Question about Dell Inspiron Mini 10 Notebook
Del inspiron mini notebook boot manager compressed
3 Suggested Answers
portland1970
  • 145 Answers
SOURCE: TFGHT FILE IS COMPRESSED PRESS
reinstall windows with the resore option when powering up hold the 0 key down until you hear a long beep then select the restore my computer option
Posted on Jan 28, 2011
  • 11 Answers
SOURCE: Dear sir i have a
restart the laptop and keep pressing F2 when the DELL splash screen comes up before windows loads. Inder boot settings make sure The hardrive is selected as the primary boot drive.
Posted on May 11, 2011
Boot manager is compressed
There are some security programs that do this. When you press Ctrl-Alt-Del, you get a password dialog. Certain viruses also have this effect, either by imitating the security startup or sabotaging the boot sector.
Can you boot the computer with an optical disk or USB boot system? (Some Linux distributions can be installed on a USB flash drive. If your notebook BIOS lets you enable USB boot, you can start and run the computer using the the flash drive.)
If you can get a Windows install disk for your version, you can try a repair install to see if it will patch a corrupted boot sector. Otherwise, you may need to use an antivirus scan run from a system on an external drive.
Apr 04, 2012 | Advent 4211c Notebook
Dear sir i have a dell inspiron notebook without cd/dvd RW when i started it "boot manager missing" what to do
May 11, 2011 | Dell Inspiron Mini 10 Notebook
Dell insperation10 notebook boot manager missing tried f8 not working any ideas
If U have windows bootable CD boot it from an external dvd/cd drive and go to repair. and can use fdisk command to restore boot manager.
Apr 03, 2011 | Dell Inspiron Mini 10 Notebook
TFGHT FILE IS COMPRESSED PRESS ALT+CTRL+DEL. FROM DELL INSPIRON MINI NOTE BOOK. ANY SOLUTION?
Jan 28, 2011 | Dell Inspiron Mini 10 Notebook
My dell inspiron mini 10 bootes up to the main sceen but no icons nor start button appear.. please help
ok try starting in safe mode, keep pressing f8 on startup till menu appears, then run system restore if safe mode works
Aug 30, 2010 | Dell Inspiron Mini 10 Notebook
Touch pad and keyboard do not work after re boot on dell mini inspiron
Get a USB mouse, click start then right-click computer then select manage. Uninstall your mouse and keyboard driver then restart your system. Windows will automatically reinstall the drivers and you might need to restart your system again.
May 30, 2010 | Dell Inspiron Mini 10 Notebook
Services are erased and I cannot see start button and cannot use system restore. Please help.
Hi. Press Ctrl+Alt+Del and choose Task Manager..
Click New Task and type: explorer.exe then press OK...
Your start button should appear as well as other icons... ^_^
May 21, 2010 | Dell Inspiron Mini 10 Notebook
I have an inspiron mini 10 and it is saying BOOTMGR is missing when I hit ctrl alt del to restart the same error message comes up
I would do a Windows Repair. Find your green Dell CD that shipped with the computer and boot to that. You may need to enter Setup to change the boot order.
Instructions here: http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/tips/doug92.mspx
This will not harm your data, it repairs just the operating system.
Mar 08, 2010 | Dell Inspiron Mini 10 Notebook
Boot mgr is missing
Boot Manager is missing If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529 More Info MS KB 927391 Check points for fixing missing boot-manager: Check that your boot device is configured properly Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". Boot Manager is compressed If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart OR maybe try this first. Check points for fixing compressed boot-manager: Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files. If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands: compact /U C:\bootmgr compact /U C:\ntldr If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands: attrib -c c:\bootmgr attrib -c c:\ntldr
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer Aspire 8920-6048 Notebook
Boot Manager is compressed???
here are two solution:
1.
"BOOTMGR is compressed. Press Ctrl+Alt+Del to restart"
compact /U C:\ntldr
attrib -c c:\ntldr
2.if the above solution did not work for you try this easy way:
reboot, push open the dvd drive, load OS Vista CD/DVD, before the ridiculed bootmgr compressed shows, shutdown, boot from the dvd, let the installer do it’s job.
when reach choice “install now” choose “repair the pc” instead.
In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
click Startup Repair.
Just click “load drives”since you know the answer about “repair”….nothing wrong..)=:
see that??, you’re inside your HD!! I assuming that from here everybody knows what to do, if not, that what follow:
Browse for your “C” Drive, right click properties and fellas, reverse what you did, exit, reboot.
Feb 05, 2010 | HP Mini 1000 Notebook
Dell Inspiron Mini 10 Notebook Logo
16 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
