Question about Toshiba Tecra M2 Notebook
IDE #0 ERROR
Dear Sir/Madam,
Every i boot my laptop toshiba m2 appears IDE #0 ERROR message. pls help how to solve it or any software to download to fit this error
tks
frankie
  • Anonymous Nov 02, 2007
    Model Number Toshiba Tecra M2
    PTM20U-4MP0E701
    Serial No: 94065158HU
    IDE #0 ERROR when it is booting
    Tks for your solution
    Frankie
    Scholar:
  • 134 Answers
It sounds like there is a hard-drive problem. To help you further I would need your complete laptop model number. If your hard drive is indeed dead, most likely it's not too difficult to replace and a 2.5" hard drive is not that expensive.
Hope this Helps
Posted on Nov 02, 2007
  • Alex J.
    Alex J. Nov 02, 2007
    Well after checking for your specific model, the hard drive is extremely easy to replace! It's most likely that the hard drive went bad, as i said before you can buy a 2.5" hard drive for about $100.00.
    When you turn your laptop upside down it's located on the bottom left corner, 2 screws are probably holding the cover, then just swap it, not forgetting to take the connector from the old one and put it on the new one. You will need the systems disks, hopefully you got them from toshiba. Putting it in ur cdrom will start the install, after that, it's pretty self explanatory.
    Otherwise you can always let a store do it for you.
    I might write an article on this in my website www.customautomaticsystems.com as this happened to me before.
GO TO HELL
Posted on Jul 11, 2008
I need to reset tecra m2 to factory settings, 0 option does not work or f8 pls help??
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Apr 09, 2013 | Computers & Internet
Hi I have a Toshiba Tecra M2 laptop with Windows XP Pro SP3. My CD-RW/DVD-ROM/CD-ROM drive is not working. When I try to burn a disc, it says no recorder, or no disc in drive. Also, Windows doesn't seem to...
>> it says IDE #1 error when it boots up.
IDE #0 is your disk-drive.
IDE #1 is your CD/DVD drive.
So, take your computer to a qualified technician, to first check that the connectors (power, data) from the motherboard to the CD/DVD drive are good, and then, if necessary, to remove & replace the "dead" drive.
Oct 27, 2009 | Toshiba Tecra M2 Notebook
IDE#0 ERROR
Usually the HDD is set on IDE #0.
The PXE error appears if the notebook tries to boot up from the LAN but the cable is not connected or there is no possibility for LAN booting.
In my opinion there is something wrong with the HDD or the BIOS cannot recognize the HDD correctly. I would recommend checking the HDD pins. Furthermore you should change the booting order in the BIOS.
Apr 24, 2009 | Toshiba Satellite A100-S8111TD Notebook
Boots up .. on logon goes into shutdown ... safe mode no better
pls restore ur OS like this see if it helps pls le tme know if i can help more b4 rating me and Rate me FIXYA if solved
BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
Mar 18, 2009 | Toshiba Satellite A205-S4617 Notebook
Toshia IDE #0 ERROR comes on the screen about 2 mins after starting then as follows is on the screen. .Intel (R) Boot Agent FE ver 1.10.PXE-E61 Media test failure check cable. PXE-MOF:Exiting Intel Boot...
This error is telling you that either one of three things have happened. 1. Your hdd cable has come loose or failed. 2. Your HDD has failed, or 3. the IDE controller on the motherboard has failed. You can check problems by trying a known good hdd in place of your old hdd. If bios sees it then it is the drive itself that is bad not the cable or controller. If it does not see the good hdd then try replacing the cable. If this fixes the problem then remove good drive & replace with your old hdd. Problem should be solved. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 14, 2009 | Toshiba (MK8034GSX) 80 GB IDE Hard Drive
Sir/Madam when i attached my external 30gb hdd via usb ide data cable with my laptop message appear "unrecognized device" how i solve this problem?
You need the driver for the device. If the HDD came with a disk you will need to install that beore hand. =) Hope this works.
Ed
Jan 31, 2009 | Toshiba (HDD2181) (hdd2181-50pk) 30 GB...
Toshiba Satellite laptop boots up but shuts down on its own very shortly
Hi JOJO0803,
Based from the error message you're getting it sounds to me that your problem there is not software related but is more hardware in nature.Since you're getting a message "disk read error occurred IDE#0" this pertains to a problem with the hard drive itself. It's possible that your hard drive developed bad sectors or errors on the disc itself.
So to be sure I would recommend that you run the hardware diagnostics for your laptop computer especially the one for the hard drive since you're getting this message. If the hard drive fails the test or any other part fails in the test, contact your techsupport and ask for replacement parts if your PC is still under warranty. Otherwise you may have to buy parts for your laptop.
If the hard drive tests passed and all the other hardware tests also passed then you may proceed to troubeshoot the software using the Windows XP Home CD. Boot from the WinXP Home CD, and you get to the setup screen, choose "R" for recovery console and then on the prompt type "CHKDSK /R" let it run, it may take a while. afterwards it will bring you back to the prompt then type EXIT and it will reboot the system, see if that fixes the problem. Worst case scenario you may have to format then reinstall Windows XP again to fix this problem.
Hope this helps!
Peace! :)
Oct 23, 2008 | Toshiba Satellite A105 Notebook
IDE 30 ERROR
re insert the HDD and try again or else go in the cmos if it is detecting or not..if not detecting,maybe it is loosen in connection or else the HDD is DEAD...
Jul 11, 2008 | Toshiba Tecra M2 Notebook
Error on laptop during startup
The IDE0 refers to the HDD ide cable connector. It may be faulty or the connection from the motherboard. When booting up pres F2 or Del to see if your HDD is being recognised, if not the cable will ned replacing.
Feb 10, 2007 | Toshiba Satellite A40-S161 Notebook
I have Qosmio E15 and it wont boot
Go here: http://www.hitachigst.com/hdd/support/download.htm#DFT And download the drive fitness test, burn it to a .ISO bootable CD, and boot from the disc. Run a FULL SCAN and it will tell you if the HDD is bad, which is highly likely.
Aug 30, 2006 | Toshiba QOSMIO E15-AV101 Notebook
Toshiba Tecra M2 Notebook Logo
690 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
