Mr. DV9000 laptop lid is loose, not bad but don't want it to get worse, can I tighten it myself? If so, how? Thanks, KC
  • 157 Answers
Actually you would need to take it into a repair shop. If you try to do it yourself then you can mess up the computer even worse.
Posted on Jun 19, 2009
I have HP DV9000 laptop when i switch on it powers but the display is like in safe mood i cant see anything
i am mr john uche aaron
in Nigeria ,
my hp pavilion dv 9000
cannot bootup
but display only light on the quick bar
and blank screen
what is the solution
Dec 12, 2010 | HP Pavilion dv9000 Motherboard
I have a HP Pavilion dv9330us Notebook PC that is about 3 years old. Recently, the LCD display has developed a flicker when the laptop lid is moved. At times, a green-tinted shadow appears until a jiggle...
no card there. its cables and connector only
i cant see it do its dance so no answers possible.
ask the living?
obviously its broken and is inside.
some dv9000 have ccfl lamps that all die...
that greed deal sound serious.
get the service book , read how to remove keyboard
and flex the LCD cable there. it might just be loose.
https://h30434.www3.hp.com/
the pc is retired status now. no support page
but parts yes.
the parts page shows inverter and CCFL.
if the tubes fail they do go dim /flicker and turn yellow.
that yell can make other colors go green.
but I cant see it so IDK
Aug 26, 2017 | HP Pavilion dv9330us Notebook
Hp pavillion dv9000 lcd screen changes colour when moved
The inverter is to change the volts from the laptop to the Backlight. This wont have anything to do with it.
Im more than certian it will be the LCD cable. Proberly loose or torn at where the lid closes.
Hope this helps.
James
Feb 23, 2010 | HP Computers & Internet
Loose hinge/lid on Dell latitude D410 laptop-lid does not stay upright and falls back flat and no screws to tighten...How can you fix this? Thanks
I took the hinge cover off to look for myself to see if there were in fact some set screws to tighten the monitor up. None were found, no suprise there. While on ebay ordering a new hinge set I noticed that the picture of the new hinges didn;t look the same as what I observed on the laptop. The pin on the right was sticking out on my lapto but in the picture on ebay it was flush.
I used a flat ended phillips tip screwdriver and pushed the pin back in while gently rocking the monitor back and forth. That seemed to solve the problem.
Jan 22, 2010 | Dell Latitude D410 Notebook
HP DV9000 My laptop screen is loose i would
When the laptop is flipped over, remove the battery. Under the battery there are 6 screws placed in pairs, these have to be removed. Once these are removed, the speaker and power strip can be pryed up, start with your finger nails on the right side and pop it off. Be careful with the flat cable in the middle of the strip. Tighten the screws for the display there and I think there are some that tighten from the bottom. Also, remove the rubber pads from the screen bezel and remove the screws from the screen bezel, then pry the bezel off at a corner and work your way around the bezel until it is removed. It will somply snap back on when you are finished. Tighten all the screws you see that connect to the hinges, this is wher the screen loosens alot. Just pay attention to the wires that feed through the bezel from the screen to the motherboard. Take your time, nothing to it.
Aug 22, 2009 | Frigidaire FRT17G4B Top Freezer...
Sony VGN AR630
If the lid has a small slack and then is firmer again when the lid/screen is in another position, then the hinge mounting screws is most likely loose and the mounting screws needs to be tighten.
If the hinges are loose no matter what the position of the lid/screen is in then, they need to be replaced, there is no adjustment to tighten the hinges.
Jul 23, 2009 | Sony VAIO VGN-AR630E Notebook
HP DV 1000 Loose Hinges?
I have replaced hinges on HPs and other laptops. I have found laptop hinges have no adjustments and have to be replaced.
Jun 28, 2009 | HP Pavilion dv1000 Notebook
Tightening HP Pavilion DV9000 17'' LCD Hinges
you may find the hinges parts from eBay which is cheaper price:
http://shop.ebay.ca/?_from=R40&_trksid=m38&_nkw=HP+Pavilion+DV9000+hinges&_sacat=See-All-Categories
how to replace your laptop hinges:
1) take out the screws at back of laptop under the hinges base
2) or take out the screw at side of laptop near the hinges base (if you find any screw there)
3) there are two cables connect between LCD lid and laptop base
you do not need disconnect those canbles. just careful them
4) take out all scews on the front of lid cover( the scews is covered by thin plastic cover), then take away front lid cover.
5) take out the screws at beside hinge base and side of LCD panel(2-4 scews at one side), you need check the back of lid cover can separate to LCD panel a little., be care replace only one at one time .
6) put back all screws step by step.
hope help you fix it, please take a rating let me know how much you are helped, thanks! any question please let me know!
May 18, 2009 | HP Pavilion dv6000z Notebook
DV9000 Black Screen
You just need to diable presentation mode.It's not the switch.
Mar 22, 2009 | HP Pavilion dv9000t PC Notebook
Computers & Internet Logo
23 people viewed this question
Alun Cox
David Payne
David Payne
