Question about Liebherr Freezers
Liebherr comfort no frost not working
My 4 year old upright freezer seems to have stopped working. The temperature lights have gone out and it has been very very very slowly warming up over about a month. It sounds like it is working but isn't. I've now emptied it and turned it off. Is there anything I can do as I live way too far off the beaten track to take it anywhere and it will cost a fortune to get someone out to me.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 215 Answers
Have you tried cleaning the condenser coil. They are located at the bottom of the unit and have a fan blowing them. As clean as possible is very important to operation. Let us know about this step. Roger
Posted on Apr 27, 2014
Testimonial: "Roger, I cleaned them I think!! I'm assuming it is the long black coils on the back as I can't find any other coils. It worked again for a month and stopped again, I cleaned them again and nothing?"
  • Mwenzi Morris
    Mwenzi Morris May 30, 2014
    Also, this time there is a heavy frost build up at the very top of the freezer.
  • RJ Systems (Retired) Jun 01, 2014
    A heavy frost build up in the first inches of the coil could mean it is low on refrigerant now. The smaller copper line on the compressor should be hot and the larger one cold while it is running if the refrigerant level is close.
fridgetech
  • 473 Answers
SOURCE: Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Posted on Oct 12, 2007
Master_Tech
  • 770 Answers
SOURCE: Water pours down the back(Internally) ofmy Liebherr Frost Free Fridge freezer.
It is most likely a broken water tank in back wall of refrigerator section remove the crisper drawers you will see the tank it holds about 1.5 gal of water to keep it chilled for the dispenser. check all around it with the water on and someone getting water out of the dispenser at the same time check the seams closely. you should find the leak there let me know if not we may have to look into the water inlet valve
Posted on Feb 12, 2008
  • 97 Answers
SOURCE: won't freeze
Is the compressor running the whole time? If so may have a problem with a refridgerant leak....check the compressor in the rear of unit, feel if its hot....may be as simple as a relay.
Posted on Jun 17, 2009
  • 60 Answers
SOURCE: Hot Point FZA34 freezer just 1 year old stopped
Call you authorized repair person immediately. You dont want to loose your food.This could be simpley the thermostat and they usually have part on hand if you give them the heads up.
Cheers
Al
Posted on Sep 11, 2009
  • 288 Answers
SOURCE: My Frigidaire upright freezer is only 4 years old & isn't working
freezers have safety devices to protect themselves. The compressor has an internal overload to keep it from overheating. some have external reset buttons and some do not. either way the cause must be corrected. if the freezer was low on refrigerant you would see signs of oil near the coils, tubing, or compressor. If there is no leak, it overheats when there is airflow restrictions(dirty coils) or a fan has stopped working. only a few screws keep you from seeing all there is to see. If it is clean and the fan is running, then the compressor may just be the culprit
Posted on Nov 27, 2009
Testimonial: "Thanks so much for your advice. Freezer seems to be working after being thoroughly thawed. Fingers are crossed."
I own a liebherr GNP2076 frost free upright frrezer
freezers do not normally go wrong too often so your going south is unusual.liebherr have given you a very good responce that some makers would not even dream of,i would recomend that you take up their offer as the chances of another problem are slim to zero...(in european law, it is you that has to prove that an appliance has a "inbuilt fault"to get anywhere.)
Apr 06, 2010 | Freezers
Frigidaire upright--"Hi temp" warning light on door. Don't know why freezer temperatures are so high (into 30s), food is thawing. Electrical seems to be fine. Have not noticed problems with door. New...
2 months old should still be under warenty.
Check the freezer fan by opening the freezer door and pressing the door switch and listing for the freezer fan sound. If no sound then the fan motor could be bad.
Look at the back wall too see if you have frost build up. If you do then you have a defrost problem.
If thees are not your problem you could have a seal system problem. (( freon leak ))
Jan 11, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Nov 24, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Won't freeze
Jun 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Working ff freezer unplugged 1 year now does not freeze
Hi!!! You seem to have a seal system problem..A leak of refrigerant or a restriction in the seal system..Good luck...
Jan 20, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Flashing power light on Kenmore upright freezer
If the yellow light is flashing it may mean that the 9 volt battery is dead.
On my Kenmore there's a small battery compartment on the bottom right of the unit - under the door.
Aug 10, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Oct 12, 2007 | Maytag Freezer MQU2057
Freezers Logo
190 people viewed this question
Top Liebherr Freezers Experts
richie46
ray gallant
Tom Chichester
Are you a Liebherr Freezer Expert? Answer questions, earn points and help others
