Question about Car Audio & Video
I want to add 2 tower speakers to my clarion m455a. Currently I only have 2. Can I use the RCA connectors in the back of the clarion unit.
  • 23 Answers
One way to find out... Its not going to hurt anything.
Posted on Apr 18, 2014
3 Suggested Answers
vetteman3002
  • 2299 Answers
SOURCE: When i connect rear speakers
Either you have the back speakers hooked up to the sub woofer output channel on the head unit. Or your amp has a built in crossover. Not letting the higher frequencies get to the speakers.
Posted on Nov 05, 2010
  • 5370 Answers
SOURCE: I have a 2007 chaparral
Remove the radio out by removing the face plate out and reinspect its wiring's and connectors.Any of the wire is getting loose or overheated/ shorted causing this problem.------- There's usually a flat metal "key" to release each of the two lock catches at the top corners of the radio. It should have come with the radio. Look for slots in the top corners about 1/4' wide. If you don't have the key, you can try using a thin jewler's screwdriver or can try buying a key at an audio store or even a Radio Shack. --------- Once the radio is out, then disconnect it wires, then clean the wires with contact cleaner and reconnect the wires.Then without fitting the radio, just turn it on and see, does it gets over heated and is there any problem with sound after using it for few hours.--------- If you still notice the same problem, then speaker and sound wires to the radio needs inspected.But if there is no problem, when radio is working out.The refit as it was before and test.--------- This will help.Thanks.Helpmech.
Posted on Aug 23, 2011
Parts
There may be a fuse link or diode inside of the unit. You would have to dissasemble to locate. Depending on your skills, you can do this yourself. It would probably be expensive to have a shope repair it.
Jul 05, 2013 | Clarion M455a Marine Cd Receiver
I have a clarion m455a marine raidio in our new boat. It has two cmrc3d remote control stations. niether one of them work. Why
Sorry I can't help you...but wanted to let you know you are not alone. I bought a 2007 Chap last March and have the same problem. I've covered all the basic/common sense troubleshooting but can't get them to function. My frustration is that the displays work so the clock/radio station is displayed but nothing in regards to controlling the deck.
Aug 08, 2010 | Clarion M455a Marine Cd Receiver
I cant find the Part Number for the connector harness that has th
You will have your best luck at a local car audio shop that sells clarion. If your not sure where to find one, you can do a dealer search at Clarion's web site. www clarion.com Hope this helps
Jul 08, 2009 | Clarion VRX775VD Recorder
Installation manual clarion m455a
Here is the product page:
http://www.clarion.com/us/en/products/2006/marine/source_units/M455A/us-en-product-pf_1151544055054.html
And here is the manual:
http://www.clarion.com/us/en/MungoBlobs/797/154/M455A_ENG.PDF
In page 33 you'll find the wiring chart.
Dec 01, 2008 | Clarion M455a Marine Cd Receiver
Connecting my ipod to xmd3
I believe that if you use the RCA connectors, you can use your iPod. If you use the clarion cca connector, you get more functionality from the dash of the clarion.
Jul 07, 2008 | Clarion XMD3
Clarion xmd3
Yes, there are 2 Red RCA jacks on the back. A $10 cable from radion shack, 2 RCA on one end and a 3mm jack on the other.
Cheap way to do it, there is also a device you can buy from Clarion that will do it for about $90 that gives you more control from the radio.
Jun 23, 2008 | Clarion XMD3
Clarion APX480M amp
This sounds like a signal problem. Make sure that all of your signal cables are plugged in fully. If all are, you need to check for coninuity between the shield ground of the head unit's RCA jacks and the case of the head unit. With no RCAs plugged into the head unit, you should read ~0 ohms between the shield of the RCA jacks and the case of the head unit.
Aug 28, 2007 | Clarion APX480M Car Audio Amplifier
Manual
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Jun 20, 2007 | Clarion DRB2475
Car Audio & Video Logo
102 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
