operation. The control is sensing over 615 degrees with the door lock circuit in the unlock mode. Control senses oven temperature above 915 degrees with the door in the locked mode.
  4. F3 and F4 indicates an open or shorted oven sensor or sensor circuit.
  5. F5 indicates a loss of relay drive circuit.
  6. FF indicates a loss of door motor safety switch.
  7. FC indicates a door lock circuit problem.
If the display of your control is flashing "F" followed by a number or letter its a range malfunction. Press the clear/off pad. Let the range cool for 1 hour and place the range back into operation.
If the problem repeats, call for service.
Jul 16, 2011 | AEG B5741-4 Electric Single Oven
When the electricity goes out the F7 button comes on and the manuel says to turn the power to the unit of and it still comes back on
Unfortunately the F7 error code normally means a problem in the controller or touchpad (replacing both is common and parts alone is about $300)
You might try shutting down the power. Then finding the ribbon cable connector for the touch panel, unplug and clean the edge connector with a #2 pencil eraser. Sometimes that improves the signal enough that it will work a little longer, sometimes it doesn't and then you are talking about a $300 parts expense plus your labor or the $300 parts and Service call and labor expenses if you call a service tech.
Jun 05, 2011 | GE Profile JTP56 Electric Double Oven
Have a maytag super capacity plus oven i tried cleaning the oven now the door will not open and it shows f9 on the front
Had the same problem. How I fixed it, was by using a very thin, and I mean really thin, flat tip screw driver and a flash light. Unplug the stove. Use the flash light to look at the very top of the oven door. You should see in the air vent slats a silver hook. Use the screw driver to go through the vent slats and push the lock open. Now, you should be able to open your door. But we arent done yet. With the door open, plug the stove back in. Close the door and wait for the F9 to flash. Now open your door, and on the right side you should see a tiny peg sticking out on the open oven. Its for the light to come on when the oven door is open and also to let the oven know the door is ajar. Push it in and wait. The door latch circuit should reset like normal, and you will see the latch move back into its normal open position. Which resets the F9 error and allows you once again to use your oven like normal.
Dec 20, 2009 | Maytag Ovens
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F7 Shorted Touch Panel Replace Glass Panel
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F2-E0 Shorted Keypad Replace Keypad
Ovens with 2 Digit Displays
Dec 18, 2009 | Ovens
Error code F7 keeps coming up, what does this mean?
F1 error and beeping. Don't bother getting GE out there. Cost me $90 to learn they don't make the clock. WOuld have been $500+ for the control panel anyway. Better off just buying a new one. Planned obsolescence I guess. I won't buy GE again.
Mar 16, 2009 | GE JKP27 Electric Double Oven
Range led flash code F7
Mar 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
47 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
