Question about Irons
Steam iron My tricity iron stop working. not light not hot nothing
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
jaylex
  • 417 Answers
SOURCE: Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Posted on Feb 11, 2008
SOURCE: No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Posted on Feb 25, 2008
SOURCE: Hinari steam vapor iron Model HIN001
More complete answer...
If you are having steam problems then the cartridge needs changing.
I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
Send Cheque for £5.99 for each cartridge with note of model etc.
Pulse Home Products Ltd.
Middleton Road
Royton
Oldham
OL2 5LN
Posted on Oct 07, 2008
  • 244 Answers
SOURCE: I have a Bosch Steam
Your steam generator my have mineral deposits that are clogging the steam openings. One of the easiest things to do is to pour out the water and add white vinegar. Let the vinegar sit for about 2 hours. Then turn on the iron and press the steam button until the deposits are loosened and flushed by the heat and steaming vinegar. Do this on a towel or other absorbent fabric so you don't stain your ironing board. You may need to unplug the iron, let it cool and then gently **** the steam vents with a wooden skewer or toothpick.
I hope this helps you. If it does, please rate my suggestion!
Posted on Jun 02, 2011
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Apr 12, 2016 | Rowenta Irons
Why has the steam function has just stopped working - power on but nothing happens
My wife has one of these irons and she loved it. Now it steams for a while, and a red light starts blinking and it stops steaming. It can be turned back on and works for a while, then the same thing happens. I read that it needed descaled, so I bought OUST descaler and ran it through the iron, but it did not solve the problem. Any one have a solution to this problem, I would like to hear from you.
Jul 07, 2014 | Rowenta DG8430 Pro Precision Steam Station
I have a bosch TDS25 steam generator iron and when I plug in and switch the iron on the green light light does not come on
if the iron is still getting hot and generating steam i would say the light has failed, however if nothing is happening you could change the fuse in the plug if you now how if not get some one who dose and if this dose not help then i think your iron has had it
Oct 01, 2011 | Bosch Irons
I have so far seen 3 other people with the problem i have with my russell hobbs steam glide iron 13153. I have tried what was suggested to me but nothing has worked. the iron gets hot but no steam coming...
I would write to russell hobbs and complain, my friend bought one of these 18 months ago and hers got hot but no steam through. She sent it back to them and they sent her a new one as a gesture of goodwill.
Aug 04, 2011 | Russell Hobbs 13153 Iron
Iron stopped working suddenly
perhaps the thermostat is sticking.as irons are cheap to replace i would try cleaning /soaking the tank to remove lime scale. or strip the iron down checking thermostat and conections.
May 01, 2009 | Tefal UltraGlide Easycord FV4256 Iron
SHARK STEAM STATION G6200 SUDDENLY STOPPED WORKING.
take it back to the store and tell them what has happend the only thing i can think of is that one of the wires has come loose within the cable
Apr 21, 2009 | Euro-Pro Shark GI490 Iron
Middleton Road
Royton
Oldham
OL2 5LN
Aug 24, 2008 | Rowenta Surfline Iron DE-333 Iron
Euro-Pro Steam Generator G6200H iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 18, 2008 | Euro-Pro Steam Generator EP8001 Iron
Irons Logo
26 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
