Question about Cub Cadet Garden
Cub cadet LT1050 that won't start .new battery, changed solenoid etc still getting nothing when we turn the key
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 1,917 Answers
Brake safty switch is bad or seat switch is bad replce them
Posted on Dec 17, 2014
2 Suggested Answers
  • 2239 Answers
SOURCE: Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Posted on Mar 07, 2012
Cub cadet lawn tractor not starting?
There are several safety switches located on the tractor that could be giving you the problem. The starter solenoid may be bad as well.
Jul 10, 2016 | Cub Cadet Garden
Cub Cadet Riding Mower LT 1046 have to jump, but won't stay running
Check the bottom of the carburetor for a little solenoid. If it has one, the battery may be dead enough that it can't keep the solenoid open causing the carb to shut off the fuel flow causing the unit to die. The easiest way to check if it works is by turning the key to the run position and listen and/or feel for the solenoid to click. If it clicks it is working and there is another problem, if it doesn't then replace it. I recommend having the battery tested or replaced too
Jan 03, 2013 | Garden
Mar 04, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet ZTR will not start
Is the blade engagement off? If that is ok, does the solenoid even click when you put the key to start position? If the solenoid doesn't even click check the battery connections and make sure they are good and clean. If the connections are good, are you sure the new battery is fully charged. If the battery sat around for a long time in the store it could need charged. If all that is good and then you don't get the starter solenoid to click when you put the key in start position, then it is either the seat switch, parking brake switch, handle switches, or mower engage switch keeping it from starting. If all that is ok maybe you have a bad starter solenoid. Please rate my answer so I am rewarded points for it.
Jan 30, 2012 | Cub Cadet Garden
My lt 1050 will not start without a charger attached. Once its running, the pto will not engage. Thought the battery was dead but battery has 13 v. Starter makes no sound when trying to start. No problems...
Does the battery have good voltage even with the key on? A battery can have 12.6-13 volts with the key off but once it is turned to "ON" it can drop considerably. Lights, solenoids, safety switches, and relays all take voltage from battery. Also check to make sure the battery connections are free of corrosion and tight.
Aug 04, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I HAVE A CUB CADET LT1050 LAWN TRACTOR AND WHEN I TURN THE KEY I GET ONE SINGLE CLICK. THE STARTER DOESN'T ENGAGE
Hi camy wils815...
Sounds like you have a faulty solinoid.
Make sure your battery has a full charge, the by-pass the starter solinoid on the engine.
To do this ground one big wire connection to one of the small wire connectors (with the wires still hooked up) and if it starts, then replace the solinoid...if it does nothing, replace the solinoid.
Please take time to rate me
Jul 30, 2011 | Cub Cadet Street Sign- tractor lawn riding...
STARTER WONT TURN ENGINE SOLENOID CLICKS BATTERY IS FULLY CHARGED
Do you have 12volts dc to your starter when your solenoid clicks?
if not replace solenoid,if yes check starter next and then be sure engine is not siezed?
Apr 30, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Mower has fully charged batt while trying too start it just clicks at the solenoid and then a humming sound but nothing from the starter it self ltx 1042 cub cadet any help would be great thankyou
Sounds like your going to need a new starter. They're not to much you should be able to buy one at your local lawn and garden store, and they're very easy to replace.
Feb 07, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
2140 cub wont turn over when trying to start
Change the solenoid, if you can jump the posts on the solenoid and the engine turns over...the solenoid is bad
Apr 02, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
174 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
