Question about Marzocchi Fork Oil - Fork Oil 7.5 weight
How do I change the fork oil on a 2004 ktm 50sr lc
Changing fork oil
Remove forks from bike, with each fork remove end cap and drain plug over a bucket drain oil from each fork reinstall drain plug on lower leg, replace oil thought top of the fork to spec, replace end caps and bleed oil from forks
Apr 18, 2014 | 2004 KTM 50 Adventure Senior
How to Change the Fork Oil on a 2004 Yamaha YZ250
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2006 yz250 front fork oil change break in
How to change fork oil on an Dirtbike
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 16, 2013 | 2004 Yamaha YZ 250
Fork oil capacity for KTM 200 EXC 2005
https://youtu.be/kUzEuHYjodo
Oct 06, 2012 | 2005 KTM EXC 200
How much oil do you put in the front forks of a 2004 ktm sx 250
A good rule of thumb on anything that has a plug that removes to pour oil in, which I am assuming this one does, get it level and pour oil into it until it just starts to run out of the hole,. Again make sure it is setting level.
Gillight
Jun 22, 2012 | 2004 KTM SX 250
Change oil fork
There is a bit of directions on how to change the oil. I will give you a link to a site that has pictures with step-by-step directions that will work for any bike fork.
http://www.bluepoof.com/motorcycles/howto/svs_fork_oil/
If you have any more questions, feel free to ask..
Nov 25, 2009 | 2004 KTM EXC 200
Changing fork oil on a 2004 ktm 125.
It is something that you can do yourself, but you will need some special tools in order to do it. I'd recomend purchasing a spanner wrench, seal drivers, and an owner's manual if you don't have one to do the job. The cost of these tools, and you can't do the job without them, pretty much kills any money saving over having a KTM dealership to do it, but once you have them, you can do the job yourself on yours or other WP 48mm forks. They give you all the steps in your owner's manual. If you don't have one of those, get one. It spells out how to perform a lot of maintenance jobs that will save you money in the long run.
Mar 19, 2009 | 2008 KTM 200 EXC
How to fill the front suspension on a ktm exc 2001
If you get the sevice manual or contact a dealer to get the correct oil amount for your bike, they need to know the model and year, you have to have the forks off the bike. take the fork caps off, take the springs out compress the upper fork tube all the way and add the specified oil. if they also give you the measured amount from the top that's the best way to get both fork oil levels exact. there is a special tool that you set the oil level in millimeters and it sucks out the oil to the right level, but before you do that step after adding the oil always pull and push on the cartage rod several times to remove air from the cartage tube. you will hear the air coming out and you will feel the changes in the cartage rod as the cartage tube fills up with oil and the air is removed.
something i'm confussed on though is if you replaced a seal you would have had to brake down the fork to replace it. you would have poored the oil into a container, cleaned all the internal parts,and used a fork seal driver to install the new seal. part of your question asks where do i put the oil in? thats in the open end of the fork after you have taken off the fork cap. It sounds to me like you only replaced the dust seal on one fork. that is not going to fix your leaking fork. you need to replace the oil seal thats pressed inside of the top fork tube.
Dec 01, 2008 | 2008 KTM 200 EXC
Clutch fluid
Use 5wt. fork oil or ATF Dextron II/III. I've use both and have the 5wt. fork oil in now. Suppose to have a lighter pull but can't really tell any difference. Use a large syringe to pump the oil in from the bleeder at the bottom up to the master cylinder.
Nov 10, 2008 | 2002 KTM LC 8 Adventure
Marzocchi Fork Oil - Fork Oil 7.5 weight Logo
26 people viewed this question
Top Marzocchi Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Marzocchi Cycling Expert? Answer questions, earn points and help others
