Question about Whirlpool Dryers
Removing the front plate of a Whirlpool WED7800XW?
I need to replace the heater element of a 3 year old Whirlpool WED7800XW. I have read many times that you go thru the front now for the newer units to replace the heater element. It is always stated that you remove the kick plate - unfortunately, this model has one solid front plate (no lower kick plate). Does anyone know how to remove this full face plate on the Whirlpool WED7800XW?
watugot
  • 290 Answers
SOURCE: Kenmore Electric Dryer Model # 110.62622101
I think on your machine the lower thermostat connected to one terminal of the element, you have a wire coming from the thermal cut off down to the top terminal of the lower thermostat, a wire from the lower thermostat to the timer, and a wire going to the other terminal of the element.
You probably have the wire from the cut-off correct as it won't reach the other terminals. You have crossed the other 2 wires. This caused 240V to short across the lower thermostat and burned it out.
You will need a new Hi-limit thermostat, which will include the upper cut-off as well. They come as a set part# 279816. This will be a little different because the new hi-limit will not connect directly to the element. There will be all the wire ends and instructions with it that you need to get it hooked up correctly.
There should be a wiring diagram inside the console of the dryer that shows which wires go where, but I am sure you have crossed the 2 wires below the hi-limit switch.
Post back if you need any help.
Thanks/Mike
Posted on Dec 02, 2007
aborcass
  • 2651 Answers
SOURCE: Whirlpool Dryer Motor Removal
stand that baby up!!! acess is from front, try removeig 2 screws from under lint filter and then pop top with screw driver lean top back.. youll see the tub and belt(if not broken right there),no belt??? order a 341241 whirlpool dryer belt. 2 5/16screws on either side of iside facade remoivefront caver, disconnect door switch and remove front panel. belt slips over drum , you need to reset tension pulley and wrap around motor shaft. .
Posted on Feb 26, 2008
  • 156 Answers
SOURCE: Newer Whirlpool Dryer Heat Element keeps breaking
  • clean out the dryer vent make sure hose behind dryer not pinched close ck the temp comeing out bac k dryer should be around 160
Posted on Mar 06, 2008
  • 1073 Answers
SOURCE: Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Posted on Jun 11, 2008
SOURCE: Amana Electric Dryer runs but does not heat up - model ndw2330ayw -
I HAVE AN AMANA DRYER MODEL LE8217W2 ITWILL COME ON FOR A SHORT TIME AND THEN CUT OFF. I CHANGE THE BELT, THE MOTOR AND THE THERMOSTAT. THE DRYER STAYS ON , BUT WILL NOT HEAT UP. WHAT'S NEXT ???? PLEASE HELP!
Posted on Nov 06, 2008
Removing the front plate on a Whirlpool WED7800XW
After you get to the element, you may want to troubleshoot other components. Common problems are failure of the thermal limiter on the element housing and poor ventilation. If the dryer is producing any heat at all, don't disassemble the dryer, you have a ventilation issue.
Unplug the dryer.
You need a 1" putty knife to get the top up. At the front left and right corners under the top panel there is a spring clip. It may be helpful to look with a flashlight first because there is an alignment pin that sits right beside them. They can be stubborn so you may need to hit the back of the putty knife to get them loose. Apply upward pressure on the top panel as you disengage the spring clips. You will also need to remove the screws that secure the front panel to the lint screen housing (2 or 4 philips screws).
Once you get both sides released, open the door 90 degrees and the top panel will lift up on a rear hinge. With the top up you can access two 5/16" hex screws that secure the front panel to the bulkhead. Remove these and the front panel should lean forward. Remove front panel.
Remove the 5/16" hex screws that secure the lower lint screen duct to the blower housing and front bulkhead and remove duct. Disconnect wiring harness for the moisture sensor at the bottom right of bulkhead. There will be 4 screws holding the bulkhead to the rest of the cabinet. Remove these and lift off front bulkhead assembly. Two rollers on the back will want to hang on to the drum but gently turning the bulkhead should release without much trouble.
Remove the belt by releasing tension on the idler pulley and, using the belt as a handle at the top, remove the belt and drum together. The element is on the right, and you will need to remove the wires from the thermal limiter at the back, hi limit thermostat in the middle, and element at the front.
To remove the element, there are two 1/4" screws at the front that are tough to get to because you don't have much clearance, but they support the front of the element housing. There is one screw at the rear. Remove the element and then the hi limit and thermal limiter screws.
Apr 18, 2014 | Whirlpool Dryers
To check the elements hot water hearter stop heating.whirlpool electric
While the power is off to the water heater it's safe to remove the access panels. Once the elements are exposed a multimeter that is set on the Ohms can be used. The average reading of a good element is around 12 ohms. This can range a few ohms up or down. If you don't get a good reading the element will need to be replaced.
If the water heater has two elements the top element should be checked first. When a Whirlpool heater has two elements and the top goes out this will cause the water heater not to heat at all.
If both elements show they are good it would be recommended to contact the manufacturer. The technical support line for the Whirlpool water heaters is 1-877-817-6750.
Sep 02, 2010 | Whirlpool Water Heaters
How do you replace the heat element on a whirlpool LER8648 dryer?
Before replacing the heating element, check first the continuity of the thermal cut-off and the high-limit thermostat located on the heater box, the resistance of the heating element, and the continuity cycling thermostat located on the blower housing. Replace the heating element only when it reads open. Replace both the thermal cut-off and the high-limit thermostat should any one of them is found open. The cycling thermostat must have continuity between its thicker terminals; otherwise, replace it.
All of the above components are accessible through the rear of the dryer. Remove the rear panel by removing the screws securing i to the dryer cabinet. Replace the heating element by removing the screws attaching its housing to the heater box then securing the new heating element housing in place.
May 28, 2010 | Whirlpool Dryers
My 15 year-old RHEEM Warrior Model 71-40S forty gallon electric water heater is leaking, and the element also needs replaced. I am thinking it is likely time to get a new, energy-efficient model versus...
Rheem makes great products. Lowe's sells whirlpool brand and they are not all that bad for the money. I would buy something better than the budget 7 year warranty model though. My preferred choice is AO Smith. I would definitely replace your water heater if it is 15 years old- most don't go much longer than that, although mine is 27 years old and going strong! Please remember to make sure and extend your pressure relief valve down to within 6 inches of the floor when replacing the water heater as Code requires. A water heater blanket will also earn its keep in a short amount of time.
Jan 02, 2010 | Microwave Ovens
Will run but will not heat up
Most likely a bad heating element and or bad thrmostats. you'll need to check these by ohming out after removing the rear panel to your dryer.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
Oct 26, 2009 | Whirlpool Dryers
How do you install a heating element on a whirlpool WED5300SQ0 Electric Dryer.
There are 2 kinds of heating elements.
One is in the front and one is in the back.
If you have a kick-plate in the front, remove the plate by pushing in the 2 clips with a putty knife. Then you will see the element on the right side. You need to remove a couple quarter-inch screws and then pull it out, once the 2 wires are removed from the element.
If you don't have a kick plate, you need to take the entire back panel off by removing about 10 quarter-inch screws around the parameter.
Then you can easily see the element and just remove the 2 quarter-inch screws and wires and pull it down and out.
Best of luck and please feel free to e-mail me if you have any other questions.
Sep 15, 2009 | Whirlpool WED5300S Electric Dryer
How to replace heating element?
there are 2 kinds of heating element.
One's in the front and one's in the back.
If you have a kick-plate in the front, remove the plate but pushing in the 2 clips with a putty knife. Then you will see the element on the right side. You need to remove a couple of quarter-inch screws and then pull it out, once the 2 wires are removed from the element.
Best of luck.
Aug 08, 2009 | Whirlpool Dryers
I have a electric whirlpool 50 gal. energy saver water heater that is 3 months old. It keeps shutting off so i called whirlpool and sears came out and replaced the energy smart box on top. now it is...
the thermostat should be replaced it only has one on the upper eloement, it has the dial on it to set the temp, but if it is only 3 months old it comes with a 1 year parts 6 year tank warranty, if you call whirlpool and tell them about this problem they will have there own teck or sub contractor that they use to come out and fix it for free,,, first go to there web site and put in your serial number and it will tell you how old the unit is, sometimes they sit for a while and are actually out of warranty before it is installed,, also did you install it your self?? if you did di you fill it with water all the way till the water came out of the hot side on your faucet full force before turning on the electric,, if not you have fried the whole unit, you will need to replace both elements and the thermostat, the elements must be completely submerged in water before they have the power turned on,,,
Jun 25, 2009 | Water Heaters
Replaced both elements, both thermostats. What else could it be?
no hidden switches!, did you replace bottom elements? and thermostats? one hint...bottom element heats first, then top...never both at one time.
Mar 24, 2009 | Kitchen Appliances - Others
DRYER SPINS BUT WILL NOT HEAT
The heating element is located in a pan on the rear wall of the dryer. You must remove the front and drum to access it. Start by opening the door and removing the screws that hold down the top. Then you can easily get the front off. In a GE dryer almost 100% of the time it is going to be the heater element.
When restringing the heater...READ MORE
Mar 19, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
20 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
