Question about RCA F32645 32" TV
No Volume from cable input
My TV was tampered with by children now the cable has no sound the dvd player sound works fine, checked connections there is no cable box is there a menu option i need to change?
  • 31 Answers
The sound is probably set to the SAP channel (language) and the SAP channel is not active on the program you are watching. Just push the SAP button on the remote. The button might be labelled SAP or LANG. This will return you to the main sound channel which is always active.
Posted on Apr 28, 2014
My olevia tv volume only works with me dvd player but no sound when i connect my cable box
If cable from cable box is connected to TV, use TV remote to switch to Cable input if you have a Cable/DVR you will need to run speaker wires from Cable/DVR to a TV input
Nov 12, 2013 | Olevia LT32HVM 32 in. LCD Television
Our tv, model 42hp25bat, has been running on our cable input for the past year. All of a sudden the tv input setting says "no signal". The tv works for our DVD player on HDMI setting. We...
the signal input on the cable connection to to your tv (inside your tv) is broken, and possibly needs to be replaced. Possibly few capasitors or other parts might need to be replaced. or the whole signal board.
Apr 17, 2008 | Televison & Video
When my tv is playing regular cable the volume doesnt work but when i play a dvd in the dvd player volume comes out of the tv, whats wrong?
Good--sound when playing a DVD means either a setting is wrong and it can be in the set or a box if connected---it also means the audio output circuit is good.
Worst case is where sound is developed by the set's tuner there may be a problem but check all audio settings first---
Jun 12, 2012 | Hisense LHD3204US 32 in. LCD HDTV
No audio in dvd playback. Video works just fine. Cables connected properly. Vhs sound and audio work.
Would you pls check the connection again that you have made between TV and DVD player..?
2xRCA (white+Red) will go to 'Audio IN 'sockets of TV in addition to '1xRCA Yellow video cable' goes to "Video IN socket 'of TV..since you have video ,probably Audio cable connected REVERSE..
if the connections are right than you must select the right source on TV ,as AV1 ,AV2 which corresponds to the cable input sockets of your TV.
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 11, 2011 | Philips DVD740VR DVD Player/VCR
Dvd play works but vcr playing does not
For this unit the component output (green, blue, and red cables) only work for the DVD player portion of it. You will need to connect either the av input on the back or the front with composite (yellow, red, and white cables) to your television in addition to the component cables I assume you have connected already. Once you have done so you will need to switch this unit over to the right av output in order to access the vcr and also switch your television over to the right av input in order to pick up the signal from the vcr.
May 05, 2010 | Toshiba SDV395 DVD Player/VCR
Cannot hear the sond on Sylvannia TV 6615LCT
This will sound strange, but some DVD players and cable boxes have separate volume controls. I would check the settings for both of those to make sure that the volume has not been turned down and also check the connections from the dvd player and cable box to the tv. Make sure all connections are solid.
Apr 25, 2009 | Sylvania 6615LCT 15 in. EDTV-Ready LCD...
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Dec 23, 2008 | Sony BRAVIA® DAV-HDX576WF Theater System...
I am trying to hook up my tv to my receiver, I have a dvd vcr combo,and cable box
Audio: There should be a set of audio outputs on your TV. Connect those to the AUX inputs of your receiver. When you turn on your receiver, set it to AUX. Set your TV volume to approx 1/3 and adjust the volume on your receiver. There's probably a menu section on the TV to turn off your TV speakers so the sound will only come from your receiver.
DVD/VCR (I'll call it DVD from this point forward): Connect the video (yellow) output from the DVD to the "video input" on the back of the TV. Connect the audio out on the DVD player (red) to the red audio input on the back of the TV, then do the same with the other audio (white). When you want to use your DVD player, you'll select "input 1" as the input on the TV.
Cable: Your cable box probably has numerous output types. I have the cable box hooked up to both the DVD player AND to the TV; one output type going to the DVD player and another output type going to the TV. I like to use the HDMI output from the cable box to the TV, and the composite video from the cable box to the DVD.
Hope this helps. Let me know if you need more info.
Mar 18, 2008 | Televison & Video
Does not recognize cable channels
All you have to do is connect those yellow red and white cables to one of your tv inputs in the back either video 1 2 or 3 and you should have both your dvd player and cable working. Make sure your black cable is connected through coaxial in the back of your tv and the yellow white and red cables from the dvd player to video 1 in the back of your tv if anything else just let me know...
Nov 23, 2007 | Sanyo DS24425 24" TV
RCA F32645 32" TV Logo
70 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
