Question about Light Boating
1998 j15recr hp idles fine but floods at full throttle, is something cloged I don't know about?
Have cleaned carb, hotter plugs, new head gasket,rebuilt f.pump, comp@ 100psi x 2,
5 Suggested Answers
finish line
  • 207 Answers
SOURCE: 25 hp 2 cycle 2004 runs rough at idle to 1/2
it should advance but not bounce you have a loose something the trigger switch (that is what that is called) should be still and advance and disadvance as you throtle up and down there is a adjuster on the side where the shifter linkage is they usally have a stain less bolt as a adjuster there may also be loose bolts or broke something under the fly wheel you get the trigger adjusted right and your problem is fixed good luck
Posted on Jul 08, 2009
  • 77 Answers
SOURCE: Chrysler 70 HP outboard motor dies when pushing throttle
I have found that 99 percent of the time when this happens it is carb related. It is very possible that you picked a a small piece of grit or trash in the high speed jet of one, or both, of your carbs. I would be willing to bet that pulling the carbs and cleaning them will resolve your problem. I am almost positive that will fix your problem, mainly because it sounds like you've already tried everything else. I had this same problem last season, and what had happened was I left the vent open on my fuel tank, we got a shower, and I pulled just a small bit of water into the carb and that was it, she would not do anything over idle until I pulled the carbs and cleaned them. i even put the water muffs on it and let it run in the yard for about an hour thinking that it would burn the water out, but i was wrong. Anyway, clean the carbs and i think you'll be in good shape, Good Luck.
Posted on Aug 02, 2009
  • 43014 Answers
SOURCE: 1991 EVINRUDE 25 HP 2CYL 2CYCLE IT RUNS ON BOTTOM
get a spark tester that has 2 leads and test spark .
Posted on Apr 26, 2010
goldbill
  • 184 Answers
SOURCE: mercury 8hp wont idle without choke
sounds like a minor vacuum leak, follow any tiny hoses from the top of the crankcase to the bottom- they love to split right where they bend,
Posted on Nov 29, 2012
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
Hi. I inherited a 1998 Husqvarna 265 rx. Got new plug and new fuel and it fires ok. Wouldn't stop so I added a washer under the 'earth' screw and it now stops. Problem is poor acceleration
To set the throttle, start by slackening the cross head screw securing the cable in the handle and pull completly out, now slacked the three allen headed screws securing the handle, twist the handle to the best position for your use ( at full throttle your thumb should not be straining ) now slacken the lower cross head screw and turn the silver clamp to tention the spring underneath, when correctly adjusted the throttle trigger should spring back to the idle position readily, now re fit the cable up through the clamp, turn the cable so as it is just about to open the carb throttle spindle, lock the cross head screw and test to make sure you are getting full throttle, if not slacken the screw and turn cable a little more.
Sep 19, 2012 | Husqvarna 531004054 Throttle Wire
My 2006 polaris 550 super sport idles perfect, but when given gas it dies out like its flooding. I did a compression test, and it was good. I took apart the carbs and cleaned them,replaced the coil,...
i had same problem in dirt bike. had buildup inside of gas tank. cleaned it out and put in an inline filter, cleaned carb again, run fine since.
Jan 27, 2012 | Winter Sports
Strimmer will not run on full throttle.When choke engaged will idle fine,but as soon as I release the choke it dies.It has fresh fuel mixed correctly.There are no obstructions such as grass in the...
This condition sounds like a plugged main get. Take the carb off, and clean it out, run spray carb cleaner though all passageways, and test it again. No need to focus on the idle circuit.
Apr 15, 2011 | Garden
03 vstar 1100 idles good runs bad under throttle. Changed plugs,cleaned carbs on bike.Pulled rubber diaphragm's cleaned with carb cleaner.Bike will turn over but will not fire off.New plugs fouled.Good...
Hi, Cgallops108 and the usual suspects are:
1. Dirt or other foreign matter between float valve and its seat.
2. Float valve sticking.
3. Float valve and/or valve seat worn or damaged.
4. Float misadjusted.
5. Float cracked, leaky or damaged.
6. Excessive "PUMPING" of hand throttle grip.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
06 vstar 1100 carb flooding
Yamaha star 1100 heat soak flooding
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Mar 21, 2010 | 2001 Yamaha V Star 1100 Classic
Cant keep idle at one rpm
Many times you may also have to adjust the throttle needle as well for altitude or just to get it to run right. It may be the throttle cable having problems too.
Aug 05, 2009 | 1998 kawasaki KDX 200
Mariner 25 hp 2 stroke hard to start then quits and won't restart
It sounds like the float is sticking in the carb. Since the carb is higher than the fuel tank it pulls the fuel in by vaccum of the engine. when running at high rpms, it can burn the fuel thats flowing into the carb, when you idle down, the bowl of the carb is filling up with fuel faster than the engine can burn it and causing it to flood. Then when it shuts off at idle it does not want to start back up because it is flooded. To make a long stary short, pull the carb and give it a good cleaning and your problems should be solved.
Aug 01, 2009 | Light Outboard Motor Boat Bass Fishing...
2001 kdx 220 starts idles great no power stalls out , floods
Use a hotter spark plug. They do have different heat ranges.
Jul 01, 2009 | 2003 kawasaki KDX 220 R
Boating Logo
29 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
