Question about Insignia IS-LCDTV32 32 in. Television
How to remove back of tv - Insignia IS-LCDTV32 32 in. Television
    Top Expert:
  • Insignia Master
  • 75,178 Answers
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magzine" will make surf easy Pull up older posts. Surf the site with patience.
Disassmble procedure to many popular brand TVs' are given with illustrations.
Posted on Apr 19, 2014
How to remove the Base from a Sharp LC 46D64U TV
No.
Stand or base on any model of TV should be removeable without taking the back panel. How to Remove Pedestal Stand from Your TV YouTube
Oct 31, 2016 | Sharp Televison & Video
How to I remove the back cover on a Toshiba 50L1350UC LED TV. I have removed all the screws as I have on dozens of other tv repairs, but can't seem to see how to remove this back cover. Thanks.
Toshiba TV Repair - Replacing 26AV5 Backlight Inverter ...
? 2:36
https://www.youtube.com/watch?v=ZoAn6ovLVXc
Apr 22, 2013 - Uploaded by ShopJimmy.com
There are various ways to eliminate static electricity, but the most common ... Return the back cover to its original position and secure all screws. .... Hi I am having problem with my TOSHIBA46TL963 TV 3D LED TV WITH NO ...
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
Free Fix For Toshiba 50" TV That Will Not Turn On. ... Removeall; Disconnect. Watch Queue. Queue ... p.s. could they put more screws in that back panel? .... Now the TV turns on, so does theLED backlight, but NO PICTURE!
Toshiba TV Repair - How to Replace 75021540 Main Board ...
? 2:38
https://www.youtube.com/watch?v=AUOAQR_raTA
Feb 28, 2013 - Uploaded by ShopJimmy.com
Toshiba TV Repair Main Board Replacement for LCD TV Fix No ... Unscrew and remove the back cover. ... LCD & LED TVRepair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD & LED TVs - Duration: 5:56.
Jan 17, 2016 | Toshiba Televison & Video
Fuzzy picture...direct cable says its in the tv itself...unplugged ,plugged back in removed coaxial and replaced checked all plug ins to no avail..
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV by removing lots of screws at back to clean it inside.
Thanks.
Apr 18, 2011 | Televison & Video
Remove stand on a Sony KV-35V75 television
I have not known of any Sony tube TV thay was attached to the stand in any way with exception of they had a cloth strap in the center in the back at the bottom of the TV that buckled into a pocket on the back of the TV, but nothing in the front, usually the TV just lifted straight up or slid back about 3 inches then lifted up, that is all I remember on that other than the TV is very heavy and maybe it is just stuck from being on the stand for a long time. Good luck!
Dec 27, 2009 | Sony KV-35V75 35" TV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
How to install a SONY LAMP XL2400 into your TV
remove 2 screws from bottom back of tv(plillips) now carefully remove front cover.it unclips,sometimes you have to pry it off.take out screws from lamp cover,remove cover,take screws out of lamp, remove lamp.reverse process to put it back together.
Sep 19, 2009 | Televison & Video
How to remove stand from panasonic tv model no tx-32 l m d 70
Place tv on its BACK,with the screw holes underneath.Remove the four screws,remove stand,and turn tv over to rest on the sceen (on top of a towel)or some other cloth so as not to damage the screen,and replace screws.The reason for placing the tv on its back when taking out the screws,is that,unless you have a magnetic screwdriver when removing the screws the are difficult to remove as they are deeply recessed.
Apr 09, 2009 | Emerson RP6248 AM/FM/TV Radio
Putting the tv stand back on the tv
these are removal instructions should be helpful though
Open up the panel on the back of the TV which covers the various input connections. At the bottom of the area previously covered, there are 8 screws (two rows of four screws). Remove them, and the entire stand should now slide right out of the TV. You can then replace the screws back in their holes, so you don't lose them. You do not need to disassemble the stand to do this.
Mar 09, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Insignia IS-LCDTV32 32 in. Television Logo
22 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
