Question about GE FUF17SVRWW Upright Freezer
I Have A Freezer Model Fuf17svrww.the Door Open Light Control Is On And Sounds and the door is completely close
  • 884 Answers
Check the door switch is being closed when the door closes. The door may have dropped just enough to allow the switch not to be activated by the edge of the door.
Posted on Apr 28, 2014
3 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: freezer door won't close
There are several type of attachments, so pick the one best suited to you....
1. (most likely) With the door open, pull on the plastic panel. If it is held on by clips, it will pull straight off. Look carefully at the clips on the panel. Usually, they bend out of position after being forced back on. Adjust the clips, and gently press back into place. If they are damaged, the clips can be reattached with a 2 part epoxy. I prefer JB weld epoxy.
2. Locate the screws that holds the plastic piece on, and loosen them. Adjust the piece. Tighten the screws.
Best regards, --W/D-- please feel free to rate this solution! thanx!
Posted on Aug 01, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: freezer doorpops open when close
Sorry to read about your problem, I hope this helps you out.
The gasket seals are getting weak.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 27, 2010
Testimonial: "After 6 years, it seems about time for that. How do you redo them??? Thanks you, we figured that out."
Refrigerator problems 2-door freezer door stuck will not open
Good Afternoon friend, I appreciate your post!
Based off what you have described the door on your Frigidaire refrigerator is stuck and will not open. It sounds like you may have condensation on your gasket and it has frozen the door shut. The best thing to do is disconnect power from the refrigerator for four to six hours and that should break up any ice holding the door closed. I hope this is helpful information. -Matt
Mar 01, 2015 | Frigidaire FFHT1715L 16.5 cu. ft....
Freezer control
Go to appliancepartspros.com
They have everything. If you do not like the price you now have the part number and can check that out on ebay for an even better deal.
Jan 20, 2014 | GE FUF17SVRWW Upright Freezer
Freezer not cold. Can't get to coils to see if they are frozen.
Hi grammycather, thank you for allowing me to assist you. Here are a few simple troubleshooting tips that may help you resolve this issue:
First check clearances around your freezer. There must be adequate space around a freezer with a static condenser so that air can circulate properly. Proper clearances include 1" at the back and 3" on top of the unit.
Examine your doors. If the doors have been opened too often or for too long, this may have allowed warm air to enter the appliance. Make sure to shut the door completely and be sure not to keep the door open for too long. Even leaving a door slightly open can allow too much warm air intake. Make sure freezer is level and keep food and containers from blocking the door closing.
Check the door seal. You do this by placing a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet, double check to see if the door is being blocked by anything that may be stopping it from closing. If nothing is stopping the door from closing then refer to a tech to replace the gasket.
Check to see if the condenser is dirty. A dirty condenser cannot release heat efficiently into the surrounding air. Cleaning the condenser may be necessary, more if you have animals in the house. If you have condenser coils, they should be wiped occasionally with a damp cloth to remove accumulated dust. The condenser coils should be wiped occasionally with a damp cloth to remove accumulated dust.
Check for any obstructions to the vent to ensure proper air flow. If the vent is blocked, the air in the freezer will not get cool.
I suggest to double check the freezer control. If the freezer control is set too warm, set freezer control to a colder setting and allow 24 hours for temperature to stabilize.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Aug 11, 2013 | Frigidaire 14 cu. ft. / 396 liter Upright...
Frigidaire freezer LFFU14F5HWN fan not running or cooling
Hi djgecko - Here are a few simple troubleshooting tips that may help you resolve this issue:
· First check clearances around your freezer. There must be adequate space around a freezer with a static condenser so that air can circulate properly. Proper clearances include 1" at the back and 3" on top of the unit.
· Examine your doors. If the doors have been opened too often or for too long, this may have allowed warm air to enter the freezer. Make sure to shut the door completely and be sure not to keep the door open for too long. Even leaving a door slightly open can allow too much warm air intake. Make sure the freezer is level and keep food and containers from blocking the door closing.
· Check the door seal. You do this by placing a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet, double check to see if the door is being blocked by anything that may be stopping it from closing. If nothing is stopping the door from closing then replace the gasket. (Most appliance owners can easily do this without any tools or sealant.)
· Check to see if the condenser is dirty. A dirty condenser cannot release heat efficiently into the surrounding air. Cleaning the condenser may be necessary, more if you have animals in the house. If you have condenser coils, they should be wiped occasionally with a damp cloth to remove accumulated dust. The condenser coils should be wiped occasionally with a damp cloth to remove accumulated dust.
· Check for any obstructions to the vent to ensure proper air flow. If the vent is blocked, the air in the freezer will not get cool.
· Double check the freezer control. If the freezer control is set too warm, set freezer control to a colder setting and allow 24 hours for temperature to stabilize.
Apr 17, 2013 | Frigidaire 13.7 cu. ft. / 388 liter...
Light will not go out when door is closes
It sounds like the door switch is sticking in the on position to me>
Does it go out if you manually press door switch with the door open?
If it doesnt then its almost certainly a sticking door switch. You may have to bring this unit completely out of the fridge to look at it and then test it for a permnanently closed contact.
Mar 05, 2013 | AEG 10.35 cu. ft. / 293 liter Upright...
Food is not completely freezing in spots
This is a symptom of air leaking into the freezer. The most common place is around the door. Check the door really good to make sure something is not obstructing it from closing all the way, it may be closing enough to satisfy the ajar alarm but not enough for a bit of moisture to sneak in. Look for tears or breaks in the seal. If you put a bright flashlight inside the freezer and close the door, turn off the lights in the room you may find a leak that way.
May 03, 2010 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
Weird (Pressure Release) Noise After The Door Has Been Closed
The freezer being closed up tight and so cold can create a negative pressure inside. This negative pressure will cause the door to be very hard to open and could pull the door closed too quickly. Most manufactures today use small air valves the open and release as the door is being opened and closed. They are most often found on the bottom of the door itself or sometimes in the cabinet behind the back wall.
The noise is perfectly normal, my wife says it is there to alarm her when I am eating too many ice cream bars.....
May 03, 2010 | Frigidaire 14.1 cu. ft. / 399 liter...
I left the Freezer door open and now it seems like the freezer is not cold enough to freeze things. It has been 5-6 hours since it has been closed. Is it just taking a long time to completely cold or...
Place a glass of lukewarm water on one of the freezer shelves. Leave the freezer door closed overnight. Check the water in the morning to see if the freezer has brought the temperature down. It takes quite awhile for refrigeration units to recover from heat loads such as door open for extended periods of time.
Jan 06, 2010 | Freezers
FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Dec 29, 2007 | Freezers
Fisher and paykel vertical freezer N308 model
bec,
Sounds like you are freezing up! The coils are so frost-laden that they will not allow the unit to function. The unit will need a complete defrost. I'm not familiar with the exact layout of this unit but I can tell you that it needs to be shut down, have warm air blown into the fan area and completely freed of ice. If you just leave it open and turned off, this takes about 2 days.
Possible causes: humidity in the air is condensing...very humid area, too much 'window shopping', not closing the door completely, possible damaged door gasket.
Others: (on older units)
Possible defrost timer problem...or low gas. Try the defrost route. We'll go from there.
Dec 03, 2007 | Freezers
GE FUF17SVRWW Upright Freezer Logo
157 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
John Tripp
John Tripp
Are you a GE Freezer Expert? Answer questions, earn points and help others
