Getting a Ricoh Copier Ready to Ship.
Is there a way to lock the scanner from moving during shipping?
  • Office Equip... Expert
  • 398 Answers
There is an SP mode to put scanner to "ship position" depending on model (none given) but over all it is no big deal if copier is kept level and nothing very heavy on top of it. -Carl
Posted on Apr 18, 2014
  • Brian Allen
    Brian Allen Apr 18, 2014
    Sorry It's Ricoh Aficio MP 7000
  • quennie732 Apr 18, 2014
    On this model I found no sp for this, big copier it should not be a problem. -Carl
Scanner carriage error
Look in the book for the scanner lock. It will still be locked for transport.
Jan 24, 2014 | Ricoh Aficio SP C240SF
Ricoh Aficio Sc 122
The scanner home position sensor
does not detect the home position
during initialization.
Causes:
Scanner I/O board or SBU defective
• Scanner motor defective
• Harness between scanner I/O board
and scanner motor disconnected
• Scanner HP sensor defective
• Harness between SBU and HP sensor
disconnected
• Scanner wire, timing belt, pulley, or
carriage defective
Aug 14, 2012 | Ricoh Aficio 2232C Color Copier
My copier is ricoh aficio 650 during it self test and worming time the message appear sc101 - 00
That message is related to the scanner.
Probably the scanner lamp is dirty and the white bar under the glass.
You have to remove the glass and clean it with a dry cloth.
See you
May 13, 2011 | Ricoh Aficio 450 Copier
Scanner will not move
Check to see if it's locked. Some scanners have a mechanical switch that locks the head so it will not become damaged during shipping.
Mar 23, 2010 | Canon CanoScan 8600F Flatbed Scanner
Scanner locked message on display. Will not copy
Check if the transit lock may have engaged due to movement. These locks prevent the scanner from moving while moving the devices during shipping. They sometimes engage by themselves.
Mar 23, 2010 | Xerox FAXCENTRE 2218 18PPM FAX
I HAVE A SHARP COPIER- AL-1631 CODE- L-1 POPS UP WHEN I TRY TO MAKE A COPY
Check to see if the scanner is locked. There is a lock underneath the scanner to keep it from moving during shipping.
Jan 06, 2010 | Office Equipment & Supplies
Ricoh Aficio Color 6513 scanning mechanism lock
A locking mechanism holds and protects scanner optics during shipment.
You product is a printer though, not a scanner, and does't have any physical locking mechanism or switch, so the instruction to lock down the scanning mechanism doesn't apply.
Just turn off the main power switch.
Aug 24, 2009 | Marshall Inkjet Canvas Cloth - 11x17" - 6...
System error L1-00
the L1-00 indicate the scanner carriage is not moving. Something is stopping it. Open the document feeder and turn the copier on while watching the scan carriage (beneath the main glass) - does it move or try to move ? does it make a noise?
If it seems to be moving freely for a bit and then stop - is it going back to its "home" position (starting point). Remove the main glass and then move the scan carriage by hand (with the copier turned off) .. does the carriage move ok? check for a loose carriage drive wire or debris or something broken. Make sure the carriage locking screw is not holding it. Then turn the copier back on and see if the carriage makes an attempt to move back to its starting point. if everything seems to be moving ok then the problem could ly with the "home position" sensor. It could also possibly be a bad drive motor.
Apr 03, 2009 | Sharp AL-1655CS Copier
WHAT DOES A L1 MEAN
The L1 is indicating a scanner lock.
1. Turn machine off.
2. Make sure the scanner lock is unlocked. This is a clear plastic knob. (it is located on the left hand side of the machine under the document glass in the copy exit area - check your manual for a picture.)
3. Turn machine back on, watch scanner to see if it moves.
4. Try a copy.
5. If you still get an L1 then it might need service because the scanning bar is jammed.
This also is a fix if you are getting blank copies.
Hope that helps...
Jun 23, 2008 | Ricoh 3310LE Copier
Toshiba printer e-studio 150
There is a small clear plastic circle under where the paper comes out, it has two positions, lock and unlock, sometimes when people grab the copies they bump it to lock, use a flash light and make sure its unlocked, you can also just remove it, it was there for shipping. L-codes = scanner lock problems, real cold conditions can cause the scanner greases to not allow the scanner to move fast enough, put the copier somewhere warm. Good Luck!!!
Jan 22, 2008 | Kyocera RI-3530 Black and White Copier
44 people viewed this question
k24674
jasbo
jasbo
