Question about LG Televison & Video
Lg vcr hello problem
Displays hello but no buttons work except power and eject tAPE
  • 883 Answers
SOURCE: Tape ejects just after insertion
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Posted on May 20, 2007
  • 139 Answers
SOURCE: VCR tape won't eject
The flap on the door stays open until the tape is ejected. There are two possible ways to remove the tape. First, with the power off, try to locate the drive pulley or gear on the side of the tape housing. It may be possible to turn it with your finger and cause the tape to eject. The eject mechanism will move VERY slowly when you use this technique.
The second way to do it should normally be done by an experienced technician, because it involves taking it even farther apart...and it may be difficult to reassemble. There are typically four screws that hold the tape mechanism in place...two near the top front and two near the back. It should be possible to remove those screws and pull the entire mechanism out of the VCR. Then you can more easily rotate the eject pulley (or gear) and remove the tape. If this sounds a little scary, I would definitely recommend placing the top back on and acting like nothing happened!
Posted on Mar 17, 2008
  • 8 Answers
SOURCE: flashing auto display - won't power up
The infra red light in the middle of the mechanical deck, that powers the left and right photo sensors is not ok.It looks like a small lamp( you cant see it when it works-Infra red mind it).The video cassette has a large round opening in the bottom towords the front, and accomodates this lamp.please check it out.
Posted on Apr 28, 2008
SOURCE: GE vcr tape stuck
when this happens to me, i disconnect the vcr and remove the screws to the top cover. i remove the cover and carefully remove the tape, being careful not to touch any of the parts of the vcr. but please make sure the vcr is un plugged.
Posted on Dec 08, 2008
SOURCE: SONY VCR: Keeps ejecting video tape
may be machnical stuck in playback mode. remove the cover and see the loading arms are near the video head , if not try to release the arm rotating caption wheel smmothly . don't push more force to rotate the wheel.
Posted on Jan 15, 2009
VHS tape is running at high speed when insert it to VCR. no playback..buttons doesnot work.
Check if the fast forward button is more inside than the rest of the buttons. May be its stuck in the ff position. After all they were just micro switches below the plastic buttons strip. The specific ff micro switch may be stuck, if I were you I would try some switch cleaning spray to loosen it. But be prepared that the control ic is busted.
Jun 21, 2014 | Panasonic Televison & Video
Err on display when insert tape, no functions work.
Two things. First there is some damage to the tape transport mechanism. Only a good look around will confirm this. Secondly a faulty mode switch.
Jan 14, 2013 | GE VG4250 VHS VCR
I have a philips DVDR3510V ( DVD/VHS Recorder) which is 16 months old. The problem is that the buttons on the recorder do not work ( except power button) . We thought we had got round this as the remote...
I can only speak to getting the tape out. If all else fails, you can take the player to your local best buy and have them remove the tape for a minimal fee of no more than 30$.
Jul 18, 2011 | Philips MWD2205 DVD Player/VCR
My Aiwa HV-MX100 vcr has not been used in about 18 months. When I insert a tape, I can hear a whirring noise, but the tape will not eject properly. Also, the power will not shut off completely - the...
Is your VCR fixed?
From what you have written, I understand that you have not used the VCR for many months. And since you are hearing a whirring noise, the eject motor is working, but the belts are spoilt, and are slipping. Hence your problem. I suggest you open the top cover of the VCR and observe the eject mechanism. As suggested, you will - in all likelihood, observe that the belt driving the eject gears is slipping.
May 27, 2011 | Aiwa HV-MX100 VHS VCR
I got an LG VCR GC980NW (MG 64) VHS VCR. I've wrongly pressed both the eject and play forward button at the same time. After that, the VCR shows both the 'EJECT' message and 'No Tape' signal, and then...
It is possible that the mechanism is out of mode as the front cassette loading mechanism and the tape forward loading mechanism have gone out of sync. Now it is important that the MODE of the system control is in the correct parking.
Hence I feel that the VCR must be opened and the mechanism reset-ted. Make sure that the tape loading has come back to the correct parking and also the cassette loading has returned, other wise remove the mechanism and reset.
Apr 05, 2011 | LG MG64 VHS VCR
Tape stuck in vcr. when you press the eject button vcr starts to work but shtuts off the power Model number DVR-3034N. I have only taken the front and back covers off. Turned slanted roller untill the...
It sounds like the tape is jammed in the vcr, remove the top cover of the machine this will expose the tape. If the tape is spewed in the mechanical section and around the video head, get a pair of scissors and start cutting the tape and carefully remove all tape particles, when all tape debris has been removed, plug in vcr turn on and eject. If the tape looks good, you may have a loading basket problem, bad idler ***. or broken drive belt. "Lets hope for the best"
Jan 25, 2011 | Emerson Televison & Video
JVC HR-S9500 S-VHS VCR. all functions work except the eject on the vcr. there is no eject on the remote.it plays, ff, rew, stops etc. I can't get the tape out.
the eject button is a plastic piece that turns and pushes down on the board and is more then likely broken open the vcr take off the front face plate and check the button, it will propaply fall out. you can use super glue and glue the button back in place
Jan 05, 2010 | JVC HR-S9500 S-VHS VCR
Orion vcr troubles
hello . yes u have a belt slipping.that's what make's the tape eject. from the vcr. and you can fix it your self also.
Jun 29, 2008 | Televison & Video
MINI DV TAPE WON'T LOAD
First power off the unit, then remove the DV's tape housing , power up the unit, and allowed the mechanism to go back to the unload mode, make sure that the tape posts are at unload mode. then unplug the vcr back again, put back the tape's housing in the load position (tape in) power the vcr back on and push eject button to reset tape mechanism.
Jan 16, 2008 | JVC HR-DVS3 Mini DV/S-VHS VCR
VCR Tape playing problem
The mean time between failure for the rubber parts in a VCR is about the same as the rubber parts on your car - about 5 to 7 years. You are due for a belt job.
Dec 29, 2007 | Televison & Video
Televison & Video Logo
32 people viewed this question
Computer Repairing
Computer Repairing
