Question about Hamilton Beach Kitchen Appliances - Others
Cook doesn't work. goes to warm
Warm no cook ligt
MY stop/clear button doesn't stop all the time.
It may be making noise, and the light comes on, and the turntable goes around, but I'll bet it's not actually cooking (although that CAN happen). Try putting a cup of water in the microwave when this happens and see if it gets warm. If it does NOT get warm, then you just have a bad door switch. If it DOES get warm, then you have a stuck relay on the control board, and the control board will have to be replaced.
Oct 15, 2014 | Microwave Ovens
One Pot Cooker does not cook
Is this a slow cooker? If so , it doesn't get hot, you cook casseroles in it for 8/10 hours, prep all your veg and meat, saute in a deep frying pan, add stock or a casserole mix, bring up to boil, tip into your cooker, switched to med/hot and leave, the ides is that you do prep night before and cook overnight, or first thing in morning and leave to cook all day
Jun 15, 2012 | Coffee Makers & Espresso Machines
Dough doesn't rise
Yeast is likely too old, buy a new one and try again - if it works, toss out the old yeast. If the results are the same, your unit is bad. Is it getting warm/hot while operating?
Mar 29, 2012 | Black & Decker Bread Machine
Pilot light stays lit but oven will not stay lit
I would be interested to know just how long it is that the oven does stay lit. All ovens, gas and electric, cycle off and on throughout a baking cycle, to maintain the proper temp. If the flames or the power to the element were to stay on at full power for the life of the food's required time in the oven it would most likely wind up charred. The temp would simply continue to rise, up and up and up. If that's what it appears to be doing, then it's just working normally. If it goes out completely and stays off, doesn't come back on in a few minutes, then it may be in a keep warm mode. Many ranges have a TIMED BAKE cycle available, so you can set the clock to start the oven at such and such a time, cook the food and then shut off. Once it's finished with the cooking cycle, it goes into a keep warm mode, where it will come on for a short time and then go off, to maintain about 180 degrees. Not hot enough to really cook anything anymore, but hot enough to keep it warm for you when you get ready to eat.
If this seems to be the way it's acting, then look for the timed bake function on the console and set things back to a manual mode.
Apr 22, 2011 | Kitchen Ranges
When i plugged my cooker in the numbers started flashing all zeros and now none of the buttons will change the screen except the cancel button. When that's pressed the screen goes blank for a second it...
I am having the same problem. Here is what the Tiger people say. I haven't tried it yet though.
* If an external power failure has occurred, but only for a short time, then there's a possibility that when the electricity has returned, all functions may work normally and the clock is working correctly.
* When a power failure lasts for a long time, and the indicator is flashing 0:00...
--> Please set the time correctly by following the instruction manual.
If the electricity has returned as in these situations below:
(If it's already past the set time, after a lengthy power failure, cooking starts immediately.)
* While cooking rice (or reheating rice).
--> Continue to do the cooking (or reheating).
* Keeping warm (or Low temp Keeping warm).
--> Continue to keep warm (or low temp Keeping warm).
Aug 25, 2010 | Tiger JAE-A10U 5..5-Cup Rice Cooker
The micowave will not heat or cook anything
PLEASE HELP ME TO FIX THS PROBLEM....
Mar 10, 2009 | GE Microwave Ovens
Rice cooker goes to "keep warm" mode before rice is cooked
bad thermostat . there are no parts made for this model . sorry
Jan 17, 2009 | Tiger JNP-1000 5.5-Cup Rice Cooker
Kitchen Appliances - Others Logo
Top Hamilton Beach Kitchen Appliances - Others Experts
ken skalski
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
