Question about Numark x2 Hybrid Turntable
How to fix my numark traget light
I have a target light but it wont come on. When I plug it in. Is there a fuse or something I can check.
Fixing a audio mixer
That's something that an authorized repair shop will need to fix. Contact support@numark.com about the issue, and they'll let you know what the nearest repair shop to you is.
Nov 12, 2012 | Numark M4 Dj Mixer
I bought a target pre-lit christmas tree but half of it wont light up even though its all plugged.How do we fix it?
trystarting from the point that bulbs aren't working,take one of the replacement bulbs that usually come with the lights and replace them one at a time.just one replacement bulb to start then the one you took out put it in the next until either it lights up or you reach the last unlit bulb,but hopefully you dont get to the end because if you do then there's more then one bulb thats faulty. I've had that happen alot so dont give up..If the lights are on two separate wiring check for a glass fuse hidden on either ends of plug(wall or tree) I hop that helps.
Dec 03, 2011 | Cars & Trucks
I am not able to play DVD and CD in my Sony DVP NS51P
Have you tried cleaning the player with a disc made for cleaning optical drives? These such units are available at retail locations such as Traget and Best Buy.http://www.target.com/Memorex-DVD-Laser-Lens-Cleaner/dp/B000P0OJ8O/ref=sc_qi_detailbutton
May 05, 2011 | Sony DVP-NS51P DVD Player
Hello i have the numark cdn95 2 disc cd player had a power outage in my home i did not have my numark cdn95 plug up to a surge and when i push the power button the buttons key lock light up and it wont...
Hi. Here is a link to a free download of your manual http://safemanuals.com/user-guide-instructions-owner-manual/NUMARK/CDN95-_E
Often times, a surge will require going into the machine and replacing one or two fuses. This is not an expensive job. Most all stereo shops have the capability to do this for a few dollars. Joe
Oct 21, 2010 | Numark CDN95 2-Disc CD Player
Checking fuse for parking lights now my car wont 94 Lincoln Mark
You may have not plugged the fuses all the way in. Or maybe you had a bad connection in one of them. Just by unplugging and plugging the fuses should not cause this problem. Make sure all fuses are good and have good connection.
May 15, 2010 | 1994 Lincoln Mark VIII
Numark Axis 9's wont turn on
1. Check for internal fuse.
2. Check the power transformer.
3. Check the rest of the power supply.
Aug 11, 2009 | Audio Players & Recorders
Acard 1 to 3 duplicator can't seemto get past the traget disc not ready
of course theres a problem but what are you doing with the thing? are you formaating the disk first to render the dvds in the target drives? are you using the right DVD like DVD+ DVD+- or Blueray? need more information to help you. and it the DVD you are copying has been redered on another machine it won't copy it anyway. You have to use the same machine to copy it as thats how they protect copy rights now days.
May 29, 2009 | Computers & Internet
It wont turn on!!
Are you getting no power what so ever from the turntable? No lights, or leds?
Oct 23, 2007 | Numark TT1520 Turntable
LOST INSTRUCTION MANUAL
WHEN I AM SWITCH ON MY POCKET PC IT IS SHOWING ME (ALIGN SCREEN) AND TTAP THE TARGET FIRMLY AND ACCURATELY AT EACH LOCATION ON THE SCREEN .THE TRAGET WILL CONTINUE TO MOVE UNTIL THE SCREEN IS ALIGNED.
WHAT IS THE PROBLEM REPLY ME DETAILY
Oct 14, 2007 | Compaq iPAQ H3660
Numark x2 Hybrid Turntable Logo
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Electro Med Services...
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
