Question about LG Refrigerators
LG gwl227hsya freezer not working properly
My lg gwl227hsya side by side fridge freezer is not working properly. The fridge works finebut the freezer is not getting cold enough to freeze all the goods
  • 29 Answers
SOURCE: Our beko frost free fridge
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Posted on Aug 13, 2008
ghappliances
  • 126 Answers
SOURCE: GE side by side refridgerator
YOU NEED TO CHECK THAT YOUR HEATER ELEMENT AND SENSORS ARE FUNCTIONING WELL AS THAT WILL CAUSE THE ICE BUILD UP AND THE UNIT NOT TO WORK PROPERLY. GOODLUCK.MOHAMED
Posted on Sep 17, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
  • 236 Answers
SOURCE: Both freezer and fridge Not cold on top
sounds like the circulation fans are jammed/seized or faulty -try a full defrost and see what happens after that.
Posted on Apr 04, 2009
  • 401 Answers
SOURCE: Freezer not getting cold enough.
That is normal since the cold control is on the refrigerator side and is satisfied. It needs to be in a heated environment and not in an unheated garage.
Posted on Jan 05, 2010
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
I bought a fridge from liquidation a Kenmore model #59649539018 freezer works finebut the fridge is not cooling they changed the control panel but still not working
There should be a fan in the freezer that moves cold air into the fridge. The fan might not be working. The temp setting for the fridge is a door that opens and closes depending on the setting. Check to make sure it works.
Nov 19, 2014 | Refrigerators
Ice build up in LG frost free american freezer
You have a problem with your auto defrost system or someone did not get door shut all the way
Jul 14, 2014 | LG Refrigerators
Gwl227hsya, water not dispensing. Water in the bottle inside the fridge. Can hear the pump but no water coming out. Fridge is only 6 months old!
Any luck with fixing this- I have the same problem with this fridge- six months old also. Not even filling up ice dispenser either~?
Feb 20, 2011 | LG Refrigerators
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Jan 03, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
114 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
