Question about Tablets & eReaders
Nextbook nx007hd If you put SD card in then go to the storage In the settings it will say "setting is now shutting down"
    Guru:
  • 135 Answers
Try restart maybe it needs to reresh its storage devices and doesnt support hot swap
Posted on Apr 19, 2014
I put an sd card into my tablet but my apps does not give me an option to save to sd card. What am i doing wrong. Not good at this stuff so help.
If it's an android, you can change it within an app - like camera. Go into settings and change default storage location from internal storage to sd card.
If the app can't see your sd card, make sure it's "mounted" within your device. Depending on the software version: Go to settings, general, phone/tablet management, storage, from here you should be able to see the sd card. It is either ejected or mounted. Click on the sd card, if you can see the folders content, then it is installed correctly.
Also, if it was used in another device, it may need to be formatted to be used in your tablet. You can do that from the same setting menu.
Hope this helps.
Jan 01, 2018 | Tablets & eReaders
How do I get the 7 in irulu tablet to see an SD card I put in the slot so I can move apps over?
sd card is automatically recognized, however you need to
- set default storage as sd card
- also move apps and data to sd card from memory/storage setting menu individually.
Yet many apps occupy main ram and refuse to release space
Aug 29, 2016 | Tablets & eReaders
How do i set my tablet to auto save to my SD card
There are several methods to help you set download application path to SD card by default.
Please follow the steps given below,
Method 1:
- Insert the SD card into the device, Touch 'File Browser' on 'Home screen'.
- Tap 'Apps', On Apps, select the 'App to be installed'.
- Tap OK to install the App to SD card.
Method 2:
- Tap 'Settings' on 'Home screen'.
- Tap 'Storage', Check to turn on SD card, and set 'SD card' as the default storage place.
Method 3:
- On your Android tablet or phone, tap the 'App drawer' icon from the home screen.
- From the displayed list, tap on the 'My files' icon.
- From the opened window, on the top right corner, tap the icon with four horizontal lines.
- From the displayed menu, tap the 'Settings' option.
- On the opened Settings window, under 'Select directories' on the left, tap the 'Set home directory' option.
- From the window that appears next, tap to select the desired folder or the entire external SD card where you want the files to be downloaded by default.
- Tap the Done button from the top right corner of the window when you are done.
GuruAid.com
Jul 22, 2016 | Polaroid 7-in. Internet Tablet - Other
Have. Gigaset qv830. I've put in an sd card. When I download book to kindle app how can I save to sd card and not on tablet?
Go into "storage" in settings and then scroll down to the Kindle app. Select "move to SD card"
Mar 13, 2016 | Tablets & eReaders
How do I download apps onto this device?
The default on most tablets is to install apps to internal storage so the SD card does no good by itself. You can go into Settings>Applications and change the location for each app to the SD card. Likewise anything else you put on a tablet, particularly photos and videos get stored in internal storage. If you have taken a lot of photos and videos they can fill up your storage quickly. You can change this in the Camera app by tapping the settings icon and changing the storage option to SD card. You will still need to actually move existing photos and videos to the SD card manually or copy them to external storage and delete them. I would also change the image and video resolution in Camera settings to 640x480. This is plenty good enough for pictures you just want to look at on the device or share online.
Jan 04, 2016 | Trio Stealth G2 7 inch Tablet with 8GB...
How do you move internal storage to the sd card to free up internal space
touch the "Settings" icon, go down to the "Device" area, touch the "Storage" icon : go to the bottom of the screen, and select "Transfer data to SD card", then select the items you want to move.
You should also move some apps from internal storage to the SD card : "Settings", "Device", and touch "Applications" : then touch each and every application : for most of them, the button "Move to SD card" will be active, just proceed.
Dec 18, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
How do I use sd card storage
Hi if you want transfer your apps on sd card go to setting- application manager- choose the app and there you will see a move to SD card button, just press it and after a while your app gona be transferred to memory card. You need do it for every app sepretlly. If you want store a photo's on it go to camera- setting and there press storage and choose memory card. With music create a folder music on it using my files and player should detect it automaticlly if not navigate there.
If you need more help let me know.
regards
Dec 14, 2014 | Samsung Galaxy Tab Tablet PC
Why am i getting insufficient storage error when downloading if i have 10.3 gb free?
Go to your settings. Then to your apps. When you click on the app, you will have the option move to your sd card. Do it. Do the same with your photos, videos and music files. That is what your Sd Card is for. Once this is done you will have plenty of space on your internal memory to download what you want.
Sep 03, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
How to put photos on my sd card
This more than likely means your internal storage is low and not the SD card and may not have anything to do with your pictures but more so with your apps. Go into settings and see if your tablet has the feature to set where your downloads and other media is stored, by default that will be your internal memory. change it to SD card or USB storage. In Settings you can also click on your apps individually and transfer them manually one by one to the SD card or USB storage or download a file manager and do so all at once. Some apps and files may not have the feature to transfer these apps the tablet came with or apps you downloaded that uses the internal memory. By default if a memory card is in you tablet pictures are automatically store there, if this is not the case the easiest way to transfer is connecting the tablet to a computer/laptop and transfer to the card or again use a file manager.
Aug 15, 2014 | Acer Iconia Tablet with 8GB Memory - Steel...
What does code 912 mean? i get this when downloading apps from apps store
There are a few reasons why you would get a 912 error when downloading apps.
  • Downloading apps directly to an SD card
  • Play Store (app store) needs to be updated
  • Bad cache
The following methods could help solve the problem
Clear Cache and Reboot
  • Go to Setting >> Go to Application Setting (In some devices application setting is named as apps).
  • Go to, All the apps > >Find the Google Play Store >> Clear Data and Cache
  • Once you have clear everything, Next you need to Force Stop the application
  • Also, try to clear Cache and data of Download Manager and Google Service Framework.
  • Now, Restart your device and try to download the app.
Unmount SD Card
  • Go to Setting >> Storage >> Scroll down and select "Unmount SD card"
  • Open Google Play Store >> Download the app again that was giving you the error message
  • After successful installation, Go back to Settings >> Storage >> tap on "mount SD card"
  • If above steps didn't work, also try removing your SD card before installing.
Move app to phone
  • Go to Settings >> Go to Apps >> Select, All the apps
  • Scroll down and select the app that was giving you the error during update
  • Select "Move to phone"
  • Open Google Play Store and update the app
  • After successful installation, you can move the app back to SD card
Feb 01, 2018 | Tablets & eReaders
Tablets & eReaders Logo
174 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
