Question about Bissell 3591 CleanView Bagless Upright Vacuum
Wont turn on
It shut off and you turn on switch wont do nothing
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
Reset fuse on vac?
Posted on May 06, 2014
My rainbow stop working.no red lights.3 times try to start and then switch off by itself.what should I do?
PDF]3 - Rainbow
rainbowsystem.com/.../Rainbow_e2_2011_R14449A-1_English_P...
RexairAs part of Rexair's Customer Care program, each Rainbow and Power Nozzle receives a ... If the Rainbow is not working ... Do not clean the unit or unclog the hose until theRainbow is switched off and the plug is removed from the wall ..... alone or with the Jet Brush attached. ..... The Power Nozzle brush is stopped and.
My Rainbow Vacuum Cleaner Won't Turn On ' eHow
Rainbow keeps shutting off Vacuums Questions & Answers ...www.fixya.com > Forum > Tags > keeps shutting off > VacuumsRainbow vacuums keeps shutting off related questions and answers. ... My Rainbowstopped running I was using the Rainbow and it stopped running. ... the switch . my electrolux has the same problem but wont always turn on.so it probably is ...Three common problems with Power Nozzles and how to fix ...
Dec 03, 2015 | Rainbow Vacuums
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
My eureka enviro vac shut off and wont turn back on it was clogged but does not smell burnt . is there a reset or some kind of shut off when it gets clogged?
Same thing happened to me. I checked the owner's manual and it turns out the Eureka Envirovac has a built-in thermal cut-off switch. So anytime the motor gets too hot, it just shuts down. Most of the time this is because it gets plugged or the filter is too dirty. In my case, the dust basket thingy and filter were clogged beyond belief. Probably would help to clean that more regularly in hindsight. Supposedly it will turn back on after the recommended 30 minute wait.
Apr 15, 2011 | Eureka 5893AVZ Bagless Upright Cyclonic...
I have a hoover windtunnel upright vacuum, It will not shut off and I have to unplug it to do so. If I take apart the upper handle and manually flip the internal switch it works just fine, only when using...
This is a common problem with this machine. The switch has too much resistance to be turned on and off with the switch button and rod. If you put in a new switch, ( # 28161075 ), your problem should be fixed.
Mar 23, 2011 | Vacuums
Wont shut Off
its the power switch, hoover has had that problem for years. I'd take it to a vac repair shop, sometimes the wires that connect to the switch get burnt as well and should be replaced.
Sep 16, 2009 | Hoover U6630-900 WindTunnel Bagless...
Kirby wont come back on checked outlet its ok
If you are refitting the shampoo tank, you havent turned it far enough. There is a safety switch that must lock
Mar 07, 2009 | Kirby Ultimate G Bagged Upright Vacuum
My nutone cv556 wont shut off
It sounds like the relay is bad. This website has a pretty good trouble shooting page.
https://www.centralvacuumstores.com/cvs/trouble_help.php#wont_turn_on
Sep 28, 2008 | Broan-NuTone CV450 Central Bagged Central...
My Rainbow stopped running
did you ever find out the problem with your rainbow? Mine did the same thing today- turned on the switch yet nothing happened. Think it needs a new switch???? Do you know how to get canister apart after taking out first screws?
Jun 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacums
check belt not broken - could have happened when you caught tassle in head
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Bissell 3591 CleanView Bagless Upright Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
