Question about GE Refrigerators
Overhead the refrigerator that I'm looking for mounts on the wall above the counter. Is there anyone still making this type of refrigerator?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 118 Answers
Are you looking for a specific Cubic Feet?
Posted on Jun 17, 2014
How to remove overhead kenmore 1000 watt microwave
Unplug the power cord and make sure it will come out easily when you start to take out the mounting screws.There are 2 or more screws in the cabinet floor above the microwave. Be ready to catch the microwave once the last screw is removed because it will drop in the front. Then lift the back of the case off the tabs on the wall mount bracket and the whole thing is in your hands.
Sep 23, 2014 | Kenmore 63792 Microwave Oven
I need to know if the kenmore microwave hood combination modle number 02285039000 will be abale to be mounted by using a wall mount only. I do not have an overhead cupboard.
Sorry but you must use the Overhead cupboard.
The wall mount is just for support.
The main wight of the unit is held by the top.
Mar 14, 2013 | Microwave Ovens
I don't know how to take my Gatco 4515 "Tiara" Robe Hooks off the door now that I'm moving. Please help. Thank you.
I'm not 100% sure about this model, but I have a similar hook by another brand. Here's how mine is removed:
When you look at the hook, there's a small hole at the 6 o'clock position, (pointing down, right next to the wall.) This hole is actually a set screw that can be turned with a small hex-key (aka allen wrench)
thomascha103_7.jpg The size needed is pobably about 2 mm, or 1/16 in.
Turn the set screw counter-clockwise for a few turns to loosen the hook from the mounting bracket. When the set screw is backed out far enough, the hook will detach.
After he hook is removed, you'll be able to see the mounting bracket that is screwed into the wall. Remove the screws with a screwdriver, and take the mounting bracket with you. You'll need it to attach the hook to the new wall.
If there is no set screw or hole visible from any side, then your Gatco hook might be removed from the mounting bracket by twisting the entire hook counter-clockwise.
If anyone else out there has experience with this particular brand, please chime in and correct me if I'm wrong.
I hope I've been helpful. Good luck.
Jan 19, 2011 | Gatco 4515 Tiara Robe Hook Bathroom...
My geberit in-wall toilet won't stop running, and there is no way to access any type of plumbing fixtures to fix. Please help me!
Shut off main water supply
shut off water value going to your wall mounted toilet.
look under your apartment or the room ajoining the wall unit.
look for hidden wall space above unit
Nov 29, 2010 | Duravit 111335001 Geberit In Wall Carrier...
What is an Overhead Projector?
An overhead projector is a very basic but reliable form of projector. The overhead projector displays images onto a screen or wall. It consists of a large box containing cooling fan and an extremely bright light, with a long arm extended above it. At the end of the arm is a mirror that catches and redirects the light towards the screen.
An overhead projector can be used to enlarge images onto the screen or wall for audiences to view.
Aug 12, 2010 | Buhl Office Equipment & Supplies
How to remove from mounting
if its an under counter set-up,then remove the 2 screws inside the cabinet above the unit and lift out of angle bracket mounted to the wall,use 2 people to be safe when doing so
Apr 15, 2010 | Kenmore 61689 Microwave Oven
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Balancing problem Frigidaire stackable front load washer/dryer
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 21, 2009 | Kenmore 98702 Stacked Washer/Dryer
Motor works but does not move chain on half horse sears
Clutch? need more info.. wall mount or overhead? If it's wall mounted it could be the clutch, I don't think overheads have a clutch though. The first thing I'd do is get on a ladder and see if the chain is still attached to the sprocket... good luck
Feb 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wall mounting needed for a top mount microwave/hood combination Whirlpool Model MH2175SB1. The cabinet above the stove is too flimsy to support the heavy microwave (50-60 pounds). Called Whirlpool. Sent me...
Is there a wall behind where the microwave is to fit?
Most of these ship with a mounting plate and instructions for mounting to the wall. In fact, the wall bracket carries about 1/2 the weight, and the overhead cabinets carry the other half. The plates come with a good set of instructions for how to install.
Whirlpool is sending you to a distributor because they have to watch liability in this litigous world we live in..
Jan 29, 2009 | Whirlpool Microwave Ovens
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
